"Beautiful" Headphone Amplifier?
Xulonn
Boquete, Chiriqui, Panama
I'm not a headphone user - although I do own a Topping DX7s and also have a HIFIMAN HE400SE open-back headphone on my wish-list at Amazon.
This morning, when continuing my periodic search for "beautiful amplifiers" to add to my thread on that subject, I stumbled across a fine example of a beautiful design and impeccable craftsmanship from Feliks Audio. I wonder how this 15.1Kg (33lb) - 6,500€ "hand-crafted" Polish monster would measure and sound? (I am not expecting @amirm to get one to review!)
It would be interesting to try as a balanced preamplifier as well - perhaps driving a Purifi amplifier...300B magic with Purifi Hypex power? Sounds [sic] like an audio subjectivist's dream combo.
TECHNICAL SPECIFICATION​
Class A Single-ended transformer coupled amplifier
  • Power tubes: 300B
  • Driver tubes: PsVane CV-181 mk2 (6SN7)
  • 2x unbalanced RCA inputs (IN1, IN2)
  • 1x balanced XLR input (IN3)
  • Input sensitivity 1V RMS
  • Input impedance:
    – For IN1 i IN2 (RCA) 100kΩ
    – For IN3 (XLR) 10kΩ
  • 1x pair of pre-amplifier output as RCA
  • 1x pair of pre-amplifier output as XLR
Maximum voltage on the above outputs is 5V (RMS) at output impedance of 600Ω and THD<0,5%
  • Impedance selector guidance:
    – LO – up to 60Ω
    – MID – up to 300Ω
    – HI – up to 600Ω–mnh
  • Amplifier’s impedance:
    – LO at 32Ω load is 3,8Ω
    – MID at 100Ω load is 8,8Ω
    – HI at 600Ω is 20Ω
Output powered measured at MID impedance setting at load of 16Ω is 5W with THD ⩽1% (maximum 8W at THD >5%)
  • Frequency response:
    – 8Hz÷100kHz ±3dB
    – 18Hz÷40kHz ±1dB
  • Headphone outputs: 6.3mm and XLR
  • AC voltage 50/60Hz:
    – 230V version (±5%)
    – 115V version (±5%)
  • Power consumption: 110VA
  • Weight: 15,1kg (without packaging)
  • Dimensions:
    – 35x33x18,5cm (LxWxH) – without tubes
    – 35x33x24,5cm (LxWxH) – with tubes
DonR
Vancouver(ish)
That is very pretty. I have always liked electronics wrapped in wood or leather. Probably measure"good enough".
Doodski
I see a pretty piece of gear... drOOL! Other than impeccably good looks and excellent layout it also strikes the right chords with the balanced operation. :D
DVDdoug
i like the wood but tubes are "just "dumb". ;)
Tubes are inefficient. Class-A is also inefficient (but maybe OK since headphones don't require much power). And class-A is OK for a preamp. Audio-output transformers add cost It's very expensive to make a good one. I'm not sure if you can make a directly coupled headphone amp with tubes. Tube power amplifiers (for speakers) do require a transformer and that's a HUGE advantage for solid state amplifiers.
Hopefully, just amplifies the signal and doesn't "sound like" anything!
...If I'm spending hundreds or thousands of dollars on an amplifier, I want at least one watt per dollar! Although there is a certain minimum cost of building & selling a little box with electronics in it, so a couple-hundred dollars isn't out of line for headphone amp.
JeffS7444
Potentially heirloom-quality due in part to the beautiful wood. Assuming of course that you got heirs, and they care about such things! For the price, I wish it had connectors for hooking up 8 ohm speakers too.
DonR
Vancouver(ish)
hmmm... at 3.8 ohm output impedance I am not sure I would want to hook up an 8 ohm speaker.
Xulonn
Xulonn
Does that mean your budget is $6.00 for a headphone amp with a max power of six watts like the "superb" Topping A90? Which HPAs are on your short list at that price? o_O
No need to lash out. :cool:
As many here know, my attachment to tubes is primarily sentimental. I'm 80 y/o, can barely hear to 10kHz, and solid-state audio did not exist when I got my start in the hobby with a 6L6 PP mono amplifier in 1958. I also had a prize-winning science fair project that used 811A tubes.
I agree that tubes are archaic and inefficient, and my main and desktop systems are all SS. But I have a "beautiful EL34 tube amplifier" and use it occasionally to warm my little room while I listen to music on cool evenings here in the rainforest mountains of Panama - where few homes have either heating or A/C.
My $750 40wpc EL34 PP amp sounds no better or worse than my $300 ICEpower amps at the moderate to fairly loud levels of my normal listening sessions. However, the warm glow of the tubes, good music, a cup of hot tea and a slice of fresh banana bread - and the memories of days past - provide for some pleasant evenings.
DSJR
Suffolk Coastal, UK
I;d just take the wooden case and front/rear controls and connections.
Xulonn
Xulonn
Me too. But I want one with cheap tubes and a only a filament transformer to make them glow - and a TPA3255 amplifier inside. However, this amplifier chassis with its excellent fit of complex lines and angles between the wood and metal would be difficult and/or expensive to duplicate.
Many who look at this Feliks amplifier will not realize how much more difficult and complex this is compared to a tube amplifier chassis with a top copper or steel plate set into a dead-simple mitered box - like the $226 Ziron kit amp below. Conversely, anyone with woodworking experience will appreciate craftsmanship dislayed by the Feliks amplifier.
JeffS7444
David, where did you find this Ziron amplifier? I did not find it on eBay or AliExpress.
Martin
Cape Coral, FL
That Feliks Audio amp is gorgeous.
I heard headphones on a Yaqin MS-300C integrated amplifier an an audio show once:
It sounded good and I wanted one for years.
I have always liked the look of the Cayin HA-300:
There's something about tubes...
I prefer this one for listening (it looks good, too):
Martin
Xulonn
Xulonn
David, where did you find this Ziron amplifier? I did not find it on eBay or AliExpress.LOL
o_O - That's because Aliexpress lists it as a "Crude wood case' and I saw "Ziron" on the badge on the front of the chassis. It's a cheap PCB design - much more difficult to modify or upgrade. Ad + pics here LINK . I just stumbled across it searching for simple wood chassis images.
Xulonn
Xulonn
Here's a single-ended vacuum tube HPA based on 1626 output tubes from Wisconsin's Toolshed Audio. It's an interesting variation on "industrial design". Even @restorer-john might like the look. o_O
restorer-john
J Ratcliffe
  • Power tubes: 300B
  • Input impedance:
    – LO – up to 60Ω
    – MID – up to 300Ω
    – HI at 600Ω is 20Ω
    – 8Hz÷100kHz ±3dB
    – 18Hz÷40kHz ±1dB
  • Dimensions:
That is stunning, but I were going 300B, I'd go for an Eddie Current.
fpitas
Northern Virginia, USA
Well, hold on a minute. Mr. Atma-sphere would like a word with you...
