Behringer DCX2496 EQ Review
Rate this DSP DAC/ADC:
    Votes: 10 5.5%
    Votes: 65 35.7%
    Votes: 89 48.9%
    Votes: 18 9.9%
ssashton
Great! How?
In the filter menu, you go to the high pass and turn the knob all the way to the left. Then It will say "off".
Of course most equipment has some DC blocking that will have effect at very low frequencies usually below 20hz.
cxbell
Ah, yes, Behringer. Still use it! This is the 'full stack' (attached) -
the SRC2496 (nice headphone amp that I use with HD 580s) but primarily to match inputs,
a DEQ2496 for Parametric Eq,
the DCX2496 for driver alignment, equalisation, and AK DAC output,
and finally the A500 amp(s).
Very useful for home-built speakers. Nowadays I just use it for sub-bass integration and timing.
But yes, there's better out there now.
In its day, a relatively cheap way to operate in the analog/digital domains.
Can be setup from a PC, though Win11 makes it tough to use right software and drivers via a USB-RS232 link.
Regards,
gp4Jesus
Georgia
Big thanks for your help. This will provide signal where it counts the most for this portion of the system
Yeah I aware and realize the value* of filtering at the extremes*. I believe dbx “cuts it” in a more “non-negotiable” way.
*prevents the less learned from destroying their gear; 20-20Khz
The flip side: the THX LFE bandwidth begins @ 3 hz. I don’t know a simple way for the DIY consumer to get around the above*!safeguards*
Jimster480
Tampa Bay
Regards,
It still seems to be a pretty cheap option considering what it does and the performance isn't too bad either.
Tim Link
Eugene, OR
I just found one of these in my closet along with a DEQ2496, two items I misplaced years ago but were right under my nose the whole time in a box I didn't think they could fit into. I already had one DCX in service but that one I had modified by bypassing the output stages so the dac chip was running straight into the pre-amp. I decided to put this unmodified one in for comparison. I have to digitally attenuate by 20dB to keep the output stages from overloading my pre-amp inputs but it still sounds good - I think better than the one I modified. It seems punchier, more dynamic, with brighter and clerear hiighs. Voices have more presence. No idea if it really sounds different or if I'm just imagining things. In any case I liked the fact that it works and sounds good so I ordered some 20dB in-line attenuators. I'll give those a try and find out if I think they make any difference by allowing me to use more bits without blowing up my receiver.
Andysu
dcx 2496 a flexible loudspeaker management crossover system many golfing happy panthers
JimWeir
I’ve used this device for years to sort out loudspeaker EQ and crossovers in my DYI projects.
roog
UK, Keynsham
This is how I used the device, very convenient and quite intuitive to my simple mind and a lot more flexible /easier than mucking about designing passive crossovers. I wasn't so keen on the aged PC software interface though.
roog
UK, Keynsham
Very true, I recall playing around with RS232 in the early 80’s, loads of dip switches to set configurations.
When using the 2496 I generally preferred to prod buttons on the front panel.
An updated version would be welcome, I guess that’s what the mini dsp products do for us.
Andysu
behringer DCX 2496 cat THX approved
Reactions: WTW
