Best No oversampling dac to buy??
KehaDNb
I currently use a starting point systems dac 3 , you can look it up online, but I want to know a better option that runs also balanced …
Thanks in advance
ThatGuyYouKnow
I've come to learn that no NOS is the best NOS, unless you're going all fast and furious with your car.
If it's a must, the Schiit Bifrost 2 is a competent option.
K
KehaDNb
No I prefer nos that’s why I asked
MaxwellsEq
What is it you prefer about non-oversampling DACs? These days they seem to be pretty rare.
staticV3
the best NOS DAC currently on the market is the Holo Audio May afaik:
MaxwellsEq
K
KehaDNb
To expensive, up to 1000 Euro im in , other wise I’m out
RandomEar
While I agree that this is most likely the best NOS option, it still sucks in NOS-mode (by design):
That's around 3 dB down by 15 kHz, 5 dB by 20 kHz [source / review].
@KehaDNb If you really like NOS DACs, I suspect that this is the reason. Get any other competent oversampling DAC, dial in that frequency response by reducing treble by ~3 dB at 15 kHz and then compare it to your current setup. Preferably volume-matched and blind. Tell us about your results.
K
KehaDNb
What do u you want??
K
KehaDNb
Trying to help you find a suitable DAC and pointing out general problems with NOS designs you should be aware of to help you make an informed decision.
Yea but I prefer nos , period
gvl
SoCal
This is not a good forum to get recommendations on a NOS DAC. But Holo Audio or Sonnet is probably what you want to be looking at if you have disposable income.
K
KehaDNb
No too much money hmmm the people are weird in here
solderdude
The Neitherlands
Not entirely, the roll-off is sample time dependent. so one moment the amplitude of say 15kHz would have no roll-off and a ms later it could be down -5dB where it would always have been 0dB in a properly filtered DAC.
But... on average (what one sees in FR sweeps) there is a roll-off.
That effect only happens with 44.1 and 48kHz though (in the audible band).
There is no roll-off at 88.2 and 96kHz and higher.
Just a bunch of ultrasonic garbage that is not removed. You can't hear that but some amps and transducers could have issues with that.
In any case... there are many people liking it. Not everyone wants perfect as possible signal fidelity. Some prefer worse signal fidelity.
Whether or not there is a 'best' NOS DAC I have no idea.
Also DS DACs that have a NOS filter feature is just an 'approximation' of a sample-hold signal but a relatively accurate one that may well be better than an actual R2R DAC.
K
KehaDNb
Ok recommendation on that???
