Beta Test: Multitone Loopback Analyzer software
Blumlein 88
This is what I have to deal with... Do you think I need an audiophile AC cord to help me?
That isn't an uncommon looking result for 60 hz. I actually haven't checked the one where I currently live. I know where I last lived I was very surprised it was a clean very nice sine wave on an oscope. Makes you respect how much your PS cleans things up doesn't it. Even without the audiophile power cord or the box of grounding dirt magic.
pkane
pkane
North-East
I'm certain a $4k AC cord will help :facepalm: I'll need to do some testing with my "true sine-wave" UPS, as well as, the PS Audio regenerator and a simple RF line filter. Don't have any grounding boxes to test, unfortunately ;)
Rantapossu
Alrighty then... Let's give it one more college try before I decide to completely rip out the History feature ;)
https://app.box.com/s/qbrh3czrvudclkqs9n8lm806k3hzmjx5
I changed the behavior slightly (double click now only works on the description or time columns, since these are not editable, the other columns do whatever they'd normally do if you click on them twice).
Thanks again!
Now you nailed it !!! :cool:
The initial measurement:
Double clicked and selected from the history:
Exported, deleted, MT closed, imported, selected and color changed:
And how lucky were we that this was just the last chance before the entire "History" -feature would be removed? Phew! ;)
There's no more unwanted chart selection too when clicking around the history.
I'll propose a raise for you... :cool:
Sokel
Thanks again!
Double raise so he can get his 10K$ power cord,regenerators and those Jin (or something like this,it's been years they trended) little bells for the very last harmonics
Sokel
Did anything change in the THD+N calculations?
Until yesterday I was getting -96db at most for lows in the Xover i mess with,today with the new version:
(the spike at 50Hz is because first I need a XXXX$ cable and second because the PSU I made is not LM7815-7915 but double 7815 the DIY ancient way :p )
Sokel
...but nothing a nice little WIMA can't solve:
Sokel
There some strange messages appear when recording with both channels,something about "out of index".
pkane
pkane
North-East
pkane
pkane
North-East
Updating the released version of Multitone to the latest, v1.0.50. This is the same as the preview version of 1.0.50 with the addition of a small cosmetic change to correct the units displayed in the labels on the sweep plots.
Changes in 1.0.50
  • Add: support for dBV, dBW, V, and W display units with Amplitude Voltage (FS) and Resistance calibration settings
  • Add: support for creating custom Frequency-Modulated (FM) test signals and adding a couple of FM test signals to the drop-down list
  • Add: during measurement you can switch to the Waveform plot to see a live preview of the waveform being captured
  • Fix: reprocessed data from history entry didn’t quite match the original measurements due to lower number of averages
  • Fix: history click/unclick sometimes selected the previous entry even when the checkbox was not clicked
  • Fix: color selection dropdown in history sometimes required two clicks
  • Fix: switching to Spectrum plot after a sweep, but with the sweep still selected, and then performing a measurement would do a spectrum analysis instead of the sweep
FM test signals are specified by entering FM at the start of the line, followed by three numbers: the carrier frequency (Fc), the modulation frequency (Fm), and the frequency deviation of the modulating frequency:
FM 1k/200Hz/900Hz
FM 3k/50Hz/10k
Sokel
Changes in 1.0.50
FM 1k/200Hz/900Hz
FM 3k/50Hz/10k
You forgot the live waveform.
Moto
Paul, I have a question about the way some measurements appear. I am on 1.0.50.
In one case I do a frequency sweep from 20-20000. After trying this several times I end up with a jump at the end to a worse thd+n.
When I try it from 19-20k, it is flat. I repeated these a few times.
pkane
pkane
North-East
I think you might want to set the measurement bandwidth to include more than 20k (your setting now is 20-20kHz), say make it 20-24k. At the end, when you get a jump, just switch to the spectrum tab to see what it looks like. It'll show the last measurement, including any distortions and calculated values and what part was measured due to your bandwidth constraints. You can even observe each sweep point being measured if you switch to the Spectrum tab early, during a sweep.
Moto
how do I interpret this?
pkane
pkane
North-East
RMS level dropped a few dB's for some reason around 18-19k? Look at the Spectrum plot to see if something strange is happening at those frequencies. You can always run just the spectrum plot (not a sweep) for that frequency a few times to see if something strange occurs once in a while.
GXAlan
With version 1.50 it seems like the graph is getting cut off beyond my 20-20 range. Is there something that prevents me from seeing the whole spectrum? While it's measuring and averaging, I see everything.
*** Edit ***
it only happens when I am recording in stereo as opposed to mono
pkane
pkane
North-East
*** Edit ***
Yes, that seems inconsistent. The recorded results for stereo should be displayed full range. Only the measured noise+distortions (when using one channel) should be restricted to the measurement bandwidth. I'll change this.
Moto
But the graph is showing rms level at -90 something and thd+ n around 0. that doesnt make sense.
