Beta Test: Multitone Loopback Analyzer software
pkane
pkane
North-East
I already broke it!
(system argument out of range,think we have seen it before)
When you have a chance, please try to uninstall the old and re-download and install from the link. I had to patch the plot library to work correctly with the plot tracker, but apparently the old version of the library was included in that one.
Rantapossu
Thanks again!
(EDIT: Please read my next message, this post is done with the unpatched library. Works ok now !!!)
It still gives the error (with the updated library version):
when (and only when) I move the mouse pointer over the graph area. If the mouse pointer is anywhere else, it works normally.
The frequency indicator of the graph is also slighly broken, with 64k fft the 1 kHz fundamental shows as about 1482 Hz
and with 128k fft it is about 2968 Hz.
Rantapossu
Thanks again!
Sorry,
I forgot to uninstall the previous v1.0.66 version before the version 1.0.67 and the new patched library wasn't active (I didn't manage to install the broken initial version 1.0.67 at all before Paul updated it with the patched library). It seems to not overwrite the existing library so it was still using the v1.0.66's library.
I uninstalled and reinstalled MT and now it doesn't show the error and the frequency display is ok with the version 1.0.67.
Could it automatically overwrite the library with the patched one when installing the future versions? I seldom uninstall the older version when I install a new version and I believe there are others than me doing the same...
pkane
pkane
North-East
Sorry,
It should overwrite it automatically, but it seems like the installer decided it didn't need to for some reason. I'll take a look to make sure it does it automatically.
pkane
pkane
North-East
Just posted an updated installer that should overwrite the older plot library with the patched version automatically. Still don't know why it didn't pick this up the first time, but after a few attempts to rebuild and a number of test installs and uninstalls, it appears to be working as expected. Sorry for the confusion!
Grooved
Hi, I updated it from the automatic feature in the the software, and after that, I got a strange thing, impossible to do a test with HiFi Cable (via WASAPI, FLEXASIO, ASIO4ALL).
I had this message I never got before:
Once I clicked on Yes, the measurements were incorrect (noise everywhere).
After uninstalling Multitone with REVO Uninstaller, and installing it from the setup file (not from the software automatic feature), it works as expected for now
pkane
pkane
North-East
Strange, don’t think there’s anything in this version to cause such a behavior. Maybe some setting got corrupted.
Grooved
I don't remember how it was with the previous version, but with this one, I get the Left/Right colors information in the middle of the results window:
MC_RME
There is an option to put it elsewhere, in the left side sections.
Sokel
Since I have found nothing broken (except for the play and stop buttons that needs to press twice sometimes I decided to measure my (very) old,very first pre.
(Thir... ehm,old any way :p,be nice!)
pkane
pkane
North-East
Maybe also do a frequency response test? You can do it in multiple ways now, from an old multi-step sine sweep to log-chirp to periodic white noise. Maybe you'll find something broken, too ;) THD and Noise vs frequency could also be revealing, as well as a level sweep or a simple multitone.
Sokel
Nope,nothing broken (except that someone needs recap :p)
FR
THD+N vs Freq
THD+N vs Lvl
1Khz square
Poor thing,at least it shows consistence.
I have to do something about my grounds.
Sokel
Is there any technical reason I can't do silence measurement with DSD?
Sometimes i doesn't start,sometimes starts and proceeds but never ends.
Or is it just broken?
Sokel
Update.
It can do DSD64 ok:
...when I set it to DSD128 or DSD256 I get this (waited for more than 5 min just in case):
...lowered the FFT size just in case the calcs is heavy for my machine and I got this in DSD256:
(he,he,THAT's a black background!)
GXAlan
@pkane
1) I tried searching but didn't see an answer -- what is j-Pk vs j-rms?
2) on one of my laptops, I occasionally get stuck with Record, waiting... ; it's inconsistent. Is there anything known w/the WASAPI drivers that could cause that?
Sokel
Jitter peak to peak I believe,I searched it before:
"What is peak-to-peak jitter?
The term peak-to-peak is defined as the difference between the smallest and the largest period sampled during measurement. TIE jitter, also known as accumulated jitter or phase jitter, is the actual deviation from the ideal clock period over all clock periods."
pkane
pkane
North-East
@pkane
Jitter peak and jitter RMS magnitude, in seconds.
pkane
pkane
North-East
@pkane
With issue (2), can you press the stop and then record again and it'll start working or does it hang even after a stop?
DonH56
Monument, CO
Curious: Do you measure them both, or derive one or the other? If derived, based upon what noise model (random Gaussian noise?)
