Beta Test: Multitone Loopback Analyzer software
Sokel
Just keep running 16M FFTs, it'll die in no time :)
I actually did a 32M FFT, as well. The first time took about 5 minutes to complete, the second time only about 15 seconds.
I already do,i have a log-chirp 0-60Hz in the background for 5min now,it will end tomorrow probably :facepalm:
pkane
pkane
North-East
You have no phase control. The correct waveform would look like this in MT (I dragged the file onto it, stereo channels intentionally phase inverted):
So I added the option to specify phase of individual sine components in the test signal. With this you should be able to construct any of the sine-wave inter-sample over tests in the paper.
This way:
Or this one:
You can even specify phase for multiple tone test signal:
MC_RME
Seems not fully correct. For example the 11.025 kHz file must give 0 dBFS peak level and look like this:
Interesting how different it looks to when my old WaveLab renders the file:
In the same way WaveLab shows the other example (7350 Hz posted by me) as full square wave, with a step.
pkane
pkane
North-East
Ah, yes, I see I missed one place where the phase needed to be included in the computation.
The 11025Hz@45 looks like this now (a 3dB play gain is required, since Multitone test signal specifies sine amplitude and 0dBFS would not generate oversample overs!):
pkane
pkane
North-East
That 7350Hz plot seems wrong in WaveLab. It shows 8 samples per cycle. At 7350Hz this would make the sampling rate 7350x8 = 58.8k???
Here's what the one from MT looks like (6 samples per cycle = 7350x6 = 44100Hz):
The 11025Hz one also looks wrong in WaveLab. It shows 0 time interval between two samples in the vertical transition. That can't be right, as that is a square wave, not a sine wave. A sine wave will have four equally spaced samples. Like this:
MC_RME
Wavelab shows 6 samples as well...it just connects the samples differently. Do you have Reaper? There you can see both versions: WaveLab style with less zoom, and as soon as zoom is increased so that Reaper marks the sample points it turns to your version :)
MC_RME
And here is the 11.025 in sample view again. I think I understand the other effect, but not this one - how/why does MT show skewing/slope?
MC_RME
I think I got it...WaveLab does not show the real sample values at all points. The way its display works any sample on an edge could be either the lowest or highest value. You perform a direct connection between the samples which gives/keeps the right values for any given sample.
pkane
pkane
North-East
Exactly what I was thinking:)
Blumlein 88
BTW zooming to +-5Hz the horizontal scale does not look altogether correct.
Paul will reply I am sure. Yes, what you are seeing is something of a bug if you zoom in far enough. I don't recall, but basically I think Paul said it would require a considerable rewrite and those levels of zoom in are uncommonly needed.
MC_RME
And I fully agree with that. No information gained at <1 Hz per Div.
Blumlein 88
Also if you back up the zoom level just before it looks like that, you can then use the SHIFT key+left click on the mouse to create a pointer which will show you hz down to several decimal places.
pkane
pkane
North-East
Well, I have to disagree with that. Maybe not needed at 12kHz but definitely useful let's say at 20Hz. Similar scaling at e.g. 30Hz seems to work slightly better.
It should be easy to add a few decimal places to the axis labels. Not sure why it’s important, but it can be done.
pkane
pkane
North-East
A new test version 1.0.68: https://app.box.com/s/ue7ll9xmvwogst817x2l1xg09opvgy47
Many changes in this one, some major, so please test:
  • Add: support for phase specification in test signal format
  • Change: better label selection for linear frequency axis
  • Change: add a significant digit to frequency axis labels
  • Change: bandwidth selector changed to work consistently across all chart types
  • Change: allow mixing of different sampling rates and FFT sizes from history on the same plot
For those wanting to test intersample overs, here are three presets (I'm not including these in the installer):
https://app.box.com/s/w5sehf9ow20ym5inh1tm3h2l010w1mcw
Download the zip file and extract the three preset files. Copy them to C:\ProgramData\Multitone Analyzer\Presets folder on your computer. Then, restart Multitone -- the three Intersample presets will show up in the drop down, in addition to all the ones included in the installer:
Sokel
You're great,thanks!
