Beta Test: Multitone Loopback Analyzer software
Guy.Cohen
There was a time I wanted to check the HUMP of the ES9822PRO. My conclusion that it has hump. I have another ADC by Nihtila which is based on AK5572 that gives the same performance without scaler as EIDA with scaler. More or less.
The Nihtila has a problem of rise of THD when one reaches close to it's 0dbfs (not as E1DA).
The reduction of the hump using the scaler is by 'holding' ES9822PRO input more or less fixed.
MC_RME
The 'Nihtila' does not have this usse, the (all) AKM ADC has. That is standard behaviour, very different to the ESS ADC.
pkane
pkane
North-East
@Guy.Cohen , @pkane
IME, THD vs level is best suited to expose ESS hump as it allows to use a simple notch, helping dynamic range and distortion of the measurement chain. Preferably at a low frequency, like 200Hz or so.
"Too much action" at higher frequencies, be it from the single tone or the second component of a twin-tone, tends to blur the hump as the distortion is then transformed to broadband noise. We want the DAC to very slowly move through its output voltage range.
Actually, the best representation would be absolute level of the distortion residual (with much of the noise factored out) vs generator level.
A characteristic of the ESS hump is that after the onset of the specific distortion it remains almost constant in level... up to the point where the more regular distortion (H2, H3) finally takes over in absolute level.
THD vs Level looks like this, shape is very similar to IMD vs Level (but not IMD+N vs Level):
MC_RME
IMHO THD deeply buried into the noise (means in the FFT plot you can't identify the harmonics visually) should not give 'valid' THD results. For example lower level parts of the yellow curve could be dashed, so it becomes clear the shown value is whatever, but not clearly identified THD.
pkane
pkane
North-East
Good point, Matthias. But we know how to dig deeper into the noise floor, so I reran the same THD sweep with 1M FFT and 64 averages. The result is substantially the same, with maybe slight differences just below -55dB.
I should probably rerun the sweep with the APU notch filter to eliminate any influence of the ADC.
Guy.Cohen
My AK4499 shows that APU+SCALER into EIDA COSMOS almost the same as SCALER into EIDA COSMOS. I know the AK4499 has no HUMP but I think you will get the same results with adding the APU.
Once you get it maybe you overlay the two cases.
Thanks,
Guy
Sokel
In the "retry" feature,I think it would be better not to ask if it's set at zero.
Measuring my x-over for example the threshold is way higher that 10db when entering the filter territory and I have to confirm in every step that I don't want it to retry (0) times.
pkane
pkane
North-East
Ah, that's a bug, thanks! When the number of errors equals or exceeds retry count, MTA will ask if you want to continue to retry to give you a chance to correct whatever issue may exist in the system and to continue. Unfortunately, when retries is set to 0, any first large error will trigger this message. Not quite what I intended :) I'll fix that.
pkane
pkane
North-East
Thanks,
Guy
THD sweep with the E1DA APU notch is looking very different, with almost no hump and much lower THD:
Guy.Cohen
Notch without the scaler. I think the difference is the interaction with ADC. The notch eliminates ADC THD effects.
Also sounds reasonable. In my case the scaler alone achieves the scaler plus APU. Almost the same.
pkane
pkane
North-East
Another week, another update :)
This time, it's the preview version 1.1.9: https://app.box.com/s/ue7ll9xmvwogst817x2l1xg09opvgy47
A few fixes, enhancements, and some new features added:
  1. Add: spectrum range display shows min and max values for all frequencies when spectrum is computed from averaged data
  2. Add: IMD+N variable to Level and Frequency sweeps
  3. Add: color selector property for 3rd measurement in Level and Frequency sweeps
  4. Add: option to position distortion panel on the left, in the center, or to the right (default)
  5. Add: line color indicators next to the Show 1 and Show 2 checkboxes are now clickable so you can change colors directly there, without opening the properties sheet
  6. Fix: color indicators are now shown on start up (previously were invisible until first measurement)
  7. Change: added automatic driver refresh on any audio device change (was previously disabled because it caused intermittent hangs)
  8. Add: various useful settings to both sweep property sheets
  9. Fix: in sweeps retry setting of 0 will no longer display a prompt when a large error occurs, effectively disabling retries
Details
1. Show signal swings around the average value in the spectrum plot. Lets you see how far the amplitude of each frequency deviates from the average during the whole capture. This will not be shown if average number is set to 1.
2. IMD+N is like THD+N, except it combines intermodulation and noise. This is similar to the measurements made by APx analyzers
3. Setting to change the color of the new, third variable in sweeps:
4. Panel Position setting on Spectrum plot. Possible values are Left, Center, and Right (default)
5. You can now click on the color indicators at the top to use Windows color selection dialog for plot series 1 or 2
7. The list of drivers in both, in and out drop-down lists will automatically update when audio devices are added, removed, or their properties changed (sample rate, bit length). Please test this, especially if you have a lot of ASIO devices. I'm hoping that I found the way to avoid the hang that would occasionally result from driver updates.
