Rantapossu
- Joined
- Jul 21, 2022
- Messages
- 528
- Likes
- 377
Changes in 1.1.10
- Add: Noise floor display in Spectrum plot selected by ‘Show Noise Floor’ setting
Thanks!
There's a minor bug:
If you first activate the noise floor line and then the error graph line, the noise floor line disappears. It won't come back even if you deactivate the error graph, you'll have to manually refresh the screen. The screen capture function does the same when using the noise floor and error graph lines.
It works correctly if you first activate the error graph and then the noise floor line. It works too ok if both lines are actived before the measurement.
