brandall10
- Joined
- Sep 10, 2019
- Messages
- 307
- Likes
- 364
If my speakers actually worked i would respond.
As soon as i receive replacement parts i will see what effect MC2 has
What's broken?
Can you tell us more about the issue?My guess after days of diagnosis is a bad wifi receiver transmitter in one speaker. One works ok.
The drop in sub bass helped a lot (9db less distortion in that area). But the rest is overall worse all the way...
Isn't that choide (deeper bass, more distorrion / less bass, less distortion) already among the factory settings?Not worth upgrading in your opinion? Is trading distortion in the bass for distortion higher up a good thing?
It could. The sub bass distorsion was waaay too high (pretty close to the fundamental) in the previous tuning. The distorsion in mid frequency is less an issue (when you look at the scale).Not worth upgrading in your opinion? Is trading distortion in the bass for distortion higher up a good thing?
Anyway, I like the sound out of the MasterTuning 2.0. The auto-standby each 20 seconds of silence...not so much.
Well, you should.I'm just nervous about bricking the hub with a firmware upgrade.
Well, I'm now on the latest hub firmware and MT 2.0. Not sure I can hear the difference yet as I think I deafened myself in the process!
The Buchardt README file does warn you that the hub will set volume to 100% during the update process, but I didn't expect my music to automatically resume when the hub came back on after I paused it. Unsure what damage I may have done to my ears (listening distance = 1m) or speakers at this point.
Re-measured with all of them.They just released the LLE adjustment variants... one with it significantly reduced, one without it entirely.
However, I noticed that the "No LLE" showed the best distortion behavior at 85dB:
It definitely is.it's overall frequency shaping for fletcher munson.
Is this a 2-way or 3-way?The regular Stock Tuning 2.0 still sounds stellar to me.
2.5 way.Is this a 2-way or 3-way?
