Buchardt S400 Speaker Review
Streamc
What the point of passive A500? Can it go deep to 40Hz like real A500?
Chromatischism
33Hz -3dB? Do not believe. There is measurements. Even in room
With or without EQ, doesn't matter:
You can see it clearly at 33 Hz.
testp
New S400... looks like Buchardt's have read what Amir measured and are adding bracing inside the cabinet's which are now even little bigger + lower crossover freq. + better crossover parts. Nice!
Chromatischism
Buchardt didn't need anyone's measurements – remember, they have access to a Klippel NFS and were one of the first to publish their own. But, the changes are mainly centered around the new woofer and new crossover, and a cabinet volume change that was probably needed for the new woofer. The larger cabinet then needed bracing.
Booker
RMW_NJ
I wasn't aware of this upgrade. I wonder what measurable differences can be expected in performance?
I asked Mads and he said the measurements on the S400 SE page are for the new crossover. It looks slightly different than the old version with the 2670hz crossover point. Would be nice if there was an economy version without the high priced Jantzen Z Caps.
One thing I don’t understand: I believe Buchardt had made the comment that they raised the crossover point to 2670hz because they had gotten a few tweeter failures at the original, lower crossover that was used on the very first batches of the S400. I’m interested what changed that now allows them to use an 1800hz crossover on the MKII and 2000hz on the SE crossover.
Rick Sykora
Stow, Ohio USA
That is quite a markup on that crossover upgrade too. $750 before shipping!
For not much more. could make it an active design and would be a true upgrade. :)
RMW_NJ
It doesn't look like the circuit has been changed--just "better" parts. I wouldn't expect any measurable differences.
They claim in the notification email that it’s a newly revised crossover with a lower crossover point than the original. Don’t know how much audible or measurable difference that actually will make.
thewas
Are the nominal RLC values the same on both?
Reactions: ENG
xarkkon
Looking at the 2 crossovers, there might be some visual minor differences between the circuit. The upgrade looks like it has 1 less resistor and 1 less inductor compared to the standard one. (Picture of the upgrade from Buchardt's site. Picture of the normal crossover found randomly via google)
617
Somerville, MA
I know the waveguide boosts low end efficiency but I was always skeptical of the ability of that sb19 tweeter to do 1800hz. I think I asked mads about it and iirc he said that their testing allowed plenty of output but still. That tweeter was not designed for a two way.
Of course 90s audiophile speaker companies were probably doing two ways with first order crossovers with hiquphons so what do I know.
2670 is a much more reasonable crossover point. This unit has an Fs of 980hz.
Dennis Murphy
It's possible. I was just going by the lack of any mention of a circuit change in the factory write-up of the upgraded board.
