Buckeye 3 Channel Purifi Amp Review
Rate this amplifier:
    Votes: 19 6.9%
    Votes: 66 24.1%
    Votes: 151 55.1%
    Votes: 38 13.9%
EJ3
James Island, SC
I like that too. @Buckeye Amps, Dylan you really should get a voltage divider made from precision resistors and a good ADC so you can test gear yourself. It's next level stuff and you need them. :D I am pretty sure one of the peeps here @ ASR with a setup can help you out in getting setup. :D I would assist but I don't have a ADC with probe setup and so I'm not 100% familiar with the stuff.
EDIT: You could even include a test screenshot printout with each amp that you sell. It's a nice touch.
Yes, like some engine builders provide a DYNO sheet of the actual engine you ordered.
DWPress
MI
I own a Buckeye 4ch Hypex NC252 amp, serial number 02. Have been happy with it from day one, even happier now that I see Dylan going to such lengths to keep his customers content and his own integrity intact.
pma
Prague
The speaker outs on the input board use FastONs
We actually did modify a board yesterday to move the FastON's off/away from the board but no change in distortion during testing.
I asked because I could see the distortion rise above 10W in almost all of your amplifiers, even in NC252MP based amp. I also have a NC252MP based amp and cannot see it:
I found this, that’s why I asked.
Doodski
When was this pic taken? Was it at the beginning of production or middle or closer to the now. I was going to critique it but if it is a old production unit then there's no sense in critiquing the assembly.
pma
Prague
I suspect something with steel. In the post #1, we can see H3 much higher than is normal for Purifi module. It is 5W/4 ohm measurement. I also think about the sheet metal case. @Buckeye Amps , have you tried to measure a module out-of-the box?
amper42
You wait three month for a Buckeye Purifi. Next, the ASR review is released showing it's not up to snuff. What a bummer. I can't imagine this is easy on Dylan either. If it was possible for the ASR review to launch before shipping that would be nice. :cool::facepalm:
mdsimon2
Detroit, MI
Link below has internal pictures of the Buckeye Purifi amp. Setup is a bit different as there is a dedicated input buffer board as mentioned elsewhere in this thread.
Also thread below has prelim testing of the Buckeye Purifi amp that shows the same elevated distortion at higher power output as Amir's review. It initially appears like the higher distortion onset starts at higher power output than Amir's review but I think that is because the measurement rig is higher noise.
Michael
Buckeye Amps
Regarding the case: it is aluminum (just an fyi).
The picture posted of the XLR with the FastON tab is from my very first iteration of my Hypex build back in 2020.
The Purifi build buffer board uses board-mounted XLRs (same with the input board I use on my Hypex builds now).
Internal pictures can be found on my website.
dscottj
You wait three month for a Buckeye Purifi. Next, the ASR review is released...
That's literally me. I got mine a little more than a month ago after placing the order in late August. That said, while I'm concerned I'm not mad or even disappointed. OEM has promised a fix and has been extremely responsive almost from the moment this came out. In a weird way I'll be looking forward to a board fix if it comes to that because it'll give me an excuse to take a screwdriver to it.
I'm quite sympathetic to Dylan. This must've been one hell of an unwelcome Christmas present. Not as unwelcome as that Michigan game of course, but still!
Bruce Morgen
In my experience, even the cheapest imaginable Fastons aren't ferromagnetic at all and therefore not made of "steel." That even goes for the ones found in "home handyman" assortments from Harbor Freight, a very "bargain basement" chain of tool emporiums here in the U.S. -- even a neodymium magnet can't attract them. Moreover, when you start blaming tiny bits of steel in an amplifier's output circuit for measurable distortion at the relatively low frequencies involved in audio, you're pretty much in Danny Richie audiophool woo-woo territory.
pma
Prague
Base material of faston terminals is either brass, or phosphor bronze, or steel. Depends what you purchase.
DSJR
Suffolk Coastal, UK
I owned NAIMs since serial nr 002 on some models and I have no idea what you are saying? What on earth is a “banana shaped rectangular sleeve?”
Post 1980, the construction was a U shaped tray slid into a cast rectangulart sleeve (CB and Olive versions). Said sleeve rang like a bell, so Nail fitted a little plastic 'strip' over the rear edge of the inner tray which on completion, was pushed into contact with the sleeve to reduce the clanky rining noise it made. Most of these castings weren't fully 'straight' and 'true' either, hence the 'banana' remark. I had a now deceased pal with six NAP135's and a NAP250 from a previous system (he didn't sell anything) and four of the seven cases weren't properly straight! The current cosmetic style post 2000 is rather better but the matt finish can hide a multitude of case flaws apparently.
pseudoid
Thank you, Amirm,
1kHz test tone for THD measurements seem so arcane.
Wouldn't an automated sweep be more representative of the EUT performance?
Your 2nd to last graph comes close...
Urvile
Seattle
Sigh...
"While probably not an audible concern, it is nevertheless a blemish on the otherwise near perfect performance of the Purifi modules."
I believe Dylan when he says that it's not audible, otherwise I can't imagine he would have shipped even one out. He's been incredibly transparent and helpful.
I respect that Amir found a bug, didn't hide it, and reached out to Dylan. I wish he could have tested if it was audible, and if not, made it a caveat, instead of not recommending it. And worked with Dylan to test whatever fix that is needed.
I ordered one and it's shipping on Monday, my expectation is that it's not audible , and that Dylan will have a fix. (Consider there are many that are in the hands of customers already, and if audible would have posted something)
I have no regrets other than the grief this may give Dylan.
sarumbear
It’s interesting how you explain a case like this to “ring like a bell” or looks like a “banana.”
_thelaughingman
I’m glad that the community here is sensible with their responses and approach to this review. We obviously hold a standard for transparency at ASR and to see Dylan from @Buckeye Amps provide a transparent response to the minor shortcoming of this amp is refreshing and endearing. Glad to see that Amir and Dylan have a good working relationship, which benefits the majority of the ASR community. @Buckeye Amps I do feel bad that this minor blip will be a source of pain for now, but there’s nothing but success from here on out for you.
Buckeye Amps
I also want to make sure no one mistakes me saying the problem is likely inaudible as me trying to say "this is not an issue"
A mixture of objective reasoning and subjective listening (as I use the same amp and am very familiar with how my setup should sound) points to this not causing an audible or noticeable impact to the consumer. I would be very surprised if someone A/B'ed their amp pre and post fix and heard a real change/improvement.
BUT that does not mean this is not an issue that shouldn't be addressed. I know sometimes people can use the scapegoat of "you won't hear it" to defend measurement shortcomings. Definitely not what I am trying to do (I think that is obvious).
Fahzz
Outside Providence
Your commitment to your product is obvious, and you have a lot of supporters and "helpers" here apparently. This will get sorted. Enjoy your holidays, and congratulations on your degree.
