- Joined
- May 28, 2020
- Messages
- 1,703
- Likes
- 6,708
I have a strong feeling it will be a moot point soon
I received one of your two-channel purifi amps a couple of weeks ago. Are you going to send out a replacement part? Should I even bother "fixing" it if it's inaudible? I guess it would help resale value for picky buyers.I have a strong feeling it will be a moot point soon
Yes in response to sending out replacement part. Just waiting to test a couple of options and set up logisticsI received one of your two-channel purifi amps a couple of weeks ago. Are you going to send out a replacement part? Should I even bother "fixing" it if it's inaudible? I guess it would help resale value for picky buyers.
Please let us know when it is fixed! I assume you will send a revised amplifier to Amir for testing?This was not expected and was not an attempt to have a known/flawed product pushed through review.
While we did robust testing during development and prototyping, I cannot account for why this issue was not identified or observed early on. But I do take full responsibility.
As Amir briefly acknowledged, now that we are aware of and able to reproduce the issue on our end, we have been testing furiously to identify the exact cause so we can produce a fix.
Transparency and communication with the community has been one of the "pillars" I've tried to build my business upon. As soon as we identify the exact issue and the appropriate fix, it will be implemented ASAP, including for current customers as needed.
BrassWhat material is the new tab made of?
It’s definitely fixed and yes, a new 3ch is being sent back to Amir for testing.Please let us know when it is fixed! I assume you will send a revised amplifier to Amir for testing?
Indeed! Best possible outcome for all involved. And contrary to the suggestion above, your forthright communication, ownership of the issue, diligent efforts to correct it, and offering a fix to everyone with an early unit should serve to bolster your reputation and instill the utmost confidence in those who choose to purchase a Buckeye. My hat’s off to you, sir. Cheers and well done.I have a strong feeling it will be a moot point soon
It’s somewhat on my radar, though I am a little reluctant since I myself find it very difficult to recommend spending extra money on Purifi amplification for surround sound channels.Dylan, any plans to build a 5 channel Purifi - can it fit in 1 case?
Cheers Al
A lot of people listen to multichannel music and in those cases, the surround channels are not bandwidth limited and are losslessly compressed and deserve as clean an amplifier as the front channels, IMHO.It’s somewhat on my radar, though I am a little reluctant since I myself find it very difficult to recommend spending extra money on Purifi amplification for surround sound channels.
I could see use case for critical multi channel music usage...but that's about it for me in terms of 5ch Purifi recommendation.A lot of people listen to multichannel music and in those cases, the surround channels are not bandwidth limited and are losslessly compressed and deserve as clean an amplifier as the front channels, IMHO.
In fact, most Blu-ray and UHD content offers lossless compression for all channels.
If we are talking garden variety Dolby Digital or DTS, those employ lossy compression schemes. If we are talking Dolby Pro Logic, the surround channels are bandwidth limited. But those are older formats.
I guess what I am trying to say is that the days of treating surround channels like second-class audio citizens have long passed!
Well, unless you are talking streaming . . .
I have 2 individual 20 amp circuits (serendipity by the designer/home builder in 1968 that happen to meet my needs when I moved in in 2022) near my stereo gear.I'll let Dylan correct me if I'm wrong but 5 channel Purifi would require a different or dual power supply. The one in 3-channel amp is already maxed out.
I was torn between ordering 3 channel or 5. My setup is 4 full-range towers and a fairly large center channel, so I went with a 2+3 channel amps.
The amps are stacked on top of each other, as they don't get hot at all. The only nitpick I have is the difference in their sizes. I'll take and post pictures later.
If I were to do it again, I would have asked Dylan to build the 2 channel amp inside a 3-channel enclosure. This way both amps would stack nicely.
Different volume levels is just a matter of gain I believe. Most Emotiva amps have a gain of 29dB (1.6v to reach max volume) and the Purifi is between 15-25 depending on the setting set at.FWIW, someone just posted a video review on YT.
TL;DW he experienced lower speaker levels than with the Emotiva he came from but was pleased by what he heard.
My thoughts exactly and commented the same on his video. If I understand Amir's review, the Buckeye requires around 2 volts at high gain for full power.Different volume levels is just a matter of gain I believe. Most Emotiva amps have a gain of 29dB (1.6v to reach max volume) and the Purifi is between 15-25 depending on the setting set at.
I like the 5 CH idea for simplicity for someone who just has a 5.1 setup.... For me i would prefer my LCR+ side surrounds with the same headroom.It’s somewhat on my radar, though I am a little reluctant since I myself find it very difficult to recommend spending extra money on Purifi amplification for surround sound channels.
