Buckeye 3 Channel Purifi Amplifier Review (2nd)
Rate this Multichannel Amplifier
    Votes: 3 1.1%
    Votes: 5 1.8%
    Votes: 24 8.7%
    Votes: 245 88.4%
This is a second review of the Buckeye 3-Channel Purifi based balanced class D amplifier. First sample had an issue with its binding posts increasing distortion. It costs US US $1,595.
Buckeye 3 channel purifi amplifier class D amplifier Multichannel Review.jpg
Typical of Buckeye amplifiers, focus on what is inside rather the case which is utilitarian. An indicator nicely shows status of the amplifier (on, fault or overload). Back panel sports a 3-way switch for setting the gain which is very nice to have:
Let's get right into the measurements to see if the issue with distortion is resolved (I ran full suite of tests).
Buckeye Purifi 3 Channel Amplifier Measurements
Let's start with our low gain dashboard:
Looking at the spectrum of the FFT we see a large reduction in harmonic distortion compared to the first sample. SINAD as a result improves a bit although it is mostly noise limited. Still, we match the reference design, landing the amp solidly in our top 20 best amplifiers ever measured (out of over 200):
You need pro type interface to drive the low gain to full power (as much as 7 volts for 4 ohm). Fortunately high gain hardly brings any penalty:
Request was made to show power with reactive loads as opposed to just resistive as is the norm in my reviews (and industry). Using my new PowerCube loadbox, I can do that:
Buckeye 3 channel purifi amplifier High Gain balanced reactive measurements.png
Capacitive load doesn't change things but inductive loads it down a bit more. SINAD remains more or less the same so really, nothing of worry.
SNR is the same as before and excellent:
Frequency response is flat as always: (should say "NO load impedance dependency"
Buckeye 3 channel purifi amplifier Low Gain balanced Frequency Response measurements.png
Oh, forgot to mention that I am testing channels 1 and 3. Due to larger distance, crosstalk is even better now (and was incredible before):
Buckeye 3 channel purifi amplifier Low Gain balanced Crosstalk measurements.png
Multitone shows an improvement of 2 bits:
Buckeye 3 channel purifi amplifier Low Gain balanced Multitone measurements.png
Let's dig into power measurement where we saw the rising distortion before:
Buckeye 3 channel purifi amplifier Low Gain balanced Power 4 ohm measurements.png
Performance is far improved. No longer do we have a large hump in mid-power region. There is a small increase that exists but we can ignore it:
Buckeye 3 channel purifi amplifier Low Gain balanced Power 8 ohm measurements.png
Power remains as before:
Buckeye 3 channel purifi amplifier Low Gain balanced Max and Peak Power 4 ohm measurements.png
Buckeye 3 channel purifi amplifier Low Gain balanced 3 channel Max and Peak Power 4 ohm measur...png
Here is the warm up behavior:
I didn't re-run the on/off pop test. Should be the same as before (which was very good).
Reactive Load Amplifier Power Testing
Let's use our fancy Powercube loadbox to simulate both capacitive and inductive loads ranging from 8 down to 2 ohms (amplifier goes into protection with 1 ohm):
Buckeye 3 channel purifi amplifier Low Gain balanced Reactive Power measurements.png
(ignore the color differences.) Response is perfect. Regardless of load impedance down to 2 ohm reactive, the amplifier maintains the same output voltage. Can't ask for more.
It is great to see such responsive companies such as Buckeye that take the results of a review and instantly jump on the issue identified to resolve it. And resolve they have. Performance is essentially identical to Purifi reference design. Value added is provided in the form of a 3-gain buffer stage and powerful power supply that allows all three channels to produce near full power when driven simultaneously. Results is one of the cleanest/most transparent multichannel amplifiers you can buy.
I am happy to add the Buckeye Purifi 3-Channel amplifier to my recommended list.
AdamG
Moderator
Reality
Home run Buckeye! Awesome and demonstrates how a vendor can work with ASR to further refine and improve their end product to the customer. Knowing exactly what you are paying for and getting via this relationship is a huge benefit for our Members and Readers. Win/Win. Nice follow up evaluation Amir.
All for less than a cup of free coffee. :cool:
So who is getting the one with bad binding posts that requires measurement equipment to discover? QC is something to have.
As far as I know, he has retrofit any that were sold with the old binding posts although there may not have been many shipped that way.
AdamG
Moderator
Reality
Honesty in the Audio World! And in my lifetime no less. :oops:
JktHifi
More channel, more noise/distortion. Is it right?
Previously the 8-channel from the same brand got SINAD 90dB.
Or, less signal because more channel?
{\displaystyle \mathrm {SINAD} ={\frac {P_{\text{signal}}+P_{\text{noise}}+P_{\text{distortion}}}{P_{\text{noise}}+P_{\text{distortion}}}},}
MaxwellsEq
I remain astonished at how significant the impact of the binding post's material was on the original unit. This is such a valid demonstration of the value of objective measurement. Well done @amirm and @Buckeye Amps
Ra1zel
Poland
Yeah so, that's why I would really like to have speakON connectors as an option
abdo123
Brussels, Belgium
Considering the recently reviewed Topping Amplifier goes into protection at 2 Ohm I find it difficult to not consider this as a superior product.
Is this already using the new NCoreX architecture?
Eetu
Helsinki
So, do you mean purifi is better than hypex? Or, is it just bad design from the 8-channel?
Yes, Purifi is a newer, more advanced design than the original NCore. There's also the next generation Hypex NCoreX / Nilai that should be an improvement over the original NCore. That being said the NCores are still very very good and at this point it's more of 'how far can we perfect it' than actual audible improvements.
Sokel
If anyone would ever claimed that such a thing as the material of the clamp connectors with the binding posts matters without evidence the least that would happened to him would be tar and feathers here.
But experience on the one hand (@pma ) and state of the art instrumentation and skilled operator on the other (@amirm ) found such a case along with the solution.
Nothing will surprise me from now on.
Thanks Amir!
martijn86
The Netherlands
No amount of advertising can achieve this level of trust in a brand. We'll done Buckeye and thanks again Amir! Very interesting to see the powercube load measurements, although I'm not entirely sure how to read them yet. Consistency is most important I guess?
_thelaughingman
Phew!!! That to me is a bang for the buck amp if i’ve seen one.
