Buckeye Amps: Hypex NCx500 Official Thread
Buckeye Amps
Buckeye Amps
@ryanosaur, Thanks for sharing your experience with the red leds on your Hypex amps.
@MicroAudio, Thanks for sharing the actual idle/standby power consumptions. 10.5 watts for 2k is pretty good. I had assumed somewhere around 12 watts based on the Hypex 1200 and 3000 SMPS idle watts
@Buckeye Amps, My question was more around power consumption when the amp is on, but not working very hard (current wattage requirements are low). I am assuming that an amp with a lower idle wattage would run cooler in that scenario than one with a higher idle wattage. I don't know if that would make a meaningful difference between the Buckeye 3 channel ET400A/NCx models, which is why I posed the question. I also think updating the design to allow true standby operation is a great update, which is a plus over the Purifi models (I assume that isn't incorporated currently). If possible I think you should try to add that feature to all of your models. Lastly, the firmware upgrade to allow standby control, can that be done by the end user or would it need to be returned to you? Do you expect that feature to be implemented by the time the next 2k MA SMPS arrive for the 2024 orders?
The feature should definitely be working for all future (and pending 2024) orders. In terms of hardware the ability is there on the SMPS and our input board. Just need to tweak the firmware.
NegativeEntropy
I currently have a Buckeye 3 channel NCx500 on order and am contemplating changing it to a ET400A model. I have a few questions hopefully some Buckeye three channel ET400A or NCx500 owners can answer.
  • There have been multiple accounts of the purifi ET400A amps running cool and the Hypex NC502MP models running much hotter. Anyone that a 3 channel NCoreX owner can comment on their experience with case heat? How hot does it get? My theater/music area is in a room over a garage and gets quite hot during the Louisiana summer afternoons and I am looking to minimize extra heat generation inside the room where I can.
    • The idle load of the 3 channel NCx500 model is reported by one user to be 38 watts while the idle loads of the ET400A 3-channel are likely to be around half that. That will help with heat generation and the low idle watts of the ET400A modules are likely why they run so cool.
    • From the Hypex/Purifi datasheets: SMPS1200 has 9 watts idle loss and the ET400A idle loss is 1.7 watts/channel so the Buckeye three channel ET400A model should have a loss of 14 idle watts.
    • Per the Hypex datasheet, NCx500 have an idle loss of 5.3 watts/channel which sums to 16 watts. Since the idle loss reported is currently 38 watts then the 2k Microaudio SMPS has idle losses of 22 watts (its datasheet from what I could tell is not publically available). That does seem a bit high as the Hypex 3k SMPS has idle losses of 15 watts and the Microaudio 2k in theory should be somewhere in between that and the 9 watts of the SMPS1200.
    • As a point of reference the 4 channel NC502MP per the Hypex datasheet has an idle loss of 53 watts (17 watts per SMPS (2) and 4.8 watts per channel (4))
  • I have seen prior pictures of the NCx500 module red LED lights shining through the case. For anyone that uses a Buckeye NCx500 amp, is this noticeable in a dark room when watching movies? I’ll probably have 5-7 inches of room between the top of the amp and the shelf above so I believe any light will be visible coming out of the vent and be a distraction.
The amp will be used to drive Ascend Acoustics ELX towers/Horizon LCR speakers. They are advertised as 8 ohm nominal, but the impedance dips down to ~4 ohms from 90-300 Hz. I don't think are considered a very difficult load (I attached the impedance chart below) They are also rated for up to 400 watts max continuous power so they could take advantage of the extra watts of the NCx500. I generally watch movies around at around -7 to -10 dB, and listen to music around 85-95 dB so from the SPL calculations I have done either model ET400A or NCx500 should work well. The NCx500 has a decent amount more wattage into 8 ohm loads which is why I initially picked it over the ET400A, but if the heat/red light leakage are significant disadvantages then I may switch to the ET400A model.
Thanks for any experiences you can share.
@LSUGopher
I have ELX Titans (LCR). Switched from class AB Outlaw 5000 with ~150-175W peak into 8 ohm to 3 channel NCx500. Relatively large room with ~12’ listening distance. Only switched because I needed 3 more channels anyway and I did not want headroom to be a potential issue.
Got the expected extra gain. Sounds great of course. Have not done much critical listening since the install, but other than some reduced hiss close in I would only expect more headroom based on the amp measurement and no other audible change.
As you noted, efficiency of the speakers is relatively low, but they are not very difficult to drive impedance wise.
Haven’t been able to do a full recalibration as I am finishing some construction in an adjacent room and stuff is everywhere so just did pink noise level matching of previous Dirac cal.
My amp is remote mounted in a rack, so can’t help with any of your other questions. Don’t regret my purchase at all.
If you have questions I can answer I’ll keep an eye on the thread.
Dr. Cyrax
Have gotten my Buckeye 3channel Hypex ncx500, got it powering my LCR from Arendal Audio 1723 THX towers, and center.
And it is fantastic!!
No hiss, only pure enjoyment.
After several hours of "non healthy" music and movie listening it is not warmer than that I can place my hand on top, no problem.
When I am doing the rest of my surround system, its going to be Buckeye amps all the way.
Thx Dyllan, for great product and great support along the way.
ViperDom
Delaware
Heyu, that info would be here:
LSUGopher
Louisiana
@LSUGopher
Thanks for your feedback. Always nice to see another Ascend Owner. I'm team RAAL :) Like you I am mainly expecting extra headroom as I am currently using an old receiver (Denon 4311, rated for 140W) as an external amp to power the LCR and have found it quite good for the past 7+ years, but am looking to retire that and hopefully the NCx will run a bit cooler than the receiver. I do like to music especially symphonies quite loud and am hoping the new amp will help with symphonic dynamics.
NegativeEntropy
It may, especially if you are not using subs or are crossing low. Guessing it should run cooler than what I assume to be class AB ams in the Denon.
Considered going RAAL of course but with 3 LCR to upgrade from NrT and 5 new surrounds to buy, it was not in the budget!
Heyu
Unless I missed it. There is no mention of dirac amps release dates.
amper42
That's a lot of questions.
If you don't want the amp to run warm after an hour get the Purifi. The watts used with the Purifi 1ET400A while idle and at lower volumes is almost half the NCx500 solution and the NCx500 amp will get warm. On the other hand, my Purifi amps stay cool no matter what. The Purifi amps offer lots of power and the best energy efficiency and heat characteristics. It's an excellent module that ages well. The Purifi will offer plenty of power for the Ascend ELX.
The Buckeye Stereo Purifi measures 14W while idle or with lower volumes in stereo. I don't have a three channel to measure. In comparison, the NCx500 stereo amp is 26W. It will heat up with 60 minutes of operation or simply leaving it on. A lot of users are going for the NCx500 design but personally the Purifi build would still be my first choice if you are looking for an exceptionally cool running amp design.
Buckeye Amps
Buckeye Amps
About 6wks or so ago, another vendor on here tried to imply that lack of certification meant there was "distrust" of Micro Audio SMPS' when Micro Audio was suggested as a proper SMPS for reaching full power output with certain amplifier modules (such as the Purifi 1ET7040SA and the upcoming Purifi 1ET9040BA). To which Micro Audio provided certifcation for the 1k SMPS currently being used for 7040 builds and promised upcoming certification for the 2kW SMPS being used in our 3ch NCx500 build.
Well, here you go!
Micro Audio 2kW SMPS Certification
I also have the full certificate on file, as well.
LSUGopher
Louisiana
Thanks, I figured the Purifi would be more energy efficient from everything I have read. I'm concerned I will have regrets if I change to the ET400A from the NCx500. Before I ordered the NCx500 I did a lot of research and between the two before ultimately deciding to order the NCx model. I should be receiving the 3XNCX amplifier shortly after Dylan receives his next batch of MA 2k SMPS's as I ordered in early January. If I feel it runs too hot then I may purchase the ET400A version to compare. However, I can't believe that 10-15 W can make that large of a difference. I suppose I will find out when it arrives.
MicroAudio
AMMAN - JORDAN
I have the NCX500 3 channels amplifier running for over 3 months by now, 24/7.
It never became hot to the level that makes it hot to touch.
Can post some thermal images if needed.
Thanks
Buckeye Amps
Buckeye Amps
As @MicroAudio posted, even if you left the 3ch NCx500 in idle indefinitely, it does not get that hot. In fact when I tested one of the rack builds in my own setup, the AC Infinity Aircom would never come on while sitting idle, even though the thermal probe was placed right next to the SMPS and the temp for triggering on was set to 84F.
LSUGopher
Louisiana
That is great news. Mine will be on 12V trigger so it won't be idling all the time, so it may run even cooler than what you saw. Thanks for the additional information.
Thanks
If you can post thermal images that would be a great data point to have in this thread for all potential owners.
MicroAudio
AMMAN - JORDAN
I will get some thermal images soon for the entire amplifier from the outside.
Thanks.
MicroAudio
AMMAN - JORDAN
Buckeye NCX500 3 channels amplifier in idle running 24/7
LSUGopher
Louisiana
Thanks for the excellent picture. I appreciate the spot temps and the temperature legend. The front panel seems to be ~15 Deg C warmer than ambient, with the top around ~10 Deg C warmer than ambient.
scotchrocks
I've had my 3 channel NCx500 installed for a few weeks now, and it has been excellent so far. I've always had issues with clarity and harshness at higher volumes when I ran my KEF R700/R600 LCR setup through my AVR's amps (Marantz SR7012). The theater seating position is pretty far back (13-14 ft or so), so I don't think the AVR had the juice to keep up with the lower impedance and sensitivity of the speakers.
With the NCx500 powering them, I can keep pushing the volume and the speakers don't seem to struggle. Even when audio levels are set higher than before, I have much less listening fatigue, probably due to less distortion. Things just sound far cleaner, particularly in the treble and upper midrange compared to the SR7012. The sound improvement over the AVR is significant enough that I'm delaying my original plans to upgrade the LCR to KEF R11/R6 Meta. I even ended up getting an NC502MP for the Atmos speakers and surrounds as well. This is definitely overkill, but it'll give me flexibility when I upgrade the AVR and speakers.
Other than the sound, the build quality is great, and I don't mind the simplicity of the case design. Heat hasn't been an issue, as it does get a bit warm but not hot when passively cooled. Regardless, I added a near-silent Noctua fan blowing on it, and with active cooling, it feels barely warm. Overall, I don't think I'll need to buy another amp for my theater setup again.
