- Joined
- May 28, 2020
- Messages
- 1,687
- Likes
- 6,634
- Thread Starter
- #41
Yes. The custom SMPS Micro Audio is manufacturing for us will take some timeIt says on your website that the 3 channel amps will ship early Q3. Are we talking july?
They do not make amps, but they do make many different models of SMPS'Does Micro Audio make SMPS amps for mono configuration?
Not that I have heard off.Any such thing as a NCx250 coming out soon? More power for the same cost as the NC252 etc.
Not for a while. I can probably get one sent towards end of MayAny feedback as to when you might have a mono unit for Amir to test?
The original terminals were steel (so magnetic) as opposed to what was listed as brass (non magnetic) when I ordered them.I’d like to ask a question that’s been bubbling in the back of my head ever since the testing and re-testing of a Buckeye amp by Amir. I don’t think I’ve seen the answer in the test/review threads, apologies if I missed it.
The first round of testing of the amp showed increasing distortion from a certain output power onward, and this was confirmed as fixed by the second test. The fix that was alluded to was about the speaker terminals.
What I would like to know is, what was the problem with the original terminals? Was it the type or style of termination? The clamping force? The cross-section of the post? I’d like to understand how a terminal can introduce current-dependent distortion, other than (obviously) through poor contact.
@Rick Sykora did a deeper dive into this issue and if he is willing may be able to explain better what is happening when using a ferrous material.Ah, I see. What is the presumed mechanism of action for causing the distortion, though? Does being ferromagnetic affect the flow of current through a material? I would have thought that if anything, a higher conductive material (like copper or brass) would be more affected, for example through eddy currents.
I know that when there is sufficiently high magnetic flux in a ferromagnetic material (like in a transformer core) one can get crackling Barkhausen noise, but surely that’s not what we see in speaker terminal posts?
Did not delve into the physics of it, but some smart folks at Purifi claim that hysteresis distortion can occur when iron is in the signal path. The distortion also reminded me of what happens with an oxidized contact. Ran this by some experienced electrical engineers I know and they said a good solder connection should resolve. I tried this with the steel tab and it did not fix.
It's complicated, and I claim no expertise as it has been a while since I have dealt with this (though have spent a lot of time dealing with the effects of ferrite beads in RF and power supply circuits). It is not (or not just ) Barkhausen noise, but actual distortion (nonlinearity) that is added. IIRC, ferrous materials introduce nonlinear effects on current flow including hysteresis. The effects are small, but at higher current are enough to add distortion, especially when we are looking at the very low distortion levels here. In the real world, as @Rick Sykora noted, similar (e.g. voice coil/magnet modulation and hysteresis, etc.) and other effects (e.g. other hysteresis, nonlinear suspension flexure, cone breakup, etc.) from the speakers will dominate the distortion you hear by several orders of magnitude.Ah, I see. What is the presumed mechanism of action for causing the distortion, though? Does being ferromagnetic affect the flow of current through a material? I would have thought that if anything, a higher conductive material (like copper or brass) would be more affected, for example through eddy currents.
@Buckeye Amps
Do you have the specs for the 3 channel Micro power supply? Can you give it's current rating at max output per channel at 2ohms? Thanks...
Sustained power is 1.8kW @ 120VAC / 2kW @ 240VACSome detail on sustained power would be useful too
Peak power is 2kW @ 120VAC / 2.2kW @ 240VAC
