- Joined
- May 28, 2020
- Messages
- 1,703
- Likes
- 6,719
- Thread Starter
- #1,521
I also use them on my stove/microwave clocks (since my theater room is open to my kitchen)Ordered. Thanks!
Ya, they are going on a few things! The emotiva et-3 as well as some switches, modem, and smart home hubs....too many brightblinking lights!I also use them on my stove/microwave clocks (since my theater room is open to my kitchen)
Oh man, those subs are huge! I really like the shelf arrangement that puts the MTM center speaker vertically to minimize lobing.Got everything set up now with the buckeye amps, the htp-1, and the philharmonic speakers. Everything sounds so good and these amps drive everything very easily! I'm glad they were part of the upgrade for me! My dog, moo, also approves!
Now just waiting on those stickers to cut the intensity of that blue light some!
Haha, Ya, 18" subs in 4cuft boxes. Stereo integrity ht18 v3's.
I just made that shelf for that exact reason. I was gonna lay the bmr monitor horizontal, but we wanted a new media stand anyway. So decided to make one that works with a vertical bmr as a center. The bmr is a 3 way so it would have been OK horizontal, but not nearly as good as vertical.
The flexy shelf gave me everything I wanted. I thought about just doing wooden dowels, but this way I didn't have to measure and can level everything easy.Nice to see that flexiracks are still in style.
Interesting finish on the shelves, almost stone-like. What did you use?
Phew, that sounds like a lot of work.The finish was the following. Stained them with minwax water based slate gray. Then a dry brush white. Finally min wax polycrilic gloss on top of all that (5 coats of it).
About a weeks worth. Cutting took about a half day. Prepping surfaces a couple of hours.Phew, that sounds like a lot of work.
Glad you enjoy it.
OK, working on some case revisions. Vertical alignment of speaker binding posts or a slanted orientation (see attachments)?
So you mean slant them more so they use all of the space above each connector horizontally?Slanted but centered left to right wrt input connector.
I was thinking to shift them right but your idea might be better.So you mean slant them more so they use all of the space above each connector horizontally?
Yes!So you mean slant them more so they use all of the space above each connector horizontally?
The distance between the + and - of a binding post pair is exactly 19.2mm (same as it has been on all my cases).I suggest you maintain the proper spacing for dual banana plugs. (19.2mm?)
Yes.OK, working on some case revisions. Vertical alignment of speaker binding posts or a slanted orientation (see attachments)?
