CHORD M-Scaler Review (Upsampler)
Rate this product:
    Votes: 358 88.2%
    Votes: 13 3.2%
  • 3. Fine (happy panther
    Votes: 7 1.7%
    Votes: 28 6.9%
Music1969
It was paired with Chord DAC, the Hugo 2.
Can you redo full Hugo2 measurements?
You did it long time ago right after getting your AP
I imagine you're testing is better now than then
MZKM
Land O’ Lakes, FL
Let's go back to basics and see if the M-scaler is doing what it is supposed to be doing by running our filter test with the D70s:
It is indeed. Both 2X and 4X modes provide an ultra sharp response. However they do so at the cost of higher noise floor/lower attenuation.
Shouldn’t it be labeled 48kHz?
theREALdotnet
Interesting that the M Scaler appears to produce jitter. That might make it a worthwhile addition to a test bench :)
Interesting too that the D70 seems really bad at handling that jitter, I thought jitter rejection was what makes a good DAC. Unless I’m misinterpreting the results.
ayane
NorCal
300dB? As in 1E15
It's literally impossible to have SPLs higher than 194 dB in air at sea level. Sound is longitudinal, so the rarefaction of those waves can't get lower than vacuum pressure. There will be shockwave distortion.
More importantly, SPLs that high will result in instant death.
Bonus: the noise floor of air is about -24 dB SPL, so even the maximum possible dynamic range doesn't get anywhere close to 300 dB.
don'ttrustauthority
I don't find it takes any time to become familiar with the light scheme on the Mojo2. After a few hours with it I had it figured out, including the graphic equalizer which operates on some combination of the buttons and colors. Really is a simple thing to master. $700 for a dac/amp is a lot, and it didn't perform as well as desktop gear to these ears, but it did drive the DCA Stealth fully without balanced outputs, so there's that.
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
His claim is that he can hear distortion at -300dBfs, or something like that if I remember right.
I'm not surprised it doesn't do anything audible, but I am surprised it isn't a good performer (in a measurements sense), for what it is supposed to be, if that makes sense.
Doodski
Good to read that there is some logic to the controls layout. The premise that I have for detesting the system that CHORD uses is it should not require any learning curve to speak of and it is a cost saving measure that eliminates the usual display and controls that would be associated with a proper and functional system. CHORD is cost scrimping on a high end unit.
Matias
São Paulo, Brazil
And for reference, the Shoutometer.
Blumlein 88
To be even more fair, I think his claim is to hear differences in filters that only differ at the -300 db level. Or so I recall without going back to listen to his talks. But yeah, he might as well say -1000 db for all the credibility it has.
I do disagree on this device with others. I think it is attractive. A very pretty piece of gear. Too bad it is somewhere between making no difference, and making a difference for the worse.
Doodski
He really did step into a big cow pie when he made that -300dB level claim. :facepalm:
