Close-back setup
O
Ole_S
I am the kind of person how loves trying and buying new stuff.
Therefore, I think it would be a good idea to by an AMP/DAC for the future. If you understand nu.
O
Ole_S
Another option has just appeared.
In Denmark I can buy an almost new Topping DX7 for 335 EUR.
Is that an overkill or a great bargain?
Jimbob54
Which version of the DX7? How old?
Also, slow down, listen to the kit you have and enjoy something. Buying isnt listening and enjoying music.
O
Ole_S
It is not the "+" version.
But I just want to buy the "right" setup.
And I am not in a hurry.
Jimbob54
If I recall correctly that model has relatively high output impedance and could impact how some headphones sound. But you have an e50/L50 stack coming dont you. I would try those with UAPP with EQ on your phone.
O
Ole_S
Yes, but the E50/L50 is overkill. Right?
I am a little surprised that you do not recommend the DX3 Pro+ for my setup.
You might have your reasons.
Jimbob54
Ummmmm...
Like I say- slow down a bit
O
Ole_S
Ummmmm...
I am slowing down?
As I said: I am not in a hurry.
But I would the to get best out of my system. Sorry?
O
Ole_S
I'll keep E50 + L50 and buy a bluetooth AMP/DAC = QUDELIX 5K
O
Ole_S
I am curious why choosing K5 over Topping G5?
Topping G5 is more powerful.
And if this device is for both desktop and transportable.
O
Ole_S
Qudelix 5K only = 129 € for the total setup is what StaticV3 is trying to tell you.
It will also give you EQ possibities, have enough power and can be used as desktop as well (via USB) and can be used portable.
You will be lacking 2 separate boxes, display, power supplies. Your wallet will thank you.
You may want to buy a balanced cable for the Sundara (Pentaconn 2.5mm TRRS).
The Qudelix will be enough unless you want to remove the fillings from your teeth.
Hi,
I know absolute nothing og Hifi-cables.
Sorry.
Can you please send a link to the cable, you are mentioning?
That would be a great help to me.
Thank you.
solderdude
The Neitherlands
Use the headphone with the current cable.
When you need to go any louder then start shopping for a cable with the 2.5mm balanced plug.
O
Ole_S
You wrote this:
O
Ole_S
It sounds great to me
solderdude
The Neitherlands
Sundara is 3.5mm TRS where T and S are connected.
The 5k is 2.5mm TRRS
2.5 TO 2x3.5
Try the Sundara on the 3.5 output first. You may not need the balanced output.
