Crown XLS1002 Pro Amplifier Review
matgir99
seems a fine amp for subwoofers, you get plenty of power and between -110db and -120db up until 90 hz
PeteL
The Ncore design is fundamentally a self oscillating PWM amplifer, which makes it intrinsically difficult to see how it could work with a fixed period sampled digital input. Not impossible, you can, in principle, shift any part of the topology into the digital domain, but within the bandwidths and computation limits, pretty difficult. I'm not sure how they might use an ADC in the comparator except that in some sense a comparator is a 1 bit ADC, although the comparator in the Ncore amplifier is a zero crossing detector, which is not quite the same thing as a simple level comparator. There are other places in the amplifier where some digital control is useful, most certainly in the protection circuitry, and maybe control of the forward filter could be effected, which would be central to the Ncore design.
The basic Ncore patent is well written and worth a read.
Combined DAC/PWM devices certainly exist. Of note for ASR denizens is the beloved JBL LSR 30x family, that uses the STA 305B for the entire digital chain, from digital in, DSP, and power amp. Not exactly a high end chip, but the end result in the loudspeaker does not seem to generate complaints about fidelity. There is no definable DAC in this chip that is separate to the power amplifier, and one might indeed characterise it as a power DAC. But an Ncore it certainly isn't.
The Ncore plate amplifiers are available with DSP, they include a conventional DAC feeding an analog signal to the amplifiers.
Thanks. I was reffering to this, but I incorrectly assumed it applied to Ncore
https://www.researchgate.net/public..._PWM_Switching_Amplifier_with_Global_Feedback
Francis Vaughan
Adelaide Australia
mhardy6647
So you've got moles, deer and groundhogs. We've got possums, wallabies, bandicoots and cockatoos. We've just given up trying to grow anything. Even herbs. You go out one day and you have a nice big basil plant. Next morning, nothing but dirt in the pot. And that was 30ft above the forest floor on our back deck.
Plus, you all have the broadest distribution of poisonous species in the world. Up here, pretty much nothing that will actually kill you (without good reason, at any rate).
Panelhead
Are you saying there's a difference between the 1002 and 1502 other than the power output level? Cost-wise is $60-$100 upgrade.
The main differences between the four XLS models. As features are added they move up to the next model. And of course power ramps up.
XLS-1000 Base
XLS-1502 Improved Drive Core circuit
XLS-2002 Paralleled (x2) Output Devices and Filter cap banks
XLS-2502 Higher rail voltage
For current delivery the top two models are more capable.
stunta
Boston, MA
I use this amp for my surrounds. I haven't even tried comparing with NCore - if I can tell the difference between the two amps on a movie scene on my surrrounds, I would be so surprised at myself I would die of heart attack. This is a great value IMO.
oldsysop
It would be interesting an analysis of a real equipment, like the crown macro tech 3600.
No, I don't have one to send.
Dj7675
I’ve been using the xls1502 to power a JBL B460 sub (2245 driver). My only comment is some hiss. I sit fairly close to it and the driver sensitivity I believe is 90 both which makes things a little worse. I will probably replace it and see if I can eliminate it at some point.
Jdunk54nl
Arizona
What type of connection are you using?
If you remove it, does the hiss stop? Mine does this with an rca connection but when removed its silent. I also found that if I set a low pass filter on the crown amp, the hiss is greatly reduced, even if I set the low pass to its max 3000hz (iirc that is the max)
I ordered some better rca cables that are grounded only at one end to shield. (Worlds best cables on amazon)
beefkabob
Is there a test for transient response? Say going from silence or low signal to 29db of gain at 50hz tone? See if there's an overshoot or some amps take longer for the transition?
Dj7675
Using balanced out of a Minidsp SHD. Low pass filter did help for sure reduce some of the noise. I’ll have to check to see what happens when I remove the connection. It is capable of some tremendous output though and isn’t an issue too often, but on quite passages of music it is audible.
MediumRare
Chicago
How would a low pass filter reduce the noice without changing the FR in a full range situation?
MediumRare
Chicago
I noticed this distortion chart is at 45kHz bandwidth. What is the purpose of using this bandwidth? If I implement the low pass DSP at 20kHz will that simplify the amplifier’s job and reduce the distortion? And why would 10kHz and 15kHz be higher than 20kHz?
maverickronin
Midwest, USA
That won't help. The frequency response is already limited to 20KHz by the ADC. The higher distortion at higher frequencies is because the 45KHz bandwidth of the test includes ultrasonic harmonics.
pma
Prague
Horrible amplifier. And, as usual, the recommended one.
PeteL
What do you mean setting the low pass at 3000 Hz, a low pass with a 3000 Hz bandwidth would remove all the highs. You meant 300 kHz maybe?
DonH56
Monument, CO
With very specific qualifications:
Competent pro amplifiers target for good enough noise and distortion. The Crown XLS 1002 falls in that category so if you were expecting to have anything better for so little money and so much power, you would be disappointed. But otherwise the amp does what it targets to do.
I am going to put the Crown XLS1002 on my recommended list for non-critical applications or for driving subwoofers and such.
MediumRare
Chicago
What’s the purpose of measuring anything above 20kHz? (Assuming it’s not a broken AM transmitter, of course), especially in combination with the audible frequency range and metrics?
Jdunk54nl
Arizona
He is using it on a subwoofer (as am I). So you don’t want highs in that. My point was that setting a low pass (no matter it’s value, but not too low that it interferes with other crossover settings and create phase issues) helps with the noise.
the crown has a max of 3000hz for this setting...what low pass ever has an ability to set it at 300khz?
