dbx 1231 Graphic EQ Review
This is a review and detailed measurements of the dbx 1231 stereo balanced Graphic Equalizer. It is on kind loan from a member and costs US $499.
Isn't this an attractive box or what? Makes you want to sit there and just play with all those sliders! Careful though as setting them all back to zero is very time consuming. Fortunately there is a bypass button. Connectivity is extensive in the back:
You can even use bare wire if you want!
Note: Harman owns dbx. Our company, Madrona Digital, buys some of their product lines but not these. Still, feel free to read any bias in my subjective remarks.
dbx 1231 Measurements
Let's start with EQ bypassed and input/output of 4 volts:
Distortion is at -105 dB which is very good for the class. Don't like the power supply noise but they are at -118 dB so we can ignore them. Turning on the EQ but keeping all the sliders at 0 shows the penalty of the full pipeline:
We are right at noise floor of 16 bit audio so not bad still. Here is our signal to noise ratio which is impacted the most:
Frequency response is flat in audible band with EQ bypassed:
It is hard to get rid of the channel mismatch due to notches in the gain control with the pot itself being fully variable. Repeatability is hard as well for the same reason.
I was pleased to see it handle up to 9 volts input before clipping:
IMD distortion is respectable with EQ bypassed and not too bad with it active:
Crosstalk is excellent either way: (better than most amplifiers)
I was disappointed to see a rise in distortion at low frequencies:
Good to see the word "professional" has a meaning here in delivering a low distortion and noise graphic EQ. My memories of consumer units was that they were hiss factories. Not so here. This is a quality piece with reasonable price to match it for analog lovers.
Note that in general, graphic equalizers are poor at dealing with room modes or speaker correction. You need parametric EQ for that. The dbx 1231 has a lot of bands so you may be able to get close with it but still not an optimal tool.
I am going to recommend dbx 1231 graphic eq if you need such a device.
Rja4000
Liège, Belgium
Hi Amir
Thanks for this review.
Nice to see that here.
For such a device, an important question is: what kind of graphic EQ correction does this one bring ?
Is that a constant Q ? Or a vary-Q ?
A simple frequency response test at 4 levels on the same graph would bring the answer (and measure the amount of correction): for, say, 1kHz, level at 0, 1/2 max, max, 1/2 min, min.
Another big difference between graphical EQs is: if I push, say, 1kHz to max, then cut 1.25kHz to min and 1.6kHz to max, what is my level at 1.25kHz ?
Some EQ will have level at the middle frequency to 0dB, which may be confusing.
(More explanations between constant Q and vary-Q here)
(EDIT: Another interesting explanation here
and here an example of an asymmetric EQ)
EDIT:
An example of "Q check" measurement
Here, the RME ADI-2 Pro fs R. I tried different boost/cut levels with a "Peak" EQ, 1kHz, Q=9.9, at level -12dB, -6dB, 0dB, +6dB and +12dB
As I've fixed the RME's Q, we see very well the effect of a "Constant Q" EQ: The correction bandwidth is larger if you increase Boost/Cut
Some EQ are more or less keeping the bandwidth constant (and therefore vary the Q with level) or do even more complex tricks (like the Proportional Q in Klark Teknik EQs)
Here is what we could get if the EQ is trying to keep the +/-3dB bandwidth constant
Q is now 5.3 at +/- 6dB and 9.9 at +/-12dB
Some EQ are even asymmetric, using a different profile for boost and for cut.
(picture from Presonus)
So this simple measurement gives us a lot of information...
I've also performed the comparison of the second test I listed:
Alternate max boost/cut on adjacent faders:
Here, still with the RME, I've set 3 EQ to 1kHz -12dB, 1.25kHz +12dB and 1.6kHz -12dB
First with a Q of 9.9 (Max)
then with a much lower Q of 2.0
The different is stunning, isn't it ?
(NB: It would be more "readable" with frequencies centered around 1kHz, so 800Hz, 1kHz and 1.25kHz)
DualTriode
Amirm,
I am glad to see you review this equalizer.
I have been using similar Rane and Klark dn370 equalizers for quite awhile.
It help to select drivers that fairly smooth Frequency Response.
I use JBL 2226 woofers, JBL 2123 mids and JBL M2 waveguides with D2 drivers.
I use a Behringer RTA 61 band thing with a microphone to dial in the sliders.
Thanks DT
DanielT
Sweden - Слава Україні
Amirm,
Thanks DT
But how do you do when you fix FR with your EQ? It's fixed frequencies you change with a physical EQ, I mean ...hm are you lucky that where you need to change/ fix FR right there you have an EQ band/slider or....well how do you actually do it?
Edit:
Q values are also fixed, right?By the way, I see that Rja4000 in #8 brings up the same things.:)
DanielT
Thanks Amir, but why no test what it's made for, that is: EQing?
Exactly, take a speaker where EQ would make sense . How well does dbx 1231
correct the FR then? How close does it dot, so to say?:)
It might go beyond Amir's test of it itself but it would have been fun to see.
(Don't do it Amir, spend your time on something else:))
Do what there? Play with the slides and show that the response changes??? That part is a given. My goal was to see how transparent it is. And I tested that with and without EQ being on.
jamescarter1982
excellent these are the sort of reviews I would like to see most they tell us if these older anaolouge products are worth buying
Chrise36
Can you try eq any headphones and compare digital to analog eq
BeerBear
Good to see some production gear being tested!
Nice "legacy" product. But, in the digital domain, one can have better "equalizers" for 0.00 $, and without sacrificing space.
I agree, but some people strongly believe that hardware has some "magic sound" that can't be reproduced with software... maybe it's the magic of noise, IDK...
It would be nice to do some tests of this, as much as it's possible anyway, in a controlled/scientific manner.
It's constant Q according to this post: https://gearspace.com/board/showpost.php?p=14356767&postcount=6
Rja4000
Liège, Belgium
I found nothing in the specs or manual about it.
So measuring it would be nice, I think.
Not only you can check if that's actually Constant Q, but also what Q value it is, and what's the maximum boost/cut in dB.
(Some EQ behave differently for boost and cut)
DSJR
Suffolk Coastal, UK
These things were all but outlawed in the dark days of UK audiophoolery. My take then was that if bass was boomy due to a speaker design issue (some BeeBeeCee legacy models for example), just cutting the bass down didn't cure the issue, it just made it less of a problem. No equaliser would really fix harshness up top either..
Fast forward to today and I was all set to get one to cure a terminal dullness in the sound here. Turns out it was my hearing that needed equalising, not the system, causing the problem and it's 'fixed' for me, at least for now :) Amazing that reflected sound is now far more prominent in a beneficial way, something an equaliser can't fix really.
PeteL
The fact that it's not aimed at digital only signal chain don't make it a legacy product. It's a current product. Many of us have a mix of analog and digital sources and use an analog preamp. It's kinda nice that it appears to compete in performance of something like a MiniDsP 2X4 Hd when you account the full AD-DA. Many of us don't listen to 24 bit content neither. Graph EQ like that are limitative I admit, but I have to say that if I could find for reasonable price a combination of Analog Parametric EQ and crossover for subs without significant payback in noise and distortion, I would trade my Mini DSP in a heartbeat. It's so much more intuitive convenient, and fun to use. Cool to look at too, you can find now racks nicely enclosed in wood finished chassis that look happily at home in actual living spaces, if you have the room of course.
