DIN 5 wiring
Solist
Total newbie question, but I am a bearing guy, so please bear with me... (pun?)
About to order some cables, to connect the DAC to AMP. (RCA to DIN 5 - male to male) and need confirmation about wiring:
What would be the correct wiring? (If you reference the first picture?)
sergeauckland
Suffolk UK
DIN plugs for stereo audio (as opposed to MIDI) are wired as follows:
1 Left Out
2 Ground
3 Left In
4 Right Out
5 Right In
So from a DAC to the amplifier you need a cable with 3 & 5 wired with ground to 2
What I do is to buy a standard DIN-RCA with all four wired and just use the two that work!
S
S
Solist
1 Left Out
2 Ground
3 Left In
4 Right Out
5 Right In
S
Thank you for the reply!
I asked the same question on another forum and they told me that the following wiring is correct:
Told me, that 5 and 3 are outputs...?
I did the same (4 RCA to DIN 5), but since I wanted to order some speaker cables, I asked them if they can make also this interconnect.
Zek
It depends on which side of the cable you look at, if it's on the source side, then it's the output.
According to the attached scheme, 3 and 5+1 are inputs.
Pins 5 and 1 are short-circuited so that a 3-pole DIN plug can be used.
