DIYSG Volt-8 Speaker Review
hardisj
Reviewer
North Alabama
As always, this is a copy/paste from my site and the format may not translate well here but I don't have time to shine it up so if you want to view it on my site, here is the link:
https://www.erinsaudiocorner.com/loudspeakers/diysg_volt8/
DIYSG Volt-8 (v2) Speaker Review
  • Wednesday, Jun 2, 2021
The review on this website is a brief overview and summary of the objective performance of this speaker. It is not intended to be a deep dive. Moreso, this is information for those who prefer “just the facts” and prefer to have the data without the filler. Due to extremely limited time, I am not providing any subjective evaluation but hope the data will be enough for designers and DIY’ers alike that they can glean useful information.
For a primer on what the data means, please watch my series of videos where I provide in-depth discussion and examples of how to read the graphics presented hereon.
https://youtube.com/playlist?list=PLnIxFR_ey0b37Ex4KV2mBz-kYB7QLffR1
Information and Photos
The DIY Sound Group Volt-8 v2 is a DIY design from Matt Grant which is available in kit form from DIYSG. Here are some notes from the product page:
The Volt-8 uses a custom made 8” coaxial for high output and impressive power handling. The new surround and spider improves the X-max rating while the light weight cone gives this speaker a smooth sounding midrange even when played at high levels. The crossover was designed to give an even response that not only excels for surround speaker use, but also for great front speaker performance. The custom compression driver (tweeter) made by Celestion is installed on the back and fires through a small waveguide in the center of the woofer giving you point source sound and great off axis response. I’ll be posting more information about the custom driver soon. It’s based off the CDX1-1446. The crossover was designed to give an even response that not only excels for surround sound speaker use, but also for great front speaker performance. The Volt-8 does quite well in small ported enclosures between .5 and .7cuft when used with a subwoofer. The Atmos version is a small sealed enclosure designed to play down to 100hz, which is great for Atmos use. You can use them mounted in your ceiling without an enclosure for Atmos use if needed. For surround sound or mains, you should build the ported models.
These speakers were loaned to me by their owner, who built them from the kit.
The reference axis was at the tweeter.
CTA-2034 / SPINORAMA:
Early Reflections Breakout:
Estimated In-Room Response:
Additional Measurements
Impedance Magnitude and Phase + Equivalent Peak Dissipation Resistance (EPDR)
For those who do not know what EPDR is (ahem, me until 2020), Keith Howard came up with this metric which he defined in a 2007 article for Stereophile as:
… simply the resistive load that would give rise to the same peak device dissipation as the speaker itself.​
A note from Dr. Jack Oclee-Brown of Kef (who supplied the formula for calculating EPDR):
Just a note of caution that the EPDR derivation is based on a class-B output stage so it’s valid for typical class-AB amps but certainly not for class-A and probably has only marginal relevance for class-D amps (would love to hear from a class-D expert on this topic).​
On-Axis Response Linearity
“Globe” Plots
Vertical Polar (Globe) Plot:
Harmonic Distortion
  2. 86dB at 1 meter (red)
  3. 96dB at 1 meter (blue)
  4. 102dB at 1 meter (purple)
Long Term Compression Tests
Parting / Random Thoughts
  • Response linearity is quite varied which indicates a sub-optimal coaxial design. Similar performance can be seen in the DIYSG Volt-6 I also reviewed (link). This is my quote from that review: The response linearity is pretty poor. If I am being honest, this just seems like a sub-par coaxial driver with poor tweeter/mid integration. I say that because the 6kHz region shows some sort of issue where the off-axis response is even higher in SPL than the on-axis response; something I typically see in waveguides and this is way above the crossover point. There are also pretty significant combing effects above this, especially above 10kHz.
  • Mean SPL is 89.4dB @ 2.83v/1m.
  • Impedance sweep indicates enclosure tuning of approximately 65Hz and shows some signs of resonance (source unknown) at approximately 500Hz and again at 700Hz.
  • Good distortion performance.
  • Poor dynamic range below about 150Hz where both compression and enhancement trade off below 100Hz.
  • Good long term compression with practically no change as listening duration continues (though, remember, this is not the same as instantaneous compression (dynamic range), mentioned above).
Support / Donate
If you like what you see here and want to help me keep it going, please consider donating via PayPal (link). Donations help me pay for new items to test, hardware, miscellaneous items and costs of the site’s server space and bandwidth. All of which I pay out of pocket. So, if you can help chip in a few bucks, know that it is very much appreciated and that the support means a lot to me.
Maiky76
French, living in China
“Globe” Plots
Harmonic Distortion
Support / Donate
Hi,
Here is my take on the EQ.
The raw data with corrected ER and PIR:
Score no EQ: 2.1
With Sub: 4.8
Spinorama with no EQ:
  • Poor
Directivity:
Poor
EQ design:
I have generated two EQs. The APO config files are attached.
  • The first one, labelled, LW is targeted at making the LW flat
  • The second, labelled Score, starts with the first one and adds the score as an optimization variable.
Score EQ LW: 3.2
with sub: 5.9
Score EQ Score: 3.9
with sub: 6.6
Code:
DIYSG Volt-8 APO EQ LW 96000Hz
June032021-120433
Preamp: -3.1 dB
Filter 1: ON HPQ Fc 76.9 Hz Gain 0 dB Q 1.19
Filter 2: ON PK Fc 201.3 Hz Gain -2.8 dB Q 1.29
Filter 3: ON PK Fc 775 Hz Gain -4 dB Q 3.74
Filter 4: ON PK Fc 1111 Hz Gain 2.24 dB Q 2.82
Filter 5: ON PK Fc 1738 Hz Gain -2.81 dB Q 4.25
Filter 6: ON PK Fc 2555 Hz Gain 3.26 dB Q 3.31
DIYSG Volt-8 APO EQ Score 96000Hz
June032021-115845
Preamp: -2.3 dB
Filter 2: ON PK Fc 201.3 Hz Gain -2.8 dB Q 1.11
Filter 3: ON PK Fc 809 Hz Gain -4 dB Q 3
Filter 4: ON PK Fc 1036 Hz Gain 2.74 dB Q 3.92
Filter 5: ON PK Fc 1774 Hz Gain -3.05 dB Q 3.25
Filter 6: ON PK Fc 2550 Hz Gain 2.9 dB Q 2.31
Filter 7: ON PK Fc 6400 Hz Gain -3 dB Q 1.83
Spinorama EQ LW
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
Radar no EQ vs EQ score
The rest of the plots is attached.
  • DIYSG Volt-8 APO EQ LW 96000Hz.txt
  • DIYSG Volt-8 APO EQ Score 96000Hz.txt
pierre
Switzerland
Another possible EQ that optimise the Olive score from 2.2 to 3.6.
Code:
EQ for DIYSG Volt-8 v2 computed from ErinsAudioCorner data
Preference Score 2.2 with EQ 3.6
Generated from http://github.com/pierreaubert/spinorama/generate_peqs.py v0.8
Dated: 2021-06-03-06:42:08
Preamp: -2.7 dB
Filter  1: ON PK Fc  5548 Hz Gain -2.40 dB Q 1.12
Filter  2: ON PK Fc  5313 Hz Gain +2.07 dB Q 4.00
Filter  3: ON PK Fc   763 Hz Gain -2.36 dB Q 4.00
Filter  4: ON PK Fc   439 Hz Gain +1.58 dB Q 3.14
Filter  5: ON PK Fc  1078 Hz Gain +1.99 dB Q 4.00
Filter  6: ON PK Fc  2678 Hz Gain +2.69 dB Q 4.00
Filter  7: ON PK Fc  1700 Hz Gain -3.32 dB Q 4.00
Filter  8: ON PK Fc 10138 Hz Gain -2.60 dB Q 2.65
Filter  9: ON PK Fc  4351 Hz Gain -1.43 dB Q 4.00
Filter 10: ON PK Fc  1415 Hz Gain +1.49 dB Q 4.00
Filter 11: ON PK Fc   807 Hz Gain -1.03 dB Q 4.00
Filter 12: ON PK Fc  2375 Hz Gain +1.58 dB Q 4.00
Filter 13: ON PK Fc  2185 Hz Gain -1.00 dB Q 4.00
Nomad
Thanks for taking your time to measure these DIY speakers! So far the DIYSG speakers have not made a very good impression it seems.
XpanD
Netherlands
Ouch, was hoping for something a little better here. The price isn't entirely terrible, but that seems to be about the only good thing on offer here.
Unrelated... The "CTA-2034 (SPINORAMA) and Accompanying Data" YouTube link does not seem to allow embedding on other sites, I just see a "Playback on other websites has been disabled by the video owner." error. May be good to change that to a normal link?
Thanks for another quality measurement.
yourmando
Yes, thanks for the quality measurements.
Looks like the Volts should not have been released.
Any new speaker maker these days should be willing to proudly display a quality CTA-2034 measurement on their spec page. To not even know that it measures this way, or to know but release anyway are both not great. There are incumbent brands that can get away with Klippel murder (ahem, Klipsch). For better or worse, they benefit from decades of brand building.
Given that Diysg has constant inventory problems, it would seem to make sense to slim their product offerings down. They owner has lamented many times how difficult it is to keep every little part in stock for so many skus.
Sliming the products down to the best and most popular (HTM-12 v2, etc) + raising prices to allow for better service and quality control should go a long way. (For example, should catch when speaker vendor quaility deviates from design.) From that base, it would make sense to add more models.
Ericglo
I said you would either be loved or hated over at AVS. Your thread got them stirred up. :)
Now all you need is that youtuber and his girlfriend to come over and say "See I told you measurements didn't matter":eek:
To his credit, Matt has said that they didn't measure that well. They seemed to sell well anyway.
I mentioned to the owner a couple of years ago that he should reduce the amount of speakers he has for sale. I forgot exactly what he said, but it was along the lines that he offers what sells.
