Do frequency test sweeps (REW etc) compensate for fletcher munson
fatoldgit
As title says, do test sweeps compensate for fletcher munson to achieve equal loudness or are they all flat (i.e. set to say -6db digital scale)?
Philbo King
You could design a F-M curve (for some constant audio level; it's very level-dependent) with the EQ section and export it as an IR. I guarantee you won't like the results. Your auditory cortex has spent your whole life adapting to your built-in F-M. It would be like wearing glasses where you see everything upside down.
Chrispy
PNW
Not unless designed to do so....
MaxwellsEq
This is quite a popular question, just reworded.
A recording system must not compensate for the Fletcher–Munson curves.
An accurate domestic playback system must not compensate for the Fletcher–Munson curves.
End consumer kit may have a loudness button which allegedly compensates for the Fletcher–Munson curves, but in practice must always be a fudge.
F
fatoldgit
ok
so the answer is no... each frequency in the sweep will be at a constant level because music production doesnt compensate and the playback side also doesnt so having a compensated frequency sweep that is used for room measurements wouldnt mimic the "end to end" musical content the room would experience.
Thanks for that
Peter
