Ok.
I'll play.
Give me a solution for less than the $18.97 or so I spent and requires no more effort than to plug in both ends and hasn't required any further fiddling around since then (four years ago).
25 foot of TOSLINK for $11.99?
How is an optical cable a solution for connectivity between two USB ports?
I don't know your architecture.
Had the question if these cables provide full grounding isolation? Reading the link I understand they do not transfer any power except internally for self-powering at both ends, but couldn't determine if the ground remains totally isolated? (ground loops).
10 m set you back $109
So a $100 per 10 m !
You should publish these groundbreaking findings...Exhaustive research has proven to me that USB cables do indeed make a dramatic difference in the sound. When I pull the cable, the sound goes away. It comes back when I reinsert the cable.
Yep, might be worth a AES White paper, tan might do in this case.Exhaustive research has proven to me that USB cables do indeed make a dramatic difference in the sound. When I pull the cable, the sound goes away. It comes back when I reinsert the cable.
Hummm, sounds like a job for The Scrutinizer!If ground is isolated, is it still ground?
He'll need peer review before publishing.You should publish these groundbreaking findings...
