E1DA Cosmos ADC
renaudrenaud
Tianjin
Sorry for that question, not native english here, but I would like the confirmation: it's not possible to use it as an ADC in audio system because the USB output has to be connected to a computer, am I right?
staticV3
What is an "audio system" exactly?
If you're using a PC or Mac to record and create music, then naturally you can use the Cosmos ADC with that system.
staticV3
I have plenty of, most of them are SMSL, SABAJ, Topping. For example I own a Topping D10 Balanced.
ADC->USB->DAC does not work.
You can do ADC->USB->PC->USB->DAC.
However, I have to ask what the point of this conversion is, and why you don't want to listen to the analog audio source directly instead.
renaudrenaud
Tianjin
With one ADC, it means the DAC allows me to select the source and define the volume and use a remote, for example with the Gustard X16.
Currently I have a some analog sources managed with the Topping A90 used as a preamp.
IVX
South of China, SHZ area, - Слава Україні
STM8S003 3x3mm + NTC = thermostatic oven.
IVX
MCU STM8S003 3x3mm with shorted to GND GPIO + NTC as a temperature sensor. ES9822 was calibrated as 27C, if you'll run that at 20C you'll get noticeable worse 3rd harmonic, so the simple thermostat helps to make the temperature range wider, 20-30C I hope will work exactly like at 27C.
I can warm up the ADC chip the same way i.e. short its GPIOs to GND and set them to be '0' but no thermal sensor on that chip.
mansr
mansr
Hampshire
So you glued the uC onto the ADC chip?
staticV3
Very interesting product @IVX . Unfortunately, the Aliexpress store link on your website seems to be broken:
I get only a blank page on Android and a login page on PC. It may work if you are already logged to Aliexpress.
It should probably be this -> https://www.aliexpress.com/store/5142044
5142044 is the correct store. I'll ask Ivan to change the hyperlink so that no login is required.
Edit: Works fine on my Tab S7+ though:
sseppala
It did not work for me for any browser or system, but I see that the link has already been changed. Did you really test the old link? If so, it could be that you had some Aliexpress-cookie setting in the browser that made it work.
staticV3
Yes. Tested before Ivan changed to the hyperlink.
IVX
Sorry, I'm too busy on making the product interesting, and I apologize for such mistakes.
