ESS ES9039PRO and ES9027PRO announced
BR52
Germany
They has to be balanced because they are generated in that way. Everything common mode is unwanted. First I was expecting a dc servo but @KSTR was my eye opener. If you have a servo use it as good as possible.
KSTR
Berlin, Germany
The I/V stages for the ES9069 and 9039Q2M (they are identical) are nuts to me. So unlike the one for the 9039PRO shown in above post. Can some explain to me how this IV stage works? Why positive feedback on U2.1? Why apply DAC input to both U2.1 filter netwirk and non-inverting input of U2.2? How is this circuit truly balanced?
U2.1 is just an inverter on the output of U2.2 drawn in a obscure way. U2.2 is a very simple differential I/V. Normally its non-inverting leg would go to ground, but here it goes to the inverted copy of its own output. This a) makes a balanced output but more importantly, b) it automatically keeps the output voltage of the chip's output pins at a constant voltage, sort of an automatic bias system. This one, however, is not a CM servo loop.
The same filter circuit (with input V/I converting resistors) is used some for some voltage-output DAC chips and it is a variation of the "super-balanced" differential receiver circuit (https://sound-au.com/articles/balanced-io.htm#s3)
BR52
Germany
From my understanding it’s servo the dc between the balanced pins out without a servo? For sure no cm servo loop like the thread before.
David_M
Thank you...though I don't understand the merits of this circuit over the one in the 9039PRO:rolleyes:.
Now, as far as the wide bandwidth (ok, 2.6KHz) CM servo I alluded to earlier for the 9039PRO:
a) What are some of the common mode sources of noise to the amp inputs, apart from the 50/60Hz mains and their harmonics, that would justify a wideband CM circuit?
b) If the 51pF filter cap was removed, would a full-range CM filter make sense? What are any plusses and minuses?
Thanks!
BR52
Germany
Thanks!
One op amp less. I'm not sure abut the penalties....
a) noise conducted from the digital side of the DAC, glitches...
b) oscillations, 51pf please consider the gain BW product
KSTR
Berlin, Germany
Thanks!
The circuit, when seen as a black box, does the same thing as the 9039pro circuit. It's a fully differential operational amplifier set up as a differential filter (see Fig.26).
The 9039q2m circuit, the super-balanced differential I/V (differential low-pass filter), is the simplest configuration for this besides specialized fully differential amplifier chips and it does work well / is pretty robust.
ESS "current output" DAC have higher even-order distortion and noise when looking at the individual outputs. Proper summing of the outputs removes most of the even-order distortion because because of symmetry. Therefore, removing the CM content is absolutely required for best performance. And yes, balanced internal signal paths in a DAC is always good for low interference.
In the 9039pro circuit, the CM loop amp needs to have some local compensation because the main amps are the slave amplifiers in the composite loop and would add excessive phase if the master operated "wide open" wrt bandwidth, causing instability/oscillations.
For a similar reason, BTW, we find this 33pF cap in the feedback of the inverter in the 9039q2m circuit.
David_M
@KSTR and @BR52, thank you so much for your input. I will have to study this new form of DiffAmp architecture I've never seen before a bit more.
CleanSound
Could this be it?
Matias
Matias
São Paulo, Brazil
Bleib
Sweden
Probably, D90 III
D50 III is supposed to come as well
Bleib
Sweden
Bleib
Sweden
I was hoping for a UI update similar to the new D70’s.
Yes, the optional VU-meter for instance is quite nice. In fact, the D70pro display looks a lot nicer.
According to some other posts PEQ support will be added to D90 III later on at least.
