U2.1 is just an inverter on the output of U2.2 drawn in a obscure way. U2.2 is a very simple differential I/V. Normally its non-inverting leg would go to ground, but here it goes to the inverted copy of its own output. This a) makes a balanced output but more importantly, b) it automatically keeps the output voltage of the chip's output pins at a constant voltage, sort of an automatic bias system. This one, however, is not a CM servo loop.The I/V stages for the ES9069 and 9039Q2M (they are identical) are nuts to me. So unlike the one for the 9039PRO shown in above post. Can some explain to me how this IV stage works? Why positive feedback on U2.1? Why apply DAC input to both U2.1 filter netwirk and non-inverting input of U2.2? How is this circuit truly balanced?
From my understanding it’s servo the dc between the balanced pins out without a servo? For sure no cm servo loop like the thread before.U2.1 is just an inverter on the output of U2.2 drawn in a obscure way. U2.2 is a very simple differential I/V. Normally its non-inverting leg would go to ground, but here it goes to the inverted copy of its own output. This a) makes a balanced output but more importantly, b) it automatically keeps the output voltage of the chip's output pins at a constant voltage, sort of an automatic bias system. This one, however, is not a CM servo loop.
The same filter circuit (with input V/I converting resistors) is used some for some voltage-output DAC chips and it is a variation of the "super-balanced" differential receiver circuit (https://sound-au.com/articles/balanced-io.htm#s3)
Thank you...though I don't understand the merits of this circuit over the one in the 9039PRO.U2.1 is just an inverter on the output of U2.2 drawn in a obscure way. U2.2 is a very simple differential I/V. Normally its non-inverting leg would go to ground, but here it goes to the inverted copy of its own output. This a) makes a balanced output but more importantly, b) it automatically keeps the output voltage of the chip's output pins at a constant voltage, sort of an automatic bias system. This one, however, is not a CM servo loop.
One op amp less. I'm not sure abut the penalties....Thank you...though I don't understand the merits of this circuit over the one in the 9039PRO.
Now, as far as the wide bandwidth (ok, 2.6KHz) CM servo I alluded to earlier for the 9039PRO:
a) What are some of the common mode sources of noise to the amp inputs, apart from the 50/60Hz mains and their harmonics, that would justify a wideband CM circuit?
b) If the 51pF filter cap was removed, would a full-range CM filter make sense? What are any plusses and minuses?
Thanks!
The circuit, when seen as a black box, does the same thing as the 9039pro circuit. It's a fully differential operational amplifier set up as a differential filter (see Fig.26).Thank you...though I don't understand the merits of this circuit over the one in the 9039PRO.
Thanks!
Yes, their flagship DAC using 2 x 9039SPRO.Could this be it?
I was hoping for a UI update similar to the new D70’s.TOPPING D90 III SABRE Dual ES9039SPRO Digital to Analog Convertor (DAC
shenzhenaudio.com: professional headphone, earphone, amplifier, dac, decoder, hifi player, cable supermarket. you will find good price here.shenzhenaudio.com
Yes, the optional VU-meter for instance is quite nice. In fact, the D70pro display looks a lot nicer.I was hoping for a UI update similar to the new D70’s.
