mhardy6647
- Joined
- Dec 12, 2019
- Messages
- 11,450
- Likes
- 24,849
... of course... now the problem is that I want a pair of these Fane drivers (or at least a chance to hear 'em), and they're NLA.
How the heck did I miss the photos of the driver in the OP until now??!?!?Let me share another project that I am venturing into
A few months ago I managed to buy a pair of Fane 15" full range speakers - unfortunately production of these drivers was stopped earlier this year due to low demand; as far as I know I bought the last pair in Europe
(if anybody knows about any leftover stock in Europe definitely let me know )
So I have decided to start this project now
These beasts would normally require huge boxes (250+ liters each when sealed) so I decided to go for a higher Qtc value and compensate the lows with EQ and amplifier power
Cabinet will be sealed, 65 liters with Qtc = 1
15mm baltic birch plywood (wanted 18mm but it is quite an unobtanium over here these days or freaking expensive)
Here are some simulations:
Max input power will be 90W per channel, that's where the drivers will reach their linear xmax
At that power I will get 95.4dB at 1m at 24Hz
This is for one speaker so +6dB for two speakers plus room gain which is 15dB in my living room at 24Hz
Impedance:
Phase:
Group delay:
Of course I will use extensive DSP to correct the magnitude response (it will be much needed anyway...)
Some pictures and a video in the meantime:
New video by Peter Pataki
photos.app.goo.gl
And some building material:
The bottle is for scale
Stay tuned!
No, the drivers are in the bottom half.Looking neet. Aren't they upside-down?
In case you don't need subs, isn't the woofer way too far down for decent high-frequency reproduction? The woofer is already beaming as it is, having it mounted all the way down won't make things better.No, the drivers are in the bottom half.
The idea is that if I need any subs they will fit below in another cabinet (but I suspect that I won't need any)
The center of the woofer (ie where the highs are coming from) will be at ear height - so no issues with thatIn case you don't need subs, isn't the woofer way too far down for decent high-frequency reproduction? The woofer is already beaming as it is, having it mounted all the way down won't make things better.
You are right, forgot to mention that then I apply a low shelf and a high shelf to shape the sound to my tasteCool!
Isn’t correcting for flat in-room response a bit unorthodox?
From a local (Hungarian) dealership specialized in sound damping. Unfortunately I cannot tell the original brand since it was re-branded by the dealership (I am sure that they are not the producer)Where did you get your felt from?
What do you mean exactly please?Any plans for dispersion/directivity control?
To be honest, no
I'm trying to find a company that sells felt pads big enough to go under a carpet. Haven't been successful so far.From a local (Hungarian) dealership specialized in sound damping. Unfortunately I cannot tell the original brand since it was re-branded by the dealership (I am sure that they are not the producer)
