Fast transient in music recordings - tweeter load - amp response
pma
pma
Prague
I tried my 2-way speaker with a 6kHz uniform sine burst of +/-50Vpeak amplitude. Recorded amp output voltage and tweeter acoustical output. The tweeter (Seas T25CF001) seems to handle the peaks quite well.
restorer-john
Well done Pavel. Do you have a capacitor/x/over in line with the tweeter or directly driven?
Reactions: pma
pma
pma
Prague
There is a -18dB/oct xover (2.4kHz) before the tweeter and also a padding resistor, so in fact the tweeter sees only about half of the amplitude. However it is a real-life and probably the worst case situation with my amplifier.
restorer-john
Your Seas tweeter behaves very well. Initial under amplitude, next cycle overshoots a small amount, and then stabilizes within two cycles. Impressive if you ask me.
Reactions: pma
pma
pma
Prague
Thanks, I like Seas Excel series, at least some of the drivers. And sonically as well, not only by measurements.
pma
pma
Prague
This is the measured spectrum of electrical signal at amplifier output and acoustical signal corresponding to time domain plots in post #21.
5 cycles of 6kHz sine have length of 833.33 us. This corresponds to 1200 Hz width of the side lobes. Sine burst was generated with Fs = 48kHz (see the measured electrical signal spectrum). Measurements were made with Fs = 96kHz sampling. Note the decaying oscillations of the tweeter output.
Cbdb2
Vancouver
From your graphs I see .8 fs (say 80volts)for the woof and less than .6 fs (say 58 volts) for the tweet. Thats half the peak power, not the same. And we all know average power difference will be much greater.
pma
pma
Prague
0.8FS and 0.6FS are correct guesses. And? All I am saying is that peak amplitude into tweeter section is high, nothing else. Because this is often overlooked and not understood.
Cbdb2
Vancouver
And hard to believe most of the higher end active studio monitors are under powering there tweeters.
Focal shape65s. Woof and mid= 80watt, tweet=25wats
Dynaudio core 59 woof and tweet=500w, tweet=150w
Meyer HD1s woof=150w, tweet=75w
Cbdb2
Vancouver
I see the line below .6 but whatever, .6fs is close enough, still around half the power. Sure its high but not as high as the woofer.
