Focal Clear Review (headphone)
N
nhatlam96
Guest
an amplifier with 0.2 Ohm output resistance
If I intepret that correctly: with 0 Ohm output resistance, you will get the highest fidelity of the headphone. What prevents designing 0 ohm output resistance amplifiers?
N
nhatlam96
Guest
DACs have no influence on output R. Its only the amps.
Maybe something different, can the output voltage of the dac have an effect on the frequency response? How can I measure it and what output voltage can be considered safe or not? With safe I mean does it change FR or not
Daaadou
Paris, France
Physics.
Even a bare wire has an impedance.
You could do that at extremely low temperature though, supra conductivity gets you very close to 0ohm.
Jimbob54
The output voltage of the dac has no impact on the FR of a headphone connected to an amp that is in turn fed from the DAC. The output voltage of a DAC changing has an impact on how hard the amp has to work to achieve the desired output voltage into the headphone.
What is it you are trying to get to? What is concerning you?
m8o
Just a quick note that I really loved reading this review. Specifically the way you drilled in on the places this HP shows its weaknesses and the manner you reported them.
DJBonoBobo
any germ
I wonder if future reviews will include headphones that sound better than the Focal Clear (without EQ). For me, the Clear was a significant upgrade over the HD650 with no real drawbacks. All the other headphones I tried had some kind of drawbacks that were dealbreakers for me (e.g. treble on the HD800S, wearing comfort on Audeze and Stax). But what do I know...
Jimbob54
I think "sound better" is the crux of a lot of the discussion on this and other HP review threads. Given this is a measurement led site, we might have to settle for "best measuring" before EQ and after, so proximity to the FR target and distortion and other measures. Whether the "best measuring" equates to your, mine or anyone's idea of "best sounding" is going to be hard or impossible to say at this point, maybe never. (EDIT- thats why we EQ, after all) But if we can understand how measurements can be reconciled to perception of things like soundstage, clarity, separation etc then its all to the good.
N
nhatlam96
Guest
This is a matter of personal taste and intention.
When I go to sleep, I prefer the smoother and more vocal intense HD58X.
When I would like to have complete experience of the music, then I pick the Clear.
solderdude
The Neitherlands
With a low output resistance amplifier it behaves as close as possible to a voltage source.
It is not related to highest fidelity though.
With low impedance headphones that are low in output resistance you get the least amount of coloration with all headphones.
0 Ohm is hard to do in practice but one can get really close. 0 Ohm is not essential or obligatory though. Low impedance is preferable.
Obviously the designers at Focal feel 10 Ohm is optimal for the Utopia. It would make more sense to simply EQ in a different tonal balance than to use different output resistances to slightly change the bass.
It can't when you measure it but when you use a DAC with 2V out and compare it to a dongle with say... 1V out the 2V out DAC will generally be preferred. Lower the output voltage to the same 1V and all differences disappear (unless the DACs differ in other aspects as well)
m8o
Hear, hear. Can't be said enough. This should be a disclaimer put at the top or bottom of every test review, in red, maybe italicized; would blinking be too much (lol)?
dlieb
I actually wonder if Amir would consider reviewing the HD650. It would be extremely useful to have as a reference, especially given that so many of us are familiar with it. In fact, I'm one of those people who just can't find a headphone I like more. I have never tried a Focal Clear, but I definitely didn't like the Elear very much.
DJBonoBobo
any germ
Sure. I don't want to argue with that at all. It's just that the HD 650 seems to be the closest to the desired target so far, and the Clear struck me as clearly superior in every respect.
If headphones are so heavily dependent on individual preferences, at least from my perspective, the target seems less generalizable than other measurements on this site. It calls into question what to do with the measurements. But I think that has also been noted by more competent people (than me) here from the beginning.
I probably meant: are there headphones with objectively better results than the Focal Clear out there, leaving EQ and possible clipping (which I've never experienced in 2 years with them) aside? If so, I would be interested to know if I then also subjectively like the sound better. With HD 650 it was not so. I like it well, but i like the Clear more. The question is not meant rhetorically either, I really wonder.
N
nhatlam96
Guest
Not sure if I follow everything you said, please then correct me.
Basically, low amp output impedance equals to less coloration, as long as the headphones itself are low impedance?
Why does the headphone impedance matter here?
Unsurprisingly, the Focal Arche is then a big and hollow marketing gimmick. I always knew that, now it's been explained.
Why is the 2V DAC more preferable than the 1V DAC. What are the tonal differences?
I find the Clear very obvious a class higher than Elear and Elegia.
Jimbob54
FWIW I'm in the same boat as you and others. Prefer the sound of my Clear to hd600 and few others before and after EQ.
solderdude
The Neitherlands
A low output resistance guarantees the least possible coloration of the sound when using low impedance headphones. For high impedance headphones the effect is less because the ratio between output R and impedance differs.
Well it DOES change the sound a bit for those headphones. Those that prefer a bit more bass will certainly prefer that amp in 'special' mode compared to voltage mode. It's cheaper to buy an old Topping amp with 10 Ohm out though for that specific HP.
louder sounds 'better' and 'fuller'. Technically the only difference is level. There is no difference in tone. Only perceived differences due to the 6dB increase in level.
haven't heard the Elegia, measurements suggest a much warmer tonal balance. Some find the Clear lacking this.
I found the Clear to sound better than the Elear. That one has a weird tonality to me but others find it the best.
Aside from technical performance there is also such a thing as preference and differences in ear/pinna that can make some folks prefer this and others that.
There are people that find the treble peak of Beyers pleasant. Most likely when examining their hearing one may find their hearing has a similar dip as that of HATS but at a lower frequency (different concha/ear canal). Others hate the treble peak (me for instance) but 20 years ago I wasn't bothered by the peak in my DT990 and loved it for its details. Now I can't listen to it without counter measures.
Joachim Herbert
Munich, Germany
Hm. Usually a review on ASR makes me consider a new product or reconsider a product that I do already own. Now I am sitting here, listening to "Once upon a time in the West" by Max Johnson through a Clear pro with a big smile on my face. Different use case, obviously. ;-)
Jimbob54
Zensō
California
I love this site. Love. It. The objective reviews are so refreshing, especially in the audio world. The other site I check out that reviews headphones in a very similar fashion also covered the Focal Clear. Their results were quite different. Could anyone explain why you think that might be?
https://diyaudioheaven.wordpress.com/headphones/measurements/focal/clear/
@solderdude runs that site and is a major contributor here. Perhaps he'll chime in.
Edit: @Jimbob54 beat me to it. This keeps happening, guess I need to type faster... ;)
N
nhatlam96
Guest
What exactly is low impedance or high impedance headphone anyway? I asked Amir how manufactures determine the impedance value for their headphones and amir said:
Who knows. Some use averaging. Some just pick one frequency. There is an IEC standard but I don't think anyone is using it in their specs.
The manufacturer single numbers such as 60 ohm is therefore quite wrong.
Would low impedance headphones show weaker resonance peaks and high impedance headphone then show stronger resonance peaks?
I think this would be an important aspect for comparing dacs?
For example, let's say I have two setups:
Setup 1: SMSL Sanskrit 10th MK2 (2V) > Monoprice THX887 (4V)
Setup 2: Holo Audio May (4V) > SMSL SP200 (6V)
When I now measure the output voltage from the headphone amplifier with a multimeter, would it take the output voltage of the DAC into consideration or am I solely measuring the output voltage of the amp?
Let's say it doesn't take the DAC's output voltage into consideration and I would like to volume match further, should I just add 2 Volts on Setup1 and it would volume match with Setup2 then?
(@SpeleoFool).
