English is not my first language, so I had to look up anorak. A person (like me) who lives in a place that doesn't go below 73 F (22.77 C) has no need to know this word. However, if the anorak I chose to use if I were in a cold place looked OK visually & did it's function of keeping me warm OK, I wouldn't be checking the threads in between the inside & outside of an anorak for color integrity. The same with a speaker, if the outside was visibly damaged (discoloration, mar, ding, etc then there is a problem that would require a fix. But if it looks good & performs good, I am not in the habit of taking speakers apart to see if anything is wrong when it works fine. Now, if it is out of warranty I may take it apart just to look inside or to modify it. But if it is functioning fine & there are no external signs of an issue and it does what it is supposed to (meeting it's manufacturers specs) no, I am not taking it apart just to look. I do take many things apart that are in warranty (car engines, transmissions & the like) because I am going to modify them for durability, more RPM, more power, better fuel economy, better emissions (yes, if the customer wants to spend the money they can have all five of these better) and more. But not just to check the fit of things. Unless something is going wrong & the reason that it is going wrong is not obvious.
I also don't find a Genelec to be a luxury product. It is a studio monitor (admittedly a damn good one). But there is nothing luxury about it.
Perhaps you are only being facetious:
the only word in the English language that uses all of the vowels in the correct order.
