GoldenEar BRX Review (high-end Bookshelf Speaker)
Rate this speaker:
    Votes: 103 43.5%
    Votes: 108 45.6%
  • 3. Fine (happy panther
    Votes: 19 8.0%
    Votes: 7 3.0%
This is a review and detailed measurements of the GoldenEar BRX "reference" bookshelf speaker. It is on kind loan from a member and costs US $1,598 a pair.
BRX looks pretty fancy but doesn't weigh a lot:
It is an unusual design in passive compact speakers by having dual passive radiators, one on each side:
I worry about how compromised the cabinet is with all those large holes. BTW, the back is smooth. The textured look is from my lighting.
There is a grill which you may want to use as otherwise the bottom "chin" looks pretty ugly to me.
Measurements are compliant with latest speaker research into what can predict the speaker preference and is standardized in CEA/CTA-2034 ANSI specifications. Likewise listening tests are performed per research that shows mono listening is much more revealing of differences between speakers than stereo or multichannel.
Reference axis was the center of AMT driver (aligned by eye). It is getting colder with the measurement room temp at 15 degrees C.
GoldenEar BRX Measurements
Acoustic measurements can be grouped in a way that can be perceptually analyzed to determine how good a speaker is and how it can be used in a room. This so called spinorama shows us just about everything we need to know about the speaker with respect to tonality and some flaws:
GoldenEar BRX Measurements Frequency Response Reference Bookshelf Speaker.png
This is a kind of graph that makes you go "hmmm." For starters, the bass and upper midrange is quite uneven. I imagine this is due to the turning of the dual passive radiator on the bottom side. We then have a region of disturbance from 600 to 1000 Hz. The things get smoother but there is some resonance around 4000 Hz. Near-field response gives us some clues as to what may be going:
GoldenEar BRX Measurements Near field Driver Frequency Response Reference Bookshelf Speaker.png
Seems like the midrange issue has dual causes: the woofer has bump there so seems like baffle compensation is not sufficient. At the same time the passive radiator is peaking. This will cause a directivity error due to its higher frequency and side firing radiator. There is a more pronounced resonance around 4 kHz which at first seems too low level. But it is competing with severe off-axis response of the tweeter so likely sends out some unwanted noise to the sides. Keep in mind though that these (near-field) measurements are approximate.
Back to our spin graph, the early window reflection is quite messy because the on-axis wasn't that clean to begin with:
GoldenEar BRX Measurements Early Window Frequency Response Reference Bookshelf Speaker.png
Here is the simulated response in a room:
GoldenEar BRX Measurements Predicted In-room Frequency Response Reference Bookshelf Speaker.png
I hate it when the bass response of a speaker is this uneven because the room adds to it so there is no direct path to equalization.
Directivity is variable due to beaming of the tweeter (being too large for the wavelengths it is producing):
GoldenEar BRX Measurements Horizontal Beam width Reference Bookshelf Speaker.png
GoldenEar BRX Measurements Horizontal Directivity Reference Bookshelf Speaker.png
This makes the sound room sensitive and potentially difficult to EQ or even assess.
Vertical is what we expect from a 2-way design with even more beaming due to larger size of the AMT tweeter vertically:
GoldenEar BRX Measurements Vertical Directivity Reference Bookshelf Speaker.png
Distortion at low volume is good but gets out of line across the full audio band:
GoldenEar BRX Measurements Distortion Percentage Reference Bookshelf Speaker.png
It is one thing for a small speaker like this to get distorted in bass. But one hopes that it doesn't spread to the rest of the spectrum as audibility thresholds become far more acute.
Impedance dips very low to 3.3 ohm:
GoldenEar BRX Measurements Impedance and Phase Reference Bookshelf Speaker.png
For fans of timing analysis, here is the CSD/Waterfall and Impulse response:
GoldenEar BRX Listening Tests and Equalization
I got off to a rocky start with this speaker. It left me with a very variable impression. One moment it would sound good, next moment not. So I pulled out the EQ to correct the response errors. I used both the on-axis response strategy and PIR. Neither were effective across more than one track in controlled blind testing. I would think I had an improvement, go to the next track and perform blind AB test and would like no EQ better. Very frustrating.
I took a different strategy of playing a bass heavy track and then listening to the radiator and woofer by themselves (I blocked the tweeter with my hand). The radiator was definitely falling apart with sub-bass at any above medium playback level. Trying to fix that, I dialed in simple but sharp high-pass filter:
You would think you lose bass this way and you do a tiny but the overall impression was one of reduction in brightness!!! How is that possible? Again, I cupped my hand over the tweeter and listened to the woofer alone. With the filter in place you just hear warm bass. Turn the EQ off and it develops a sharper overhand which is likely due to severe harmonic distortion (higher order ones). With the filter in place, I lost any ability to play sub-bass but overall outcome was universally good.
But how good? I swapped out the BRC for Revel M105 which costs a bit less. This is its spinorama:
Ah, what a transformation. Tonality, detail and larger spatial image was all fantastic. It even had more tactile bass than BRX (no EQ was used in the comparison).
$1,600 is a lot of money to charge for small bookshelf speakers. You best deliver great performance. Alas, I am not seeing that in the BRX. Not that it is terrible but that clearly enough engineering was not put in there to create great tonality. It presents a very complex soundfield that likely is difficult to EQ (manual or automatic) to boot. Is it terrible? No, not by any stretch. The deviations are small but collectively left me aggravated.
I can't recommend the GoldenEar BRX. It doesn't deliver a better experience than budget speakers well below its price.
  • GoldenEar BRX Frequency Response ASR.zip
enricoclaudio
Houston, TX - USA
Can’t open the review in my iMac nor in my MacBook Pro. Only opens in my iPhone.
dfuller
enricoclaudio
Houston, TX - USA
Fixed it. It was Bitdefender blocking it... Weird..
Spocko
Southern California
This is a review and detailed measurements of the GoldenEar BRX "reference" bookshelf speaker. It is on kind loan from a member and costs US $1,598.
I had to laugh at the title "high end Bookshelf Speaker", so this begs the question: at what point does one cross into "high end" territory?
dfuller
MSRP is $1598/pair not each. Easy to find these at 25-30% under MAP.
Well, a bit better at $1600 a pair, but still not great.
buzwork
Tacoma
As a comparison here are the Stereophile measurements.
With the ASR ethos of objectivity in mind, I really, really like the BRX despite Amir's measurements, although I probably shouldn't, apparently, heh. I have a pair of Revel M105 and I can't pick a favorite between the two. I also don't listen >90db in most situations which is where the BRX appear to really struggle.
I was really surprised to see this outcome. It's not terrible but I was certainly expecting better.
Thanks @amirm for the work you do for the community!
ROOSKIE
Minneapolis
Hmmm, just to many other/better options and these can't even rock out to make up for it all.
Oh well. How about that budget Monoprice next ;) (any Polk R100 or R200's been turned in to ASR?)
Really curious about it.
Anyway, this speaker is one that I'd love to see IMD testing on.
Maiky76
French, living in China
Hi,
Here is my take on the EQ.
These EQ are anechoic EQ to get the speaker right before room integration. If you able to implement these EQs you must add EQ at LF for room integration, that is usually not optional… see hints there: https://www.audiosciencereview.com/...helf-speaker-review.11144/page-26#post-800725
The raw data with corrected ER and PIR:
Score no EQ: 4.5
With Sub: 6.9
Spinorama with no EQ:
  • Not Flat
  • Not Smooth
  • Some resonances
  • Smooth DI good for EQ
Directivity:
Better stay at tweeter height
Horizontally, better toe-in the speakers by 10/20deg and have the axis crossing in front of the listening location, might help dosing the upper range.
EQ design:
I have generated One EQs. The APO config file is attached.
Score EQ Score:
with sub:
Code:
GoldenEar BRX APO EQ Score 96000Hz
November232021-113831
Preamp: -2.2 dB
Filter 1: ON HPQ Fc 55.91,    0.00,    1.30
Filter 2: ON PK Fc 172.24,    -3.69,    0.85
Filter 3: ON PK Fc 516.55,    2.37,    2.45
Filter 4: ON PK Fc 758.09,    -3.43,    1.33
Filter 5: ON PK Fc 1349.04,    -1.81,    5.09
Filter 6: ON PK Fc 3782.10,    -1.82,    6.88
Filter 7: ON PK Fc 4453.55,    -0.99,    2.87
Filter 8: ON PK Fc 12329.22,    -1.64,    0.90
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal rising directivity makes the tonal ascending ON, just listen off axis a bit.
Radar no EQ vs EQ score
Some improvements
The rest of the plots is attached.
  • GoldenEar BRX APO EQ Score 96000Hz.txt
Sancus
Not to nitpick, but it's a 6" driver with a pair of 6.5" radiators.
True. My bad, corrected.
And thanks for sending these in. We always learn more, good or bad.
buzwork
Tacoma
I knew purchasing these, and sending them to Amir, would be a risky endeavor since they're really an unusual design. I gave them a good month of listening and was very impressed with them. My subjective opinion was similar to those of Guttenberg, JA1, and Herb Reichert; they sound good. Even better after running ARC with a sub (both an SVS SB1000 and an SVS 3000 Micro). There are definitely some issues listening off axis or having the tweeters situated too high or too low but in my treated listening room in the basement I just can't find much fault with them. But, some people like Bose and I'm just an enthusiast with no particular qualifying background in audio, so there's that :)
