Help on Connections with New Desktop Stack
rochambeaux
With the help of these forums I did a lot of research and thanks to a certain online giant, auditioned a number of products to settle on my first stack.
I'd appreciate recommendations on how to connect the stack based on my output devices:
TurtlePaul
New York
I would probably use a pair of XLR y-splitter cables to connect the DAC directly to both amps. As long as the input impedance is fairly high on both amps, shouldn't be a problem.
XLR Splitter
The other option is XLR from the DAC to the headphone amp and 1/4" TRS jack to XLR cable from the headamp to speaker amp. Downside would be running your speaker signal chain through a bunch of extra op-amps, but it will still be transparent.
TRS to XLR
Of course, the real answer is whichever connection method doesn't cause ground loop hum.
JSmith
Algol Perseus
Connect your sources to the DAC via USB, Coax or Optical.
The SU-9 should output on both RCA and XLR. I would use XLR for whichever I use more frequently, the headphones or bookshelf speakers.
So if speakers are used more, XLR to power amp then speaker wire to speakers. RCA to headphone amp and headphones plugged into same. The headphone amp also appears to have a "ground lift" (hope that's safe) if any hum on RCA.
JSmith
R
rochambeaux
JSmith
Thanks.
Could I go DAC XLR -> Headphone Amp XLR In, Headphone Amp TRS BAL out -> Amp XLR In -> Speakers?
I think the Topping has passthrough?
JSmith
Algol Perseus
Thanks.
No worries.
Yes, if the Topping has passthrough (which now you mention it I think it has), however it may only passthrough without applying any amplification when powered down.
JSmith
Moonhead
Denmark
Exchange Dali for some proper active speakers could be an option to.
