Dear Members,
I need an advice which device you recommend as a main input/output system for my living room.
As you can see on the attached drawing, I have a multiple devices which I'm trying to connect together and use speakers as a main sound out.
The goal is to:
- use one remote (preferably Apple TV 4K remote) to change volume regardless of which device is in use.
ex. when I use gramophone I should be able to change volume with the remote. The same should applies to PS or Apple TV.
- keep the best possible sound quality - keeping amplifier and speakers
- it would be great if I could steam the same audio out to the other room via Airplay to BW speaker (not mandatory)
I believe I need to replace the analog/digital converter with a preamp with HDMI and toslink IN and HDMI, RCA OUT with IR for remote, to which all devices should be connected to, but I'm not sure...
All advises appreciated, have a nice Sunday!
Budget max $1000.
Drawing below.
The goal is to:
Budget max $1000.
Drawing below.
