Hifiman HE-560 V4 Review (Planar Magnetic Headphone)
Rate this headphone:
    Votes: 7 5.8%
    Votes: 42 34.7%
    Votes: 54 44.6%
    Votes: 18 14.9%
This is a review and detailed measurements of the Hifiman HE560 V4. It is on kind loan from a member. I think it is exclusive to Adorama (?) and costs US $899 but goes on sale for $260 or something like it.
The look is similar to other Hifiman headphones:
Comfort was good with about average weight:
Cups are symmetrical and round with diameter of 61mm and depth of 23mm.
The included cable is short and rather stiff, terminated with 3.5mm plugs so easy to replace.
Note: The measurements you are about to see are made using a standardized Gras 45C. Headphone measurements by definition are approximate and variable so don't be surprised if other measurements even if performed with the same fixtures as mine, differ in end results. Protocols vary such as headband pressure and averaging (which I don't do). As you will see, I confirm the approximate accuracy of the measurements using Equalization and listening tests. Ultimately headphone measurements are less exact than speakers mostly in bass and above a few kilohertz so keep that in mind as you read these tests. If you think you have an exact idea of a headphone performance, you are likely wrong!
The large cups made an easy job of mounting them on my fixture and getting good measurements on first try.
Hifiman HE-56 V4 Measurements
Let's start with our usual frequency response measurements:
Hifiman HE560 V4 Measurement Frequency Response Open Back Planar Magnetic Headphone.png
This is fairly typical Hifiman response with flat bass and droop above 1 kHz. The latter though is more than some others I have tested and is dissipating to see. It will not only impact tonality but also spatial effects. But overall not too bad.
Relative frequency response graph useful for development of EQ is:
Hifiman HE560 V4 Measurement Relative Frequency Response Open Back Planar Magnetic Headphone.png
Developing EQ should be simple given the shape of shortfalls.
Distortion is very low which is nice:
Hifiman HE560 V4 Measurement Relative Distortion Response Open Back Planar Magnetic Headphone.png
Hifiman HE560 V4 Measurement THD Distortion Response Open Back Planar Magnetic Headphone.png
Group delay is messy as is usually the case with these headphones:
Hifiman HE560 V4 Measurement Group Delay Open Back Planar Magnetic Headphone.png
Impedance as usual is flat and low:
Hifiman HE560 V4 Measurement Impedance Response Open Back Planar Magnetic Headphone.png
It does require fair bit of juice to get loud:
You definitely need a good headphone amplifier to drive it.
Hifiman HE560 V4 Listening Tests and Equalization
Without equalization the sound is not bad. It sounds light on its feet due to lack of bass energy. I turned on my HE400i EQ and it instantly elevated the performance a few notches. I refined it more for the 560 response and landed with this:
Hifiman HE560 V4 Equalization EQ Parametric Open Back Planar Magnetic Headphone.png
Once there, spatial qualities were excellent and overall tonality very good.
I honestly can't keep track of why there are so many models in the hifiman lineup. What is here seems to have been tweaked just a bit in the wrong direction. Fortunately with low distortion, equalization can compensate. Once there though, I did not want to listen without it. So this means you need to have EQ with you in all of your uses which can be inconvenient if you use a platform that doesn't support.
Overall, I can't recommend the HE560 V4 at its retail price. Fully discounted it is not bad but there are better choices from the company at even lower costs (HE400SE). Still equalization does it a lot of good and with it, I can recommend it.
  • Hifiman HE560 V4 Frequency Response ASR.zip
sweetchaos
The Curator
BC, Canada
To import this PEQ profile into 'Equalizer APO', use:
Preamp: -7.0 dB
Filter 1: ON PK Fc 20 Hz Gain 6.0 dB Q 1.0
Filter 2: ON PK Fc 37 Hz Gain 1.8 dB Q 1.0
Filter 3: ON PK Fc 1800 Hz Gain 7.0 dB Q 3.0
Filter 4: ON PK Fc 5870 Hz Gain -2.0 dB Q 5.0
Otherwise, see my PEQ guide.
For those who don't have PEQ-capable app, and want to use GEQs instead:
See my GEQ guide for 10-band, 31-band, and 127-band GEQ profiles.
sweetchaos
The Curator
BC, Canada
solderdude
The Neitherlands
Below the HE560 V1
and below the HE560 V2
For comparative reasons the HE400SE v2 ,which has a small treble peak the HE560 don't have but 4kHz is at a better level (hardness of the sound area)
The looks of the V4 are very different from that of the V1 and V2 (also around $ 900)
filo97s
Sestri Levante
Would be nice to see if they differ from older versions like the 560 V3 in THD (the one in teak with 2.5mm connectors, which I have)
Still, if you like the sound signature, I would say that the extremely low distortion is perceived here, it's a very very crisp headphone. One thing that I complain to HiFiman is its typical worst build quality to date among headphone makers. Everything is shit: the pads, the plasticky headband, the cups made out of fake wood, the cable, even the box where they came in... It's better a 130$ DT770 pro than this, construction-wise. And this annoys me since they cost well over 800$.
Harmonie
France
I hate that Adomara does this....:mad:
Here's the regular advertised price:
Here's the actual price (just add ?emailprice=t to the end of the normal URL):
Oh look at that, savings of 75%...magic!
Most of you should know this by now, but for a few that don't...;)
Honestly I wasn't aware about such trick, merci !!!
I would now put ?emailprice=t in every url of any website and hope to get some 75% magic all year long ...
Jimbob54
Below the HE560 V1
Ahhhh, the horrid connector used by the v1 is an absolute horror. Nice headphones though. Ridiculous headband.
edahl
Below the HE560 V1
Tha wooden cup look is just so badass in comparison
PeteL
So we know the "actual" price, what's the regular price?
Aperiodic
I feel sorry for anybody that gets ripped off like that. People are going to get pissed off and rightly so. Makes me want to avoid Adorama.
tomtrp
Really want to see Amir's measurement for the HE6SE V2 (he6se adorama) to help develop better PEQ. Hope some dear ASR friends in US can send theirs to Amir for measurement.
_thelaughingman
solderdude
The Neitherlands
These similar looking hifiman model headphones is probably what Amir meant.
