Hifiman Sundara Review (headphone)
Music1969
Hi @solderdude
Are planars less susceptible to driver damage due to excessive volume, than dynamic ?
What is their mechanism of damage with high SPL ?
And what are the signs/symptoms ?
I plugged into a DAC/amp and didn't realise the volume was at max 0dBFS - I had paused music volume beforehand but music app did not respect my pause !
Lucky cans were not on my head.
They actually sound fine atm - haven't heard any issues with any songs.
But I'm worried if there was some minor damage still.
solderdude
The Neitherlands
Hi @solderdude
Some have a much higher power rating, but there are also planars with a less impressive power rating.
Dynamic headphones power ratings range from 20mW to a few Watt.
Excessive power, DC on the driver, for dynamics the wires from the coil to the chassis are the vulnerable parts both mechanically (think Focal) and electrically.
When a voicecoil has overheated chances are the former or lacquer on the wires is bulging which could result in distortion, severe loss off bass (when stuck in the air gap) right down to open circuit.
For planars the contact area between the membrane's traces and chassis can be a nuisance. In this case intermittend or much softer sound or distortion can be tell-tale signs.
As decribed above.. from loss or distorted bass, 'sounds/noises' that should not be there, loss of SPL to no sound.
If the sound is fine then it is O.K. You can test with a 20Hz tone, there should be no difference between L and R. Some headphones that are O.K. will have noise or 'ticking' sounds. Drivers rarely damage in the exact same way so when there are no obvious differences between L and R side you are probably O.K.
Highly depends on the model headphone. Some can almost be used as desktop speakers while others are destroyed by it.
I expect the Sundara (most hifiman and Audeze) to be able to take some electrical beating, certainly with music. I suspect 2W is not an issue.
Continuous power (noise, sine waves, sweeps) are more likely to cause damage than music as that consists mostly of peaks.
Music1969
This was a Pro-Ject Pre Box S2 DAC playing music (only 5 seconds) at 0dBFS
"Headphone output power : 6.6 mW / 600 Ohm; 68 mW / 32 Ohm"
So it was probably around that 68 mW figure for Sundara but less with music
Sundara is approx 90dB /mW so that would have been loud lol ?
I'll try the 20Hz tone test you suggested.
Thanks!
solderdude
The Neitherlands
I would not bother. The S2 cannot blow up any planars. There cannot possibly be any damage.
When doing the 20Hz with this headphone amp the amp will very likely clip before you reach an audible level leading you to believe the Sundara may be damaged.
That simply is not possible with these power levels. At 68mW the Sundara will reach 111dB.
Music1969
I played 20Hz tone (mono) with Sundara connected to SMSL SP400
100Hz, 80Hz, 60 Hz, 40 Hz - everything sounds 'centered' playing mono - no shift to either side, which is good.
25 Hz is not possible to hear anything lol
I'm using oratory's EQ which boosts the stock Sundara bass.
solderdude
The Neitherlands
That's why the 20Hz tone. When you hear 'something' it should not be there but... the danger lies in giving it too much power.
Do not try this with IEMs and 20mW or 50mW headphones though !
Also try a 100Hz tone first (at loud volume, shortly) and then without changing the volume try the 20Hz.
The S2 is technically incapable of inflicting any damage to the Sundara.
Music1969
Ok just did this and nothing at 20Hz - good sign
Thanks! With this info + the test, I won't bother returning Sundara.
I had problem with channel imbalance with HE400se and upgraded to Sundara and this has no such issues.
I don't want to return this Sundara for another which may have issues.
Music1969
So I looked at Sundara 2020 measurements of Amir , Sean Olive, Crinacle, Oratory
And came up with the following EQ.
Feel free to give it a try.
An example - look at Amirm's measurements and his EQ. He doesn't eq 100-150Hz gap. And his peak at ~6kHz isn't on any others so I took that out.
Also oratory's EQ at 6.6kHz and 8.8kHz is too "exact" - maybe for his actual headphones it's correct but the autoEQ based on crinacle basically averages this region out, which I like and it still fits all other measurements.
Also didn't like how amir EQ's the critical region around 2kHz and above. AutoEQ crinacle and oratory did that region better (similar measurements), so I combined the best
Anyway here it is. It's basically to capture the main gist of all those above mentioned sources and eliminate the more peculiar EQ.
Can still follow oratory's recommended for more bass adjusting band #3 gain and more treble with band #7 gain
Preamp: -11.0 dB Filter 1: ON LSQ Fc 28 Hz Gain 6.00 dB Q 0.71 Filter 2: ON PK Fc 66 Hz Gain -0.80 dB Q 1.50 Filter 3: ON LSQ Fc 105 Hz Gain 5.50 dB Q 0.71 Filter 4: ON PK Fc 940 Hz Gain -1.0 dB Q 3.70 Filter 5: ON PK Fc 2250 Hz Gain 3.30 dB Q 1.40 Filter 6: ON PK Fc 6105 Hz Gain 2.2 dB Q 1.50 Filter 7: ON HSQ Fc 10000 Hz Gain 0.0 dB Q 0.71
Music1969
I suggest to also lower 10kHz by approx. 6dB.
This 'smoothes' the treble.
I tried to make a simple 7 band EQ that would work across Amir, Sean Olive, oratory, crinacle measurements. And eliminating the filters that might be sample specific.
But all their measurements have a big dip at 10kHz in their measurements
solderdude
The Neitherlands
Yes, that is because all those measurement fixtures have a dip there (compare all measurements of all headphones there) so that 'obscures' peaks there.
Those fixtures should not be used above 8kHz.
The peak is really there though. Give it a try and see how the treble looses some of the 'sharpness' or 'metal sheen'
Music1969
Will give it a try. So add a peak filter at 10kHz -6dB gain - what Q value you recommend ?
Q = 3 ?
solderdude
The Neitherlands
I don't really know... I never use digital EQ.
Leiker535
Q = 3 ?
Try using Crinacle's EQ function in his measurement tool to estimate that. That, a comparison between other 43C measurements, like Oratorys, and your own ears should land you on the sweetspot of EQing.
Music1969
6dB sounds quite different.
3dB down immediately does sound better for me.
I think my ear/brain needs to a couple weeks to get used to this 3dB drop first, before I attempt another 3dB drop
Burn-in of the ear/brain is real ! :D
Definitely a smoother experience , thanks for this tip
Preamp: -11.0 dB Filter 1: ON LSQ Fc 28 Hz Gain 6.00 dB Q 0.71 Filter 2: ON PK Fc 66 Hz Gain -0.80 dB Q 1.50 Filter 3: ON LSQ Fc 105 Hz Gain 5.50 dB Q 0.71 Filter 4: ON PK Fc 940 Hz Gain -1.0 dB Q 3.70 Filter 5: ON PK Fc 2250 Hz Gain 3.30 dB Q 1.40 Filter 6: ON PK Fc 6105 Hz Gain 2.2 dB Q 1.50 Filter 7: ON PK Fc 10000 Hz Gain -3.0 dB Q 4.00 Filter 8: ON HSQ Fc 10000 Hz Gain -1.0 dB Q 0.71
Music1969
@Music1969 I tried your EQ
Nice! Just a reminder it's based on trying to find something simpler that fits all of Amir's, Sean Olive's, Cirnacle's, Oratory's and Resolve's measurements as best as I could eye-ball. And now @solderdude 's too since others don't show any 10kHz peak.
I stayed away from any personal sound quality preferences
Like oratory recommends, use bands #3 and #8 to adjust bass and treble to taste (just change gain value)
I changed filter 7 Q to =4
Music1969
Hi @solderdude @Robbo99999
I measured my Sundara - this is with multiple re-seats and right channel has some funkiness between 8-10kHz
Based on this, would you return this pair if you had the option?
Or does this look normal?
There's 3 right channel measurements, each done with complete re-seating.
solderdude
The Neitherlands
Measure another headphone as well.
When you did this on the EARS keep in mind that the drivers are slightly angled (the pads) and that the response might differ from normal measurements due to the pinna.
But as staticV3 already said if the differences swap drivers it is likely the fixture.
You can also try to verify the measurements by listening, for instance to a sweep or white noise. Such a broadband 10dB dip should be audible if it is really there.
