- Joined
- Oct 25, 2019
- Messages
- 11,137
- Likes
- 14,811
Only the ones that are clearly nonsense. Is it soft and smooth or clean and sterile? You don't think they are opposing and contradictory? Back to audiophile school.Which part ? I forgot to add " to "transparent" word there. If you check out what i replied(quoted) you will understand the context. Most gear have inaudible distortion noise and flat fr so all them are transparent on paper.
If you are asking my second usage of transparent i was describing the bass there. Bass doesnt mask the overall music.
Those descriptors are not opposite. I see you pop up under every subjective comment and try to bash it with ridiculous arguments. Chill out. If you think every piece of gear sound same thats cool.
EDIT- and while we are at it- what do you mean by transparent "on paper" ? And how can it be a good amp that sounds bad? You called someone for BS that said it was transparent, uncoloured clean power (which it is, which means it imparts no characteristics to the sound) then proceeded to pour nonsense over everything. There is a reason that such comments tend to draw a bit of flack here - they are the antithesis of a measurement led site. I dont think everything sounds the same- but the 789, the L30, etc etc simply have no sound.
You're entitled to your subjective opinions, we all have them- but dont be surprised to get called on them when you express them - especially when rebutting someone that makes a comment grounded in the facts.
