ifi Zen Phono Review (phono stage)
Rate this phono stage:
    Votes: 14 9.4%
    Votes: 66 44.3%
  • 3. Fine (happy panther
    Votes: 54 36.2%
    Votes: 15 10.1%
This is a review and detailed measurements of the ifi Zen Phono pre-amp. It is on kind loan from a member and costs US $199.
As you can see, it comes in a similar case to other (newer) ifi line. And as with those, the white labels are not legible in all but one or two angles. The left switch is power which has a delay in it (?). The right switch is a sub-sonic filter. The four dots are LED indicators for the four separate gain settings which you can select in the back:
Power is provided by an ordinary (non-ifi) 5 volt supply. Internally this is stepped up using a very high frequency switching regulator (running at 1.5 MHz). This should do away with mains spikes we see in many phono stages.
An unusual output is the 4.4 mm penticon balanced output. This is a very unusual connector for anything but headphones. It is nice to see it though if it provides a benefit in the form of cutting out ground loops. Internal architecture is balance as well (I think).
Company provides extensive measurements/specifications compared to what we typically see and speaks a lot to the low noise of the unit.
ifi Zen Phono Measurements
I stayed with the gain setting 1 which is suitable for Moving Magnet cartridges. Here is our dashboard using 5 mv input:
The spectrum of our 1 kHz signal is extremely clean. It is free of both power supply and distortion spikes. You would expect SINAD to excel but it does not:
The reason it doesn't is that noise floor is rather high. This did not add up with company specs/brochure and member comments about it being quieter. So I emulated one of the company SNR measurements:
As you see, I am very close to their specs/measurements. Balanced output does not help:
You can see the elevated noise level in this measurement and comparison:
Our top of the line pre-amps have far lower noise floor in low frequencies.
Distortion is also rather high when we discard noise from it:
On the other hand, the RIAA equalization is the best I have ever seen/measured:
It is essentially ruler flat!
On subsonic filter, I am measuring its static response. It may do better in practice due to "AI" logic that it say sit has.
Headroom shrinks sharply as frequencies increase which is unfortunate:
ifi zen phono measurements THD vs Level vs Frequency unbalanced stage MM MC.png
There is also increased distortion with frequency which is something I don't normally see.
Going into this review, I expected to see excellent measurements across the board. But this did not come to pass as far as noise and distortion. However, RIAA implementation is superbly accurate and this is something you will hear. On the strength of this, I am going to recommend the ifi Zen Phono pre-amp.
Leiker535
Ouch, I had expected this to measure as high as the Schiit Mani 1/2 given the reviews, unfortunately not so. Mani 2's still king of the hill spec and feature wise as I see it then. The bal out option sure is nice though.
Also, thank you amirm for doing the pre phono reviews, you surely did made a mystical niche more clear and objective. Only thing left for me in this medium now is seeing accomplished chi-fi companies trying their best within it, as there is certainly room for it.
respice finem
The Germans say "was wollte uns der Künstler denn damit sagen"? = whatever the Artist wanted to tell us with this...
antcollinet
UK/Cheshire
Hi @amirm Thanks for the review.
your last chart seems to show THD+N with generator level, but the text states frequency.
Is this correct?
Is this correct?
Yes because each line is for a different frequency.
daftcombo
Nice review, thanks Amir!
Should these noise and distortion be audible with actual records?
The record grove noise and distortion will be quite high by itself. And the noise is loaded in lower frequencies where we are less sensitive. So probably not. I let owners give real-life answers.
deniall83
Australia
Thanks for your review. As someone who owns this unit, I'm very surprised. Mine was much quieter than the phono stage in my Yamaha amp and I just assumed (wrongly so) that it would measure well.
Is the Cambridge Solo (or Duo?) still the one to beat then?
GWolfman
Nice to see no power supply noise, but maybe it's hiding just under the (elevated) noise floor.
JeremyFife
Scotland
Many thanks for the review, I've been hoping this would come up as I have one of these.
Noise and distortion figures are disappointing - especially given the balanced output.
Subjectively, mine sounds pretty good (not aware of added noise above what I'd expect from vinyl anyway!) i.e. no audible artefacts to my ears.
I'm happy with my unit, especially for the money so no need to change, but I'd have thought twice (thrice) if I was buying now.
This site is a great resource.
MCH
Balanced out!
What is people's opinion on the headroom? Seems impressive until 5kHz and then starts to drop... what are the frequencies for which this is most important? Seems to me that a typical click/pop is in the middle low frequencies (by ear but no idea...)
Chester
Another great review, thanks.
I bought one of these as I was hearing so much noise (no pun intended) about them. When I plugged into my RME ADI-2 Pro though, couldn’t get the noise floor below -60dB, compared to my Pro-ject and Cambridge Duo who were both around -74dB to -79dB.
I thought it was something particular about my setup but this makes sense now.
DSJR
Suffolk Coastal, UK
The input level 'standard' I'm sure, used to be 5mV, so I'm disappointed that they tweaked the levels to 15mV to get their stated specs instead.
I'd also add that one way to help the ear disregard vinyl clicks and pops (in addition to a top quality finished stylus and good generator design), is to have hf overload margins as high as possible and without ringing when it does overload (which I believe could be a problem back in my day). Some vinyl systems do actually fool the listener into thinking they're 'quieter' than they are in terms of vinyl roar and noise, purely I believe, because there's no nasty reaction to clicks and snaps when playing..
It's currently still a growing market, this 'new fangled old fashioned vinyl thang,' so like it or not, it's here to stay for a good long while and pressing plants are apparently opening up again or being created from scratch (deliberate pun). The albums I sold for a quid each - worth a small fortune now as many were first presses too :(
Endibol
Thanks for the review Amir, quite interesting. since I own this unit. I am happy to see that the RIAA equalization is very good. SINAD is somewhat disappointing, but I think that this is of less importance for my old ears than the flat frequency curve.
@amirm A question concerning your last THD+N curve. The input generator range goes from approx. 5 to 170 mVrms. My MM cartridge has a spec of 3mV output. So I wonder why this curve is really relevant in this case.
One comment about the sub-sonic filter. I think it does do its job: It substantially reduced the very low (around 1 Hz) frequency scary high amplitude cone movement present in Joe Henderson's track "Recorda Me" from his album "Page One" (Blue Note AAA ST-84140, mastered by Kevin Gray). This extreme movement by the way was not present on the "Spotify" version of this track.
SMen
I have this phono stage and it's a pity in a way that Amirm did not test the higher gain settings. For me the lowest gain MM sounds rather 'warm' (the noise floor measured perhaps?) and so I wondered if it had been tailored in some way for this by Ifi.
The next higher gain up (for high output MC's) sounds much, much cleaner - which is not an intuitive result! Surely the noise would be more intrusive as you increase the gain?
I am only going on the subjective comparison of a very high quality lower output MM (same as a high output moving coil) through both the 2 lower gain, MM compatible settings - including the one measured.
It almost sounds as if 'noise' is bypassed as you switch to higher gain. This might be an interesting discovery if you felt like investigating as it's a conundrum for me :).
Delighted and not surprised to read about the ruler flat RIAA. I actually find the lowest gain (standard MM) rather warm sounding, and quite different to the next setting up.
