Can anyone give me some advice on some inexpensive adhesive or non-adhesive isolation pads that won't ruin either the surface it's on or the bottom of the speaker? What are folks using to put a center channel speaker on a double metal bar under a TV for example I'm imagining and have seen some speakers come with little silicon or rubber discs.
If you have a link to the items that you recommend on Amazon that would be great. Many years ago I bought some moderately expensive isolation rubber discs and they completely ruined the bottom of my monitor audio center speaker. It was as if it bleached out a circle on the bottom and I can't have that with my pretty revel M16s.
Thanks in advance for any thoughts on the subject.
Edit. I also don't trust the rubber pieces that come with the wall mounting kits to not screw up the finish on the cabinets. I am trying to use the wall mount kits to move the speakers up a bit to ear level and just outside the boundary of the TV. Stands simply won't work with the space and having little kids unfortunately.
