TheBatsEar
Germany
Anyone interested in looking inside Yamaha amps? I have a bunch in my collection, most of them need repair, all of them have to be opened eventually for dusting.
I'll start with some pictures i made inside a A-S1000 that i bought for 500€ in mint condition. This one weighs 25kg, it's a serious amp. For example, if you move the bass knob from 0, a relay clicks and adds it into the signal path. A bit of dust inside and a black sharpie marking on the volume knob was all that was wrong with it. The amp was about 11 years old when i got it, i eventually ugraded to a A-S1200 and sold this one for 600€. To me it sounded just as good as the A-S1200, but lacks standby and VU meters.
Not a scratch. Very large, heavy and deep:
Wood panels in piano finish:
Brass terminals:
There is a thick metal bridge that makes sure the amp reaches peak robustness:
The amp is made almost fully symmetric. The yellow stuff on the transformer bugged me a bit, it was hardened lacquer. Every cable is tied down with cable ties. Nothing can move.
Yamaha labelled caps, made by Nippon Chemi-Con Corporation, the largest manufacturer of electrolytic capacitors (not to be confused with Nichicon):
From left to right, bass, treble, balance and volume. The ICs don't get energy as long as the treble is set to 0 for example. If you change the treble to +1 or -1, a relay clicks and powers those chips. The volume knob doesn't change the volume, but gives a resistor value to this board, which then changes the volume. Should be easy to repair once the variable resistor goes bad in 20 or so years:
And here the left channel power amp:
Since i don't have the device anymore, i can't make new detailed pics, but i can of course give details on what you can see here. I had to heavily shrink the pictures down.
If there is interest, tell me, next would be a comparison of Yamaha A-S501 and A-S701.
I also have the R-S202D, A-S300, RX-300, A-550, RX-10, AX-10 and of course the A-S1200.
TheBatsEar
TheBatsEar
Germany
Index so far:
Yamaha A-S1000:
https://www.audiosciencereview.com/forum/index.php?threads/inside-yamaha-amps.21894/post-726711
https://www.audiosciencereview.com/forum/index.php?threads/inside-yamaha-amps.21894/post-1266636
Yamaha A-S1100:
https://www.audiosciencereview.com/forum/index.php?threads/inside-yamaha-amps.21894/post-1664938
Yamaha A-S1200:
https://www.audiosciencereview.com/forum/index.php?threads/inside-yamaha-amps.21894/post-1664900
Yamaha A-S300:
https://www.audiosciencereview.com/forum/index.php?threads/inside-yamaha-amps.21894/post-1649160
Yamaha A-S301:
https://www.audiosciencereview.com/forum/index.php?threads/inside-yamaha-amps.21894/post-790066
Yamaha A-S501
Yamaha A-S701:
https://www.audiosciencereview.com/forum/index.php?threads/inside-yamaha-amps.21894/post-733622
Yamaha R-S700:
https://www.audiosciencereview.com/forum/index.php?threads/inside-yamaha-amps.21894/post-1156780
Yamaha A-S801:
https://www.audiosciencereview.com/forum/index.php?threads/inside-yamaha-amps.21894/post-1174413
https://www.audiosciencereview.com/forum/index.php?threads/inside-yamaha-amps.21894/post-1675941
https://www.audiosciencereview.com/forum/index.php?threads/inside-yamaha-amps.21894/post-1692324
Yamaha AX-890:
https://www.audiosciencereview.com/forum/index.php?threads/inside-yamaha-amps.21894/post-1156788
Yamaha AX-10:
https://www.audiosciencereview.com/forum/index.php?threads/inside-yamaha-amps.21894/post-1156740
Yamaha R-S202D:
https://www.audiosciencereview.com/forum/index.php?threads/inside-yamaha-amps.21894/post-1168495
Yamaha RX-A1010:
https://www.audiosciencereview.com/forum/index.php?threads/inside-yamaha-amps.21894/post-1169307
Yamaha AX-1050:
https://www.audiosciencereview.com/forum/index.php?threads/inside-yamaha-amps.21894/post-1169398
Yamaha P3200:
https://www.audiosciencereview.com/forum/index.php?threads/inside-yamaha-amps.21894/post-1266648
Yamaha MX-630:
https://www.audiosciencereview.com/forum/index.php?threads/inside-yamaha-amps.21894/post-1266708
YAMAHA A-S3000:
https://www.audiosciencereview.com/forum/index.php?threads/inside-yamaha-amps.21894/post-737010
Yamaha MX-A5200:
https://www.audiosciencereview.com/forum/index.php?threads/inside-yamaha-amps.21894/post-1169656
Yamaha P7000S:
https://www.audiosciencereview.com/forum/index.php?threads/inside-yamaha-amps.21894/post-1443338
Yamaha CA-VI:
https://www.audiosciencereview.com/forum/index.php?threads/inside-yamaha-amps.21894/post-1576180
Yamaha MX-70 aka MX-800U:
https://www.audiosciencereview.com/forum/index.php?threads/inside-yamaha-amps.21894/post-1615607
Yamaha P2200:
https://www.audiosciencereview.com/forum/index.php?threads/inside-yamaha-amps.21894/post-1671901
Yamaha R-S300:
https://www.audiosciencereview.com/forum/index.php?threads/inside-yamaha-amps.21894/post-1679612
Yamaha R-N803D:
https://www.audiosciencereview.com/forum/index.php?threads/inside-yamaha-amps.21894/post-1692376
TheBatsEar
TheBatsEar
Germany
reserved
TheBatsEar
TheBatsEar
Germany
Made 100€ profit, so that's ok. When i bought it, the seller had a CD-S1000 for 200€ more. The door wouldn't open. of course i took it. There was just a string that transports the door, which slipped from a roll. Fixed it in 5 minutes. Kept the player so far for my SACDs.
The rack cost me 24€ (three Ikea Lack for 8€ each). What a bargain ;-)
trl
King of Mods
Iasi, RO
trl
King of Mods
Iasi, RO
You really seem to like the Yamaha luxury devices. :) They're really pretty indeed...and good sounding.
MakeMineVinyl
Santa Fe, NM
A lot of wires! :)
I find typical Japanese gear to be a rat's nest of wires - too many wires not very well dressed or thought out. And their circuit boards tend to be a bit messy too. Of course not that many end users look inside, and don't care.
Reactions: pma
TheBatsEar
TheBatsEar
Germany
Well, i sure do like them. Have never heard them referred to as luxury devices however. But i guess it's not wrong. I'm sure there are other worthy japanese brands, but somehow i always liked Yamahas stuff the most.
Also, as you can see partly, i have a bunch of tapedecks, cd players, turntables, and tuners from the 70ies and 80ies with matching design. Even their cheap network streamer NP-S303 fits in.
pma
Prague
It may worsen S/N and distortion. And when I googled some reviews, the reviewers complain of lack of details and impact, so it may be the case.
MakeMineVinyl
Santa Fe, NM
At the least, the variability of how the wires are routed from unit to unit can give rise to different units measuring differently with things like crosstalk, distortion and such. If most signal carrying routes are cast in stone by being part of a PCB, then there is less likelihood of unit-to-unit variation.
mhardy6647
They're better than they used to be.
This is a mid-1960s Pioneer SX-34B (push-pull 6BM8 stereo receiver), in its Allied Radio Electronics "Knight 333" morph. I replaced coupling caps in this one -- it was a bit of a challenge to find coupling caps that fit.
I like to say say of the typical 1960s (point to point) Japanese hifi hardware - it looks like the result of a dog ingesting a closetful of wire and then barfing it up. :rolleyes:
Knight333underneath by Mark Hardy, on Flickr
MakeMineVinyl
Santa Fe, NM
Almost all of the older tube gear tended to be a rat's nest, including some professional stuff - Exhibit A: my Ampex 354 professional tape machine's electronics. It at least used a PCB, but the wiring was still a mess, and a pain to work on.
mhardy6647
Not all of it.
Fisher 400 receiver (before refreshing)
Richards400belowbefore by Mark Hardy, on Flickr
Marantz 8B power amplifier (before refreshing)
Marantz8Bbefore by Mark Hardy, on Flickr
McIntosh used, what do they call them, turretboards(?) for their p to p wiring.
(also a before refreshing image, of an MC-225, but not my photo -- borrowed from AK)
TheBatsEar
TheBatsEar
Germany
What's beauty to the spider, is chaos to the fly.
TheBatsEar
TheBatsEar
Germany
Well, i reserved empty posts at the top, but i can't edit them anymore, so they are lost now.
Anyway, here is a comparison between Yamaha A-S501 and Yamaha A-S701. They are in the midst of Yamahas consumer line. There is a smaller model A-S301 (less power than the A-S501) and a larger model (A-S801 has USB input).
This is what they look like, 501 on top of the 701:
Really nice for the money, the enclosures are almost the same:
Only one difference on the front:
The 701 has a CD direct amp path, which means there are a few more parts inside, as you can see later.
The backside, A-S501 on top:
As you can see, the removeable power cable is purely cosmetic, it lacks ground connection. The HIGH/LOW impedance switch should be at high at all times. At low the amp uses a winding on the transformer that outputs a few volts less. Not sure what the point is.
Digital input board, top is A-S501, bottom is A-S701. they are the same. Sadly, the quality of the image is bad. Prominent is the large heat sink for the 5 volt USB power supply:
Time to show the goods, A-S501 on top:
Input section, A-S501 on top. Red plastic insulation, the A-S701 has white insulation:
On the lower right, the A-S701 has more parts. I think that is the "CD direct amp" path.
Power amp board, A-S501 on top:
Different power transistors, A-S501 on top:
That's it, hope you enjoyed the pics.
Should i do the A-S1200 or A-1020 next?
TheBatsEar
TheBatsEar
Germany
Thanks mate, i'll try. :)
MakeMineVinyl
Santa Fe, NM
They sure go to a lot of trouble to avoid the use of double sided circuit boards with all those jumpers. I can't imagine the extensive use of jumpers is any cheaper, or perhaps they have another rationale? Some of the jumpers appear to be bypassing unused features in un-populated areas of the PCB.
