JP
Would be interesting to see some tracking tests.
Sorry, I don't have a good test record for that.Would be interesting to see some tracking tests.
Is this more of a separate thread? (VTF should affect centering of armature and thus crosstalk.Lowest is ideal VTF.)VTA effect on Crosstalk
Here's something interesting for you all that shows up well in measurements. Plus it doubles as a sneak preview of some very interesting cartridge measurements that are coming up.
New member @melloncolliecat has been kind enough to let me share these work-in-progress measurements as he makes final adjustments. He had been using a CBS STR-100 Issue 1 that had some issues and generously purchased a CA-TRS-1007 this week, which will provide us really nice results. So round of applause.
The Empire 2000Z (a cartridge I really, really wanted to see) here has a recommended tracking force of 1g (range is 0.75-1.25g) but there seems to be some sort of compatibility issue as it results in a lot of clicks and pops. Perhaps it is the tonearm but we are not exactly sure. At 1g, it is particularly sensitive to VTA and so it is useful to see how adjustments can affect results. Results may not be typical and the take is obvious but it is all still good to see, stick to the recommended settings
This is an excellent and helpful thread! A lot of measurements of the popular VM540ML. Has anyone made a good comparison with the 530EN? And also with the 540 on one of the lower inductance bodies? Or even different low-inductance bodies, such as the AT5V vs the 150MXL?
Yes. It's the force but I thought I was saying A for adjustment. I can change it.@USER , Did you mean VTF and not VTA?
Here is my channel separation vs VTF for AT33PTGii on Ortofon test record 1kHz
On 2gram it tracks 80uM, 1.8gram 70um,
Some old recordings presented CA trs1007 track 1 and 9. NOTE too high low rumble filter active.Can you help me understand the lateral and vertical measurements?
In terms of the CA record, one question is if we can show different drop rates for different stylus shapes. If you are able to run some graphs from it I'd greatly appreciate it.
I posted my Red 2M earlierAnyone going to post any Ortofon OM / Super OM variants here?
I have some remarks on that:I run my Denon DP-35F balanced with a flat phono stage. If I don't take the strap off I get this in the upper frequencies with the Shure V15 V-MR. (I've since mitigated pretty much everything other than the 60Hz hum that's below -100dB with RIAA.)
Seems you use the E1DA Cosmos ADC. This is a great deviceI am waiting for the E1DA Scaler to come out ...
