JP
Yes, and magnets.
Yes - the stylus includes the magnets, the mounting mechanism, the suspension, the cantilever and the needle.I admit I don’t fully understand the components of the suspension versus the stylus.
The body of the MM cartridge lasts indefinitely, right? When you replace the stylus, you’re replacing the stylus, cantilever, and suspension in a single product, right?
Ortofon Super OM40
Notes:
- Crosstalk/azimuth set using Ortofon test record (sweep, below)
- Suggested load 140-250 pF and 39-47 kOhm
It is almost unused. It is also different with the Ortofon test record.What's the condition of the cartridges? The distortion above 5kHz is interesting.
So first of all, these measurements are excellent, but beyond my capability to do myself.
DENON DL-60 ORIGINAL?? ON DENON DP-51F
Sounds OK
- Cartridge: DENON DL-60 at 1.8g. Azimuth not optimized
- Stylus condition: unknown came with turntable bough form a widow. DL-60 cam with tie TT originally.
- Test record: Clearaudio TRS-1007 side A track 1&2 L/R stereo
- Turntable and arm: Denon dDP-51F Measured peak wow <0.06%. Dynemic Servo tracer arm coundteracts resonance
- Phono stage and loading settings: Cambridge CP2
- Capacitance and impedance:47kohm 310pF with cables
- Cable capacitance
- 80.pF accrong to Stereo review May 1982. +220pF RIAA.
- ADC: Tascam 144mkII
- Recording: no adjustment on balance, no Azimuth adjustment on cartridge, 96k
More will come as the thread gets more views and interest. You can help by pointing to it in other forums. No need to be preachy about it. I think people will come around. They just need to know that it is possible to measure cartridges.So first of all, these measurements are excellent, but beyond my capability to do myself. I'm personally not all that enthusiastic about searching for a used or NOS cartridge and sourcing a new stylus for it. I'd rather buy something off the shelf. So, I'm curious about the "modern" cartridges that are available through conventional audio dealers. I've seen comments about how the best ever made was right at the end of the vinyl era, but have we really proven with measurements that the currently manufactured cartridges are worse, better, or the same? I've looked at the third-party measurements are available, but the number of tests is not particularly large. Is there any appetite out there for measuring "modern" cartridges.
If I came across as preachy I very much apologize. Not my intention at all, and maybe i didn’t spend enough time composing my comments. I am very curious about how/if modern manufacturing and materials might yield improvements to performance.More will come as the thread gets more views and interest. You can help by pointing to it in other forums. No need to be preachy about it. I think people will come around. They just need to know that it is possible to measure cartridges.
I just ordered a Sumiko Pearl simply for the measurement. Might make a good cheap option. Crosstalk is spec'ed at -30dB and that hints at quality. Who loves you guys?
I didn't mean that you were being preachy. I just meant that bringing up measurements on vinyl forums is like dropping a grenade by your side. Best to be casual about it.If I came across as preachy I very much apologize. Not my intention at all, and maybe i didn’t spend enough time composing my comments. I am very curious about how/if modern manufacturing and materials might yield improvements to performance.
LOL, too late for that.I didn't mean that you were being preachy. I just meant that bringing up measurements on vinyl forums is like dropping a grenade by your side. Best to be casual about it.
When back from a bit of travel I plan to order a Grado Gold 3 for testing. Xtalk 35dB!More will come as the thread gets more views and interest. You can help by pointing to it in other forums. No need to be preachy about it. I think people will come around. They just need to know that it is possible to measure cartridges.
