DavidMcRoy
- Joined
- Jul 10, 2018
- Messages
- 580
- Likes
- 1,007
http://noaudiophile.com/JBL_LSR305/JBL_LSR305.txtFrom noaudiophile.com (see attachment)
Preamp: -2 dB
Filter 1: ON PK Fc 835 Hz Gain -2.2 dB Q 3.0
Filter 2: ON PK Fc 1110 Hz Gain 4.0 dB Q 6.0
Filter 3: ON PK Fc 1343 Hz Gain -4.8 dB Q 2.32
Filter 4: ON PK Fc 1620 Hz Gain 3.5 dB Q 6.0
Filter 5: ON PK Fc 2384 Hz Gain -1.4 dB Q 3.0
Filter 6: ON PK Fc 3650 Hz Gain 0.4 dB Q 6.0
Filter 7: ON PK Fc 5000 Hz Gain -0.5 dB Q 2.07
Filter 8: ON PK Fc 6987 Hz Gain 0.7 dB Q 3.0
Filter 9: ON PK Fc 8874 Hz Gain -1.7 dB Q 2.0
Filter 10: ON PK Fc 11851 Hz Gain 1.7 dB Q 3.5
Filter 11: ON PK Fc 15150 Hz Gain -2.7 dB Q 1.59
Filter 12: ON HS Fc 1000 Hz Gain 0.5 dB
I have one question. I just eqed the low freq to +15db. Is this a reasonable fix for the lack of subass? Or I will suffer from distorsion? Im hearing it okay. Is imperative to get a subwoofer if you can eq?
Sounds better. Can I harm the speakers? The 30-59hz region gainned more presence and its more balancedDon’t do it. The speaker isn’t designed to reproduce frequencies below 47Hz, I think. You’ll need a subwoofer.
I did it by hear. I hope in the future with a microphone I could do it better. No one eq the subass region?
Does anyone know if the LSR305 has some EQ preset somewhere?
Sorry, but I am a newbie in this field. What exactly does this mean?It has crossover and presumably JBL has preprogrammed some biquads in the amp chip.
https://www.st.com/resource/en/datasheet/sta350b.pdf
"Also provided in the STA350Bx are a full assortment of digital processing features. This includes up to 8 programmable biquads (EQ) per channel.
Special digital signal processing techniques are available in order to manage low-frequency quantization noise in case of very low frequency cutoff filter thresholds.
The coefficient range -4..4 allows the easy implementation of high shelf filters.
Available presets allow the advantage of earlier time-tomarket by substantially reducing the amount of software development needed for certain functions. This includes audio preset volume loudness, preset volume curves and preset EQ settings.
There are also new advanced AM radio interference reduction modes.
Dual-band DRC dynamically equalizes the system to provide speaker linear frequency response regardless of output power level. This feature independently processes the two bands, controlling dynamically the output power level in each band and so providing better sound clarity."
Nothing complicated about it...Thanks for this. I just imported it into Peace/APO, is it supposed to look like this? That big dip around 1.4kHz seems a bit extreme...but I probably don't know what I'm talking about.
What if each sample measurement differ?Nothing complicated about it...
NoAudiophile shows his in-room measurements:
His PEQ filter is:
Which means he's creating a Peaking Filter, with gain of ~5dB.
In the picture above:
1. I'm showing you that the 1,343hz frequency peak (using a red-arrow) that he measured.
2. The green lines are showing that if you bring the peak down by ~5dB, it will match the rest of the in-room measurements.
Once we have anechoic data on this speaker (1st gen LSR305P), then we can create PEQ filters based on that, and it will be more accurate.
Otherwise, this is the next best thing.
Of course, if you have your own measurement microphone, feel free to confirm this frequency response and adjust your filters accordingly.
His PEQ filter is:
I'm listening to these speakers for a couple of days now and love what I hear - in my tiny room they easily do as well as the hifi speakers in my living room. Happy that I took Amir's review as a recommendation. Was a bit concerned about the hiss which turned out not to be an issue for me.Get a pair so that you can get calibrated on what good sound is like
I have a bunch of JBL 305P MkIIs and previous generation LSR 305s in an 11.1-channel Dolby Atmos system. The hiss level on all of them is negibible, in my estimation, and I’m accustomed to inefficient passive speakers like Magnepans driven by very quiet MOSFET power amplifiers. I can’t help but wonder whether there is some considerable variation from unit to unit or among production runs with 305s, since some users seem really vexed by it. I have to put my within a few inches of the tweeter to even hear it.
I have x2 308p's and they both have the same amount of hiss, I listen at 2 metres and can't hear any hiss at that distance in a quiet room....at 1 metre distance I can barely hear it. Like you, I noticed that the hiss is not affected by volume position of the knob on the back of the speaker. I wouldn't want these speakers on my desk either side of my PC monitor for instance because they would be too close & I'd hear the hiss. I use them as TV/movie / music speakers in my living room so the hiss is a complete non-issue (can't be heard) at my listening position (2 metres as mentioned)Definite variance in hiss
I have 2 LSR 305 mkI which I can only just very very faintly hear hiss if you try to listen for when playing nearfield from less than a metre away
I bought 2 308 mk IIs for living room for home cinema use and the hiss is both audible (and annoying) from 2.5-3m away !
The hiss does.not change on volume on rear or whether even plugged into any audio source
One has slightly more hiss than the other.
They sound good but the hiss is only just about acceptable even in living room if you listened carefully you would probably even hear it during quiet parts of a film
If they didn't have auto standby I would not be able to keep them in the living room at all
It's orders of magnitude louder hiss wise than the 305 mkIs
