JBL Stage 125C Review (Center Speaker)
Rate this speaker:
    Votes: 104 57.8%
    Votes: 65 36.1%
    Votes: 10 5.6%
    Votes: 1 0.6%
This is a review and detailed measurements of the JBL 125C home theater center speaker. It is on kind loan from a member and costs US $120 on Amazon currently.
The 125C really looks nice with the symmetrical what woofers:
Typical of some center speakers, it doesn't have a port (i.e. they think people will put them in cabinets):
NOTE: our company, Madrona Digital is a dealer for Harman which includes JBL line. So feel free to read whatever level of bias you like in my subjective remarks.
Measurements are compliant with latest speaker research into what can predict the speaker preference and is standardized in CEA/CTA-2034 ANSI specifications. Likewise listening tests are performed per research that shows mono listening is much more revealing of differences between speakers than stereo or multichannel.
Reference axis was the center of the tweeter (aligned by eye). It is getting colder with the measurement room temp at 16 degrees C. Accuracy is better than 1% for most of the range but drops to 2% for part of the spectrum.
JBL 125C Measurements
Acoustic measurements can be grouped in a way that can be perceptually analyzed to determine how good a speaker is and how it can be used in a room. This so called spinorama shows us just about everything we need to know about the speaker with respect to tonality and some flaws:
On axis response looks flat and good other than the sloping down woofer response. Lot of resonances are visible as is the directivity error. The latter messes up the early reflection measurements:
JBL 125C Measurements Early Window Frequency Response Center Home Theater Speaker.png
Combining the two we get our predicted in-room response which shows fair amount of coloration:
JBL 125C Measurements Predicted in-room Frequency Response Center Home Theater Speaker.png
Near-field response is not directly revealing of the design problem:
JBL 125C Measurements Near field frequency response center Home Theater Speaker.png
But the horizontal beam width is:
The two woofers fight with each other causing sharp narrowing of the response between 500 Hz and 3 kHz until tweeter takes over. For a center speaker, this is really bad as the coverage angle is as low as just 20 degrees.
Contour plot shows the same thing:
JBL 125C Measurements Horizontal Directivity Center Home Theater Speaker.png
These "MTM" designs are optimized for vertical usage and we see that in that orientation:
On the other hand, the two woofers provide ton of dynamics and power handling as seen in our distortion graphs:
Worst case impedance is 4.4 ohm which is not too bad:
For the fans of timing analysis, here are the waterfall and impulse responses:
JBL 125C Listening Tests and Equalization
This section intentionally left blank.
Not feeling that great and can't make noises right now. So no listening results.
As if we needed to drill this message into our head strong and deep, we see that you can't easily build a proper 2-way speaker with symmetrical woofers on each side of the tweeter. Beam width narrows significantly causing issues for a center speaker in home theater which needs to cover a wide seating area. Response is not bad if you use this vertically. It is also better than JBL Stage 135C I reviewed recently.
I can't recommend the JBL Stage 125C based on these measurements. It is the wrong design for the job.
  • JBL Stage 125C.zip
pseudoid
S.O.S.A.D. after day!
I think I saw an Instagram photo of the Headless PinkPanther and the last 3 tested Center speakers hanging out at the homeless shelter.
I can't imagine how much worse those "soundbars" must test and sound.
I don't know what all of these results might possibly indicate about those rear-firing 'noise-generators' inside all current TVs...
As if I needed more reasons to stick with a quality pair of floor-standing stereo speakers .
pierre
Switzerland
Score is 2.3 and would go to 4.1 with the following EQ:
Code:
EQ for JBL Stage A125C computed from ASR data
Preference Score 2.3 with EQ 4.1
Generated from http://github.com/pierreaubert/spinorama/generate_peqs.py v0.14
Dated: 2021-12-01-07:37:44
Preamp: -4.2 dB
Filter  1: ON PK Fc   667 Hz Gain +3.99 dB Q 1.44
Filter  2: ON PK Fc  6372 Hz Gain -2.06 dB Q 0.72
Filter  3: ON PK Fc   171 Hz Gain -2.03 dB Q 2.41
Filter  4: ON PK Fc  1778 Hz Gain +1.98 dB Q 3.00
Filter  5: ON PK Fc  4473 Hz Gain -0.75 dB Q 3.00
Filter  6: ON PK Fc  7091 Hz Gain +0.64 dB Q 3.00
Filter  7: ON PK Fc   432 Hz Gain +0.53 dB Q 3.00
Graphically the EQ looks like:
and change the spin and PIR:
Hope it helps.
GD Fan
NY, NY USA
Wow, interesting horizontal for a center speaker.
Newman
It's almost like JBL are masters of upright speakers and morons of the horizontal variety.
phoenixdogfan
Nashville
It even has that waveguide for all the good it's doing. The MTM configuration seems to be a prescription for this sick center channel response. Just what the Doctor didn't order for us or Amir.
bunkbail
Does a pair of these make a good stereo speakers, if EQ'd that is?
Rja4000
Liège, Belgium
So, in short the MTM design doesn't work for center speaker.
Which is just a confirmation of theory.
@amirm Is that even worth testing more then ?
Bjorn
Norway
This is exactly why one is generally better off buying one front speaker and use it as a center rather then buying the "center speaker" from the brand. Obviously that would require using a sound transparent screen with the speaker behind it. With a TV it's often better to drop the center speaker, use broadband constant directivity speakers and just treat the early specular energy since the fronts are often close to side walls.
abdo123
Brussels, Belgium
I mean broadband constant directivity speakers. ;) That can be achieved in several ways. A big horn design is just one way.
The only thing else i can think off is a Geddes speaker but with a much more bigger baffle. that sort of design would always need a crossover though.
Bjorn
Norway
That's not really a broadband directivity speaker. Besides it is type of horn speaker (waveguide=short horn profile). Anyway, that's a different topic and doesn't belong here.
My point is that using a center speaker with a directivity as poor as this, and which is the case with many center speakers, generally isn't necessarily better than dropping the center speaker all together. But in order for the image to be stable with only two front speakers, it's important with a uniform beamwidth and avoid early arriving reflections.
