JBL Stage 135C Review (Center Speaker)
Rate this speaker:
    Votes: 168 88.4%
    Votes: 20 10.5%
  • 3. Fine (happy panther
    Votes: 2 1.1%
    Votes: 0 0.0%
This is a review and detailed measurements of the JBL 135C center home theater speaker. It was kindly purchased new and drop shipped to me for testing. It is on sale now for US $170.
I really like the look of 135C:
This is a 2-way design and other brands we have tested of this kind have proved disappointing for center speaker usage. Will this be different? We will find out.
NOTE: our company, Madrona Digital is a dealer for Harman which includes JBL line. So feel free to read whatever level of bias you like in my subjective remarks.
Measurements are compliant with latest speaker research into what can predict the speaker preference and is standardized in CEA/CTA-2034 ANSI specifications. Likewise listening tests are performed per research that shows mono listening is much more revealing of differences between speakers than stereo or multichannel.
Reference axis was the center of the tweeter (aligned by eye). It is getting colder with the measurement room temp at 15 degrees C. Much more samples were taken for measurement of the 135C due to complex sound field created by the interference between all the drivers. Accuracy is better than 1% for most of the range but drops to 2% for part of the spectrum.
JBL 135C Measurements
Acoustic measurements can be grouped in a way that can be perceptually analyzed to determine how good a speaker is and how it can be used in a room. This so called spinorama shows us just about everything we need to know about the speaker with respect to tonality and some flaws:
I must say, I was not ready for how ugly this looks. We have a bunch of flaws mixed in from lack of deep bass to resonances and directivity error. The only good news is high sensitivity to the tune of near 90 dB.
Due to directivity error which we will cover later, off-axis response is just as chewed up:
JBL 135C Measurements Early Window Frequency Response Home Theater Center Speaker.png
Somehow it becomes smoother when combined to predict the overall room response:
JBL 135C Measurements Predicted in-room Frequency Response Home Theater Center Speaker.png
The increase in energy at 200 Hz gives the sensation of bass to the unitiated but I find such sound tubby and undesirable. We also have some increase in high frequencies combining to present somewhat of a "showroom sound" for a small speaker.
Near-field measurements show some pronounced resonances:
JBL 135C Measurements near field Frequency Response Home Theater Center Speaker.png
The ports by the way are at each end of the speaker.
Now we get to the disappointing part: horizontal directivity and beam width:
JBL 135C Measurements Horizontal directivity Home Theater Center Speaker.png
A center speaker needs to cover wide audience range and this is the opposite. The driver array has destructive cancellation that causes it to highly "beam" (narrow) in response from 300 Hz up to near 3 kHz. A lot of the vocal range falls in this area so voices are definitely going to be impacted.
While we don't need good vertical directivity, we have it here:
One nice thing I have found with multiple drivers is that they handle power very well. Even though these drivers are small they still do an excellent job here:
JBL 135C Measurements THD Distortion Response Home Theater Center Speaker.png
Impedance is typical of speakers these days, dropping down to 4 ohms:
JBL 135C Measurements Impedance and Phase Response Home Theater Center Speaker.png
For fans of timing analysis, here are the waterfall and impulse responses:
JBL 135C Listening Tests and Equalization
I always listen on-axis to speakers which helped the 135C hide its horizontal directivity. Here, I found the sound as predicted, tubby depending on the track and a bit bright. Moving just half a seat horizontally, killed the clarity and openness of vocals. Figuring some don't need multi-seat coverage, I attempted to fix the high level flaws using equalization:
I put in the filter at 200 Hz to get rid of overboosted response there. That got rid of the tubbiness but then highlighted the highs even more. So I dialed in the shelving filter on the right and got that fixed. Problem was, I now lost most of the bass response. I dialed in a quick and dirty low shelf and was surprised how well that worked. I had warmth and good bass now with no noticeable rise in distortion! Once there, as long as you sat on-axis, the sound was quite enjoyable with good ability to play loud.
JBL nails the price and looks of this speaker together with svelte form factor. Alas, it attempts to fight physics and loses on horizontal directivity. No doubt marketing and cost dictated this configuration as their competitors are guilty of the same. Fortunately it responded well to manual equalization (automatic may not work well). So if you want to listen alone, you should be fine. Note that you can't use it vertically due to the ports at each end unless you hang it on the wall.
I can't recommend the JBL 135C as a center speaker.
  • JBL 135C Frequency Response ASR.zip
spacevector
Bayrea
Wow the harman/kardon streamer recently and now this JBL speaker. Both trashed. Must have taken some inner strength and courage amir - admirable. :p
MZKM
Land O’ Lakes, FL
As for having six 3“ woofers, I assume that it is to make it similar to the size of a soundbar, allowing for flexibility with placement (e.g., on top an entertainment center, attached under a mounted tv, etc.), this goes along with having side ports over rear ones (a sealed design would have no bass in this case).
As for why a 2-way over a 2.5-way, I assume that is to keep sensitivity high and in line with most other center channels (89dB is about average for all center channels tested).
I find it odd that this is their only center channel offering for the line, I assumed there would have been also a 2-way version utilizing dual 5.25”.
Polk‘s Signature Elite line for reference:
MZKM
Land O’ Lakes, FL
@MZKM they also have the A125C with 2x 5.25" Woofers.
Hmm, it’s not on their main webpage, so I guess they discontinued it (maybe the market has spoken):
However, it is on this site:
However, on that same site they don’t have the normal Studio line of speakers, like the Studio 590 towers, they instead seem to have a variant of the HDI series, here is the Studio 690 for instance:
https://mm.jbl.com/loudspeakers/JBL+STUDIO+690.html
Are these new models?
The center reminds me of the Array one with its narrow waveguide.
respice finem
Second thought: Considering the price, this one is likely to end up in a really cheap system, and perhaps wall-mounted, the remaining speakers being at a similar performance level. So maybe it's just good enough for this. That said, and for this scenario, a modern soundbar can be serious competition.
pierre
Switzerland
Humm. Really bad speaker.
Score 0.8
Here is an EQ optimising things a bit starting at 120Hz, it will push the score to 3.1.
Code:
EQ for JBL Stage A135C computed from ASR data
Preference Score 0.8 with EQ 3.1
Generated from http://github.com/pierreaubert/spinorama/generate_peqs.py v0.14
Dated: 2021-11-29-08:57:42
Preamp: -0.6 dB
Filter  1: ON BP Fc   263 Hz Gain -3.60 dB Q 0.05
Filter  2: ON PK Fc   230 Hz Gain -4.30 dB Q 1.01
Filter  3: ON PK Fc  3925 Hz Gain -3.67 dB Q 1.40
Filter  4: ON PK Fc   948 Hz Gain +1.05 dB Q 4.00
Filter  5: ON PK Fc  1443 Hz Gain -0.50 dB Q 2.16
Filter  6: ON PK Fc   486 Hz Gain -0.61 dB Q 4.00
Filter  7: ON PK Fc   181 Hz Gain -0.50 dB Q 4.00
The EQ will cost you ~6dB.
YSC
Reference axis was the center of AMT driver (aligned by eye). It is getting colder with the measurement room temp at 15 degrees C. Much more samples were taken for measurement of the 135C due to complex sound field created by the interference between all the drivers. Accuracy is better than 1% for most of the range but drops to 2% for part of the spectrum.
This is real bad… especially from a brand with so much research backing it…
Cost is on cheap side but I can’t imagine ppl buying this in a multi channel setup for better sound yet get all these
H-713
Headless for being almost useless with that beam width. I get the sense that this was designed to look a certain way, not perform a certain way. Of course, at this pricepoint, looks is what sells.
LearningToSmile
Good timing with the review since the JBL Stage series seems to have finally become available in Europe recently. Unfortunately disappointing result, even comparing to other 2-way center speakers.
@amirm any other JBL Stage speakers in the pipeline? I'm not expecting much from them anymore, but it would still be nice to see the towers measured, particularly the A190.
ROOSKIE
Minneapolis
Yikes.
Get a three way or no way.
The 3way Polk L400 is on sale right now.
$1449
I also believe accessories4less is expecting more Polk LSIM706c's soon for $399. Crazy good price for those. Both Black and Cherry should be in stock again soon. My Old Polk LSIM703's performed extremely well.
Airmotiv C2+ and SVS Prime are also $399, wonder how these perform?
Blumlein 88
And another one bites the dust... Making a good measuring horzontal center seems to be almost impossible, let alone a low profile one.
Yes it does. So hopefully a few more measurements and that format will be abandoned. If you use a projection screen, you would have the option of getting an acoustically transparent screen and putting a conventional well designed floor stander in for the center.
voodooless
Netherlands
Well, tell that to the spot underneath my TV... I only have room for a small thingy. But since even most big ones suck, it doesn't really matter that much. I did try to come up with an alternative with my Bessel Array topic, but in the end, it seems it will not yield enough HF directivity and you have to sit too far away to make it properly work. The only thing that I can think of now besides a small Coax (with limited output as a consequence) is a horizontal CBT array, however, that needs lots of drivers and a rounded shape and/or a boatload of DSP channels.
dasdoing
Salvador-Bahia-Brasil
the woofers need to be isolated, so the lobing ocures above the crossover, like done in line array modules:
now these are obviously produced for big distances, I am still curious how this would behave. sitting on the left you would be totaly isolated from the right woofer, for example
