JBL Stage A130 Review (speaker)
Toblerone
I ordered the speakers a couple of weeks or so ago from a Canadian retailer. I got an email saying, that the speakers won't be delivered to me before the thirty-first of March. The shop owner blames the plague for the delay: presumably, production can't currently meet demand due to general plague-related logictics and manufacturing issues
Yea I talked to JBL support and they said:
Good day! Thanks for reaching out. We're here to help you with your inquiry. Our JBL Stage A135C isn't available until the 2nd week of May, 2021. If you have any questions, please let us know by replying to this email.
Jman841
I got these speakers the other day and am very pleased with them. I am new to "Audiophile" speaker setups, but have been into headphones for quite some time and wanted a better sounding speaker set.
My current setup is using a very old Sony AV Receiver, so I'm assuming this is the limitation of the setup and I've paired it with a Klipsch R-12SW From costco for $150. The Sub has a ton of power and decent sounding, but def not the cleanest bass I have heard, for my purpose, it works well.
I also noticed these speakers do sound much better, to me, without the covers on them. I'm not sure if I'm crazy in this, but the highs and detail sounds far better without them.
Question: If I were to upgrade to a newer, higher end AV Receiver, is there going to be a significant advantage when running it in 2.1 (JBL Stage 130 and the Klipsch subwoofer)?
I got this one for free and it is rated at 100w/channel so it has plenty of power, just not sure if the older processer (2003) and technology is severely limiting the sound potential of these speakers.
boselover61
likely inaudible unless the sony receiver is flat out broken
Jman841
Just to test it, could I hook my Topping E30 DAC up to the analog audio input on the AV Receiver and just get it to pass through acting as an amp?
theyellowspecial
Better off picking up a MiniDSP/Dirac/Mic kit.
Jman841
ok, I'll give it a try to see if I notice any difference between the E30 day and the internal decoding. It will just be temporary as the E30 is my desktop DAC, but i'll be curious. I'll also be able to apply EQ when running the E30 to these speakers so it will be interesting to see how the EQ on these changes the sound.
asem
EQ cannot fix all issues that insufficient crossover design bring to the table like time align correction , avoiding cone breakup , and so.
EQ should be the last mod to the speakers after sufficient crossover design.
Hi
I tried applying eq to the a130, but it seems to sound bad to my ears. Obviously the overall dynamics seem to be a little flatter, but it feels like something is covered in sound. It seems to be struggling to make the sound come out.
Maybe this is a problem with software eq? I am wondering if the actual crossover mod will produce better results than eq.
If both methods produce similar results, it makes no sense to try the crossover mod...
abdo123
Brussels, Belgium
By the way regarding PEQ, the files and recommendations folks have posted here are pretty pointless. One has to measure in room. None of the examples here match in the way that I would want when compared to what I actually used in my room. In fact I think using them would be just slightly above a zero sum game.
Speaker correction and room correction are completely different things. all the filters in this thread are to correct the speaker, not to accommodate for the room.
doing speaker correction (with an extreemly accurate data set, like a spinorama from a Klippel NFS) means that the speaker will interact with the room in a predictable way. and that room correction will be more effective and tonally correct.
ROOSKIE
Minneapolis
Howdy, I do understand that (the difference between RC and Speaker correction.)
In my post I was only reffering to the values posted for this speaker, not other speakers. I should make that clear.
The problem is that some folks are plugging these values in blind and thinking they are done.
You have to factor in the room once you have one.
2 values are frequencies below 200hrz and 2 above 10k. These really are affected by the room, so much so that I would only want to manually adjust after an in room measurement.
The main thing to eq is that mid-range area. I know that the Klipple data is awesomely accurate. Still, in my room the middle range hump presented differenty from the PIR so how to correct it may be up for debate. (I deff corrected for it but with different values)
In any case these are very nice speakers for the $.
I also have often the feeling that too many and too narrow filters can often make a loudspeaker sound lifeless and also make the imaging flatter. Keep in my that positive peak filters mean adding a ringing in time domain.
https://support.genelec.com/hc/en-u...-does-GLM-not-fix-dips-on-frequency-response-
I'm a little late to this but, yeah, while you think of EQ as just taking out those specific frequencies any EQ that isn't specifically noted as a "linear phase EQ" will mess with phasing which will introduce its own issues. And yes, unless it is a crappy desktop speaker that you're making crazy adjustments to to make it somewhat pass as flat, if it's hi-fi you want to use wider Qs and less of them. Just fix broad problem areas and call it a day.
Denon545
I purchased the Stage A180 towers and A125c center. Very good sounding speakers. I’ve owed several brands in the past NHT, Elac, Klipsch, SVS... these things take the cake. What’s surprising is how good the center sounds. In the past I would have issues with the dialogue getting lost in the mix, but not with the JBL’s. I am shocked they sell at such a low cost and outperform much more expensive speakers!
More Dynamics Please
USA
By chance have you tried any experimenting with a phantom center channel to see how effective it might be compared to using the A125C center? Reviews of the Stage towers suggest the HDI waveguides help produce an effective phantom center with well-centered dialog.
Denon545
I've run phantom center some and it is really good. My room is a little asymmetrical and I sit closer to the right side, so I am away from the sweet spot in the middle. Which is why I like the A125C. If you are more towards the center, and in the sweetspot, the phantom effect would be good.
Toblerone
I have the A135C center and was surprised at how good it is, especially with everyone discounting center speakers with a similar design. I tried a phantom center with just the A130s and thought the A135C made a significant/difference.
But then again I am new to all this and don't exactly know what I might be missing with a more traditional center but dialogue is very clear and definitely better with the center channel.
