Looking for a tube amplifier references
hawai_50
Hello, I got this chasis, and I'd like to know more details about brand, model, tubes, or whatever it is possible to know. At the moment I suspect it was from a british amplifier, and probably wearing 4 valves. Is there any one who knows about it?
Thanks a lot
hawai_50
hawai_50
Could someone give a clue?
Frank Dernie
Oxfordshire
No idea myself.
Here is not a place where valve amp enthusiasts are particularly thick on the ground.
I would try a forum where “valvebloke” posts. He is a brilliant English scientist with an interest in repairing valve amplifiers. He can be found on Hifi Abattoir, Hifi wigwam and maybe others.
Worth Davis
I would find someone local so it doesn't kill you. Hit Craigslist for a local tube builder guy
SIY
Alfred, NY
No idea myself.
Ahem. :cool:
But of course, I'm useless here other than to observe that there seem to be no transformers there, so unlikely to be anything of value or use.
Frank Dernie
Oxfordshire
Ahem. :cool:
Oops, SIY sorry forgot your extensive expertise in thermionic electronics :facepalm:. I was thinking if it is a UK amp and he wants to know which it is "Valvebloke" may be able to help.
Certainly there is not much of value in the photos and I know nothing whatsoever about valve amps.
SIY
Alfred, NY
If @hawai_50 gets nowhere, drop me a note and I'll run it past Morgan Jones, who literally wrote the book. This appears to be a removed part of a larger assembly, with all of the useful stuff stripped off. The thumbwheels might be significant for identification.
hawai_50
hawai_50
I wanted to know any detail, to get at least the valves it was containing, or if possible the brand / model or even the schemathics ...
in order to to use as much as possible all parts that are already mounted in the chassis for building / rebuilding a small amp project. It is not for comercial use, just entertainment.
Thanks
SIY
Alfred, NY
Thanks
Hate to be Debbie Downer, but you don't even know it was an amp, the parts worth using are not there (and new ones are not cheap!), and the stuff left behind (dried out electrolytic capacitors, antique carbon comp resistors, fishplate tube sockets) shouldn't be re-used.
hawai_50
hawai_50
It's probably a foolishness for you, but I really enjoy this type of restoration. I have material and transformers in the warehouse, coming from other projects. Thanks for showing your concern.
SIY
Alfred, NY
It's not restoration (I've done a fair bit of that myself!), it would be literally ripping everything out of there and starting from scratch. There's essentially no parts in that which should be re-used, except maybe the chassis. You might be able to recover the thumbwheel switches with disassembly and cleaning.
hawai_50
hawai_50
I just wanted to know the brand and model of the chassis that I have shown.
If someone could give me that simple information, I would be very grateful
Many thanks to you and Frank Dernie, also Worth Davis, for multiple answers here
Thank you
sergeauckland
Suffolk UK
I'm not sure it is an amplifier, possibly a preamp, but there's no sign of where one or two output transformers would go, and the internal construction isn't symmetrical, so unlikely to be stereo.
My guess is that if it's a piece of audio equipment at all, it's a tape recorder chassis, with the round hole for a meter, and the two coils something to do with a bias trap and oscillator. If it's not that, then don't have a clue. My further guess is that it's a DIY item, so no manufacturer.
S
invaderzim
NorCal
..My guess is that if it's a piece of audio equipment at all,...
That is what I keep wondering, since tubes did a lot more than audio back in the day it could easily be some other type of equipment.
... My further guess is that it's a DIY item, so no manufacturer.
It does have the one off look.
tourtrophy
Probably not worth salvaging it. The point to point wiring looks horrific. I don't see any proper grounding just by looking at it. Better off getting one of the DIY kit from TubeDepot to save you all the headaches.
hawai_50
hawai_50
After hearing all these reasonable opinions, I'm going to use the chassis and also, if I can, the potentiometers to put on a simple Chinese kit that I already have and had wanted to mount for some time. Mount the transformers away from the chassis to have more space. Therefore nothing to do with the brand of origin, or with the components that are seen. Thank you all for collaborating in the decision making process.
Panelhead
Does not look like a conventional audio amplifier. Could be a short wave radio.
