Looking for Power Protector
Ronen
HI.
Any opinion what to "choose" : AudiQuest Niagra 5000 OR McIntosh MPC500 regarding power protection ?
I have a McIntosh A/V kit.
Price doesn't matter.
Thanks.
SIY
Alfred, NY
HI.
Thanks.
I would strongly suggest sticking with reputable brands like Tripp-Lite or Sola. That's the kind of stuff you see in mission-critical uses like hospitals and data centers.
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
SurgeX is another I understand to be considered decent. Mine have given me no problems.
If it is marketed to 'audiophiles,' that's your clue to keep looking.
_thelaughingman
@Ronen
Tripp-Lite 12v Outlet
This should keep your A/v happy.
I am a Clinical engineer for medical diagnostics instruments and the majority of the instruments that need power surge protection uses Tripp-Lite surge protectors.
iLoveCats
USA
What are your guy's thoughts on whole house protectors installed in the main breaker panel? They are now required in the US per the 2020 National Electrical Code book for residential construction and upgrades. They can't be snake oil if its in the code book.
ThatM1key
USA
I personally plug my amps into the wall directly. Depending your area and such, your breaker will deal with thunderstorms well. I remember I got this old used monster power strip from a thrift store and I trust that thing more than my local dollar stores offerings.
iMickey503
United States PDX
Cost no object? Server grade UPS. Eton I think use to make some of the best ones out there for industrial / Medical and Lab style supplies. Not the most efficient things out there.
These things as I recall are used in Military installations where the power has to be clean without any exceptions.
Its overkill. Needs 2 phase 240v. Not for the faint of heart. you buy something like this when the gear that you run is unobtainium
NTK
US East
This is what Amir recommended.
Teeter
Janesville, WI
For his and hers TVs with satellite boxes, dvd, AVR, etc., both surge protectors are rated at 3000+ Jules. Two lab tops on the same surge protector is 1500 Jules. We have several power failures in our neighborhood over the past 15 years, including transformers being replaced, and none of the devices have ever been destroyed. The circuit lights on the surge protectors are still green.
I do have to go along with having Tripp Lite surge protection.
bkdc
My gold standard is SurgeX and it commands a premium price. If I were building a house from scratch, I'd pay a few grand to have the SurgeX installed at the electrical panel for the entire home. SurgeX, ZeroSurge and Brickwall do not use a sacrificial MOV and can handle incredible current spikes.
D
Deleted member 46664
Guest
HI.
Thanks.
Best bet ... Head on down to Home Depot or even Walmart ... 6 or 8 outlet power strip with a fuse and surge protection ... $15.00 and mission accomplished. The super expensive stuff does nothing more and nothing better.
conqueeftador
Can anyone recommend something for the UK? Last time I checked none of the brands mentioned are available with our clearly superior 3 pin plug (untill you step on one).
