Magnat MA 900 is almost the perfect amp for me but lacks of...
Hi fellows,
found in the MA 900 the almost perfect amp for me, but is has no support for pre or sub out.
I love the brushed alu style, bass/mid/treble management and loudness. But maybe I will run a miniDSP in near future, which I can't with this amp, nor can I run a sub. So, what are the alternatives.? This amp with pre and sub out and below 1k Euro would make me very happy. But it seems it's not developed yet...
Matias
São Paulo, Brazil
Doodski
Hmmz. I looked about and subwoofer output with pre-out is rare these days for your price range.
Doodski
What about NAD C368?
That's a nice unit although the pre-out and sub-out are combined in one set of RCA's.
voodooless
Netherlands
The real question is: what do you need the miniDSP for? Wouldn't it be better to just buy a Flex as a pre and buy a power amp?
Right now found a Pioneer A 50. What do you think?
Compared to the NAD it looks arcane and crude. I would not pay 999 for that.
voodooless
Netherlands
Advance Acoustics PlayStream A5 looks the part
Otherwise:
Audiolab 6000A
Denon PMA-900HNE
Marantz NR1200
Doodski
It appears they are for accessing the power amp section as a slave amp.(Similar model pdf.) Otherwise your suggestion of a miniDSP Flex is a great idea.
P
Hm, NR 1200, 6000A and c368 are almost the same price. But marantz has plastic front. Can't find anything about bass/treble management with the 6000A, so seems to be the nad left
voodooless
Netherlands
So, what do you want the MiniDSP for then?
