Measurements of the Fiio E10k Line Out
Thalis
I got a new MM that can measure low VAC and frequencies so I was very eager to take it on a test run and measure the Line Out of the Fiio E10k. As expected Low or High gain had no effect on the output. But here's where it was a little weird for me. At various frequencies, I get different measurements.
Using Foobar2000 to generate the tones @16bit 44.1kHz @0dB and sending bitperfect to the DAC (WASAPI).
I will list out some (all left channel - I found right channel to be the same) :
10Hz 0.006VAC
20Hz 0.015VAC
50Hz 0.045VAC
60Hz 0.054VAC
100Hz 0.094VAC
200Hz 0.192VAC
400Hz 0.384VAC
600Hz 0.567VAC
1kHz 0.880VAC
3kHz 1.611VAC
4kHz 1.672VAC
5kHz 1.675VAC
7kHz 1.633VAC
10kHz 1.570VAC
11kHz 1.554VAC
15kHz 1.507VAC
17kHz 1.491VAC
18kHz 1.484VAC
19kHz 1.478VAC
20kHz 1.471VAC
I did not expect such margin but I don't know how it relates to the DAC's actual performance. I most definitely did not expect 1kHz to be that low and expected it to be at least 1.5VAC if not nearer to 2VAC. But looking at the higher frequencies it does seem to be within specs? So if I were to make sure my USB mixer (variable output) has a 2VAC output, do I just measure its higher frequencies to try to get close to 2VAC or do I use 1kHz and set it to 2VAC?
Hope to get some feedback.... thank you.
solderdude
The Neitherlands
Doesn't make sense.
Did the amplitude look the same on the 'scope' part ?
Maybe you have the time-base set incorrectly on the 'scope section'.
I would have expected better resolution but maybe it is due to the time-base.
The meter 'measures' using the scope part most likely.
One should at least see 3 full waves on the screen before it can calculate the voltage.
Thalis
Thalis
Doesn't make sense.
1. Pressing the display on MM to display the amplitude it did rise to 0.999 kHz for the 1kHz tone
2. Ok not sure about "time base". Can you explain a bit more?
3. 3 full waves as in 3 peaks and 3 dips?
Edit... always willing to retest and learn how to use the new MM
solderdude
The Neitherlands
Thalis
Thalis
Testing 1kHz tone..........
I managed to get screen to display 3 full waveforms. I can also make it display 1, 2, 3, 6 etc full waves.... but the voltage remains the same at 0.880VAC
Edit... also trying 10kHz... showing 3 full waves.... 1.570VAC :confused:
solderdude
The Neitherlands
As long as it has at least 1 complete (better = 2) it should display the correct voltage. I assume RMS is calculated.
For those wondering what this is all about: Mustool MT8206 multimeter with waveform display.
Thalis
Thalis
Hopefully I am just doing it wrong
Thalis
Thalis
Well... @100Hz the graph can't even display properly but the voltage remains as I have listed
Thalis
Thalis
Is the E10k is rated at 1.5VAC output or was it supposed to be 2VAC?
Thalis
Thalis
Here is the MM display @3kHz
Thalis
Thalis
@solderdude
After re-reading the manual several times... the Tip for waveform of Voltage Measurements says this:
The DC voltage file DCmV/V) uses a large time base scan method to select the appropriate time base to capture the waveform when measuring the waveform ACmV small signal waveform, you need to manually enter the ACmV range, then press the "SELE" button to enter the waveform display.
so I have to press REL and SELE to change the time base. What should I enter?
Thalis
Thalis
ah I understand now.... I need to be in waveform display in order to change the time base... I can use REL and SELE (up and down) to change the time base and have how many full waves i want to see.
So I have been doing that but unfortunately the VAC still remains approx the same as I have measured earlier :(
solderdude
The Neitherlands
It makes no sense that the meter would not be accurate at 50Hz for instance.
1.5V AC should not register as 0.015V 0.045V
Thalis
Thalis
I actually listed 50Hz at 0.045 VAC. However... I watched some videos on the MM and the reviewer did say this is RMS. Not sure how to calculate that back into just VAC.
solderdude
The Neitherlands
RMS is 0.707xVp for a pure sinewave. For a sinewave RMS is what the VAC setting should show.
Measure the mains for instance. See if that is correct.
1.5V (if it is really there) should measure as 1.5V not 0.045V no need to calculate anything.
Maybe use an online tone generator ?
Thalis
Thalis
Checked mains earlier......... getting 237.2VAC @50.003Hz. So its working as it should.
Which online tone generator would you recommend?
Thalis
Thalis
@solderdude
I don't know what the hell I did.... tried measuring the E30 and initially getting disappointed. Then suddenly the MM "came alive" even though I wasn't probing the ground sleeve of the RCA. The MM started showing 2.1VAC at 1kHz, 50Hz, 20Hz and 15kHz.
Without turning the MM off.......... I started probing the Fiio E10k again and i am getting:
10Hz 1.457VAC
20Hz 1.466VAC
50Hz 1.469VAC
60Hz 1.469VAC
100Hz 1.470VAC
200Hz 1.470VAC
1kHz 1.467VAC
3kHz 1.465VAC
4kHz 1.465VAC
10kHz 1.458VAC
15kHz 1.449VAC
20kHz 1.437VAC
I still have no idea what the hell i did!
solderdude
The Neitherlands
Looks good.
It's always frustrating when you have no idea why something didn't work directly.
Maybe the probe ?
Set it to resistance, connect the probes and wiggle, pull etc on the probes to check if the probes are O.K.
Thalis
Thalis
Spoke too soon... was setting up my USB mixer to 2VAC output and doing fine from 10Hz to 1kHz then I turned the knob to frequency and back to VAC and its giving me rubbish reading again :mad:
